Cold Air Intake for 2024 TRD PRO Tundra
Discussion in 'Performance and Tuning' started by TRDPRO.TX, Mar 7, 2024.
  1. Mar 7, 2024 at 11:52 AM
    TRDPRO.TX
    TRDPRO.TX [OP] @trdpro.TX on Instagram
    2024 TRD PRO TUNDRA
    2023 Dodge Demon 170
  2. Mar 7, 2024 at 11:58 AM
    pursuit2550
    pursuit2550 New Member
    You do know that the OEM intake is a CAI intake, correct?
  3. Mar 7, 2024 at 12:04 PM
    lapoolboy
    lapoolboy New Member
    Any modification to a forced induction intake isn't going to net you a whole lot. When it sucks, it sucks.
    And no, buying two of those won't work. Each side is different. It isn't even for your generation truck. Have you opened your hood?
  4. Mar 7, 2024 at 12:46 PM
    umrex
    umrex New Member
    I am patiently waiting for Stillen’s CAI. It will draw cold air from the stock location and from the front grill.
    TRDPRO.TX[OP] and Saltyhero13 like this.
  5. Mar 7, 2024 at 1:49 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    same. They said ~January previously but everyone knows how that ends up these days. Hopefully the get the kinks ironed out soon
    TRDPRO.TX[OP] likes this.
  6. Mar 7, 2024 at 3:18 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Don’t buy a part number for previous gen
  7. Mar 7, 2024 at 3:31 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
  8. Mar 8, 2024 at 7:31 AM
    TRDPRO.TX
    2024 TRD PRO TUNDRA
    I do, however, I just want to spend money irresponsibly.
  9. Mar 8, 2024 at 7:34 AM
    TRDPRO.TX
    2024 TRD PRO TUNDRA
    Thanks, is the Momentum GT your favorite out of the limited options for a third gen? Also, what exhaust would you recommend and why? I'm not big on loud, but I am big on tone.
  10. Mar 8, 2024 at 7:36 AM
    TRDPRO.TX
    2024 TRD PRO TUNDRA
    Looking into this one, let me know when you get yours— I am curious to hear a review.
  11. Mar 8, 2024 at 8:50 AM
    dirtydeeds
    Keith
    USA
    AFE is definitely the best one out there. The factory intake is restrictive on purpose. That makes it quiet so you don’t hear the turbos. But it also costs HP
    AFE is the least restrictive design. Look at how the air comes into the box on all of the intakes. You can even see the difference.
    we build exhaust systems here at my shop. With several sound levels to choose from you won’t get the Honda civic v6 scream, unless you want that. Haha.
    give a call for details. 760-877-4234
    Keith
    TRDPRO.TX[QUOTED][OP] likes this.
  12. Mar 8, 2024 at 11:34 AM
    pursuit2550
    There was once a time when I also spent money irresponsibly on a 6,000lb brick. 06 Silverado SS Supercharged. :spending:
  13. Jul 10, 2024 at 8:13 AM
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    I disagree. While yes they accomplish the same thing, the S&B system is superior and cheaper for a few reasons.
    The AFE system comes with shorter tubes that connect to the stock tubes. This allows afe to sell the extra length of tubing as "turbo inlet pipes" for an extra $200 on top of the already more expensive cost. S&B comes with that all as one piece.
    S&B is also easier to get to the air filters for cleaning.
  14. Jan 13, 2025 at 1:56 PM
    rareskills
    rareskills New Member
    2024 Tundra iForceMax
    3" lift, 35" Nitos, 20" Fuel Rebar wheels, TRD Axleback exhaust, manual bed step, JL Audio 8" W3v3, S&B CAI
    Did you ever upgrade your cold air intake? I have the 2024 hybrid limited which is the same engine as the TRD but does not have the TRD cold air intake ....was looking to upgrade
  15. Jan 13, 2025 at 1:58 PM
    ziznack
    ziznack New Member
    Texas Y'all
    I have S&B
  16. Jan 14, 2025 at 8:05 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    same. Install was relatively easy using my girlfriend’s small hands to get to the mounting brackets but neither of us could get the mounting bracket on the driver side tube to screw in due to the angle and short screws. No idea how in the hell anyone is supposed to rec h those but the intake tube itself is relatively solid in place to where I’m not worried about it having some give.
    Power difference, dunno. Made the turbos louder and my exhaust seemingly as well though
    ziznack[QUOTED] likes this.
  17. Jan 14, 2025 at 8:13 AM
    rareskills
    I'm wondering if anyone has experience doing this to the hybrid limited, I know the engine is the same as the TRD but thought I read somewhere it throws an error you can't get rid of
  18. Jan 14, 2025 at 8:55 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    The TRD intakes will throw a code if you don’t get the reflash but these aftermarket ones should not throw a code. Should not being the key words
  19. Jan 14, 2025 at 10:30 AM
    ziznack
    ziznack New Member
    Texas Y'all
    It will only throw a code of you do it wrong. Mine is a hybrid. If you forget to put the little inserts in the tube then you get to much oil and a code is thrown.
  20. Feb 5, 2025 at 6:00 AM
    ziznack
    ziznack New Member
    Texas Y'all
    Do you get any type of thump sound? I know the sound is so to the intake, but it's a weird thump. I'm guessing it is just the sound of the air rushing in when gears change etc. But it's kind of annoying.
  21. Feb 5, 2025 at 6:45 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    No, no thump sound for me. I occasionally get some like back pressure gurgle from the aftermarket exhaust but nothing from the intakes themselves
  22. Feb 5, 2025 at 7:04 AM
    ziznack
    ziznack New Member
    Texas Y'all
    I was having it on my 23 and I thought there might be something wrong with the truck and didn't think anything about the intake. I recently put the intake into my 24 and it started again so I know it has to do with the intake.
