Sony 9500es gps
Discussion in 'Audio & Video' started by Sonicbluerider, Jan 8, 2025.
  1. Jan 8, 2025 at 4:08 PM
    Sonicbluerider
    Sonicbluerider [OP] New Member
    Dennis
    2019 Tundra
    SiriusXM works so all pulgs are in right ,but my GPS does not..do I have to load google maps to the unit to get gps to work??
  2. Jan 9, 2025 at 10:52 AM
    jimg
    jimg New Member
    2016 Tundra Limited 4x4
    The sony 9500es does not have built-in gps
    It works with your phone only. , apple carplay or android auto
    If your phone is connected is should be working
  3. Jan 9, 2025 at 11:54 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Thanks. Called support an said that also .Hopefully get truck back today,other mods getting done .
  4. Jan 9, 2025 at 3:19 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Waiting on truck so 10 youtube videos later an no help o. This. ???? How do you listen/ to music an have maps displayed on radio at same time .??? Thanks
  5. Jan 9, 2025 at 4:12 PM
    jimg
    jimg New Member
    It just will
    You will get the hang of it once you have it in front of you
  6. Jan 9, 2025 at 4:39 PM
    Sonicbluerider
    Dennis
    2019 Tundra
  7. Jan 10, 2025 at 8:14 AM
    Snert
    Snert New Member
    2021 SR5
    If you have music playing on say Spotify for example, and a route on Google Maps, clicking this split screen button in the corner:
    should make the screen split and look similar to this:
    This is only for reference/I grabbed a screenshot from google but it looks more or less the same as my 9000ES/the carplay split screen looks about the same on any head unit, looks about the same on my wife's CX-5 head unit.
  8. Jan 10, 2025 at 11:29 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Thanks you got ttruck back .all seem to be working.
  9. Jan 11, 2025 at 9:34 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Now what!! Lol got most of it understood, however with all wires connected an radio install the USB is not working/ connecting! Tried to up load file pictures off a thumb drive an radio screen says USB not connect! ill try hooking phone up later but if anyone has solve this problem chime in !!!
  10. Jan 11, 2025 at 3:27 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Nope usb dead.
  11. Jan 11, 2025 at 11:12 PM
    jimg
    jimg New Member
    Make sure you change the input to usb on the headunit
    I thought the same thing on my jvcz1000
  12. Jan 12, 2025 at 4:16 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Thanks.. though i did but will try again..
  13. Jan 12, 2025 at 10:36 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Nope dead .wondering if a radio reboot might fix it.
  14. Jan 12, 2025 at 9:34 PM
    jimg
    jimg New Member
    Restart headunit
    If need be pull the headunit and connect directly to the usb at the 9500 with a usb extension csble. This will check to see if there is an issue from the headunit to the factory usb connection plug
    It is probably a connection issue. Odds are low that the usb is not working on a new headunit
  15. Jan 13, 2025 at 12:31 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Ok so they only sent me on of these cables .they are now sending one .So does this just plug into the ubs-a that is on my 19 tundra dash by cigarette lighter . If so after hooking up what do I use to make sure it works. Phone or what else. Will it show Phone charging? Hate to put together again an find out it's not working. Thanks IMG_1513[113].jpg
  16. Jan 13, 2025 at 12:39 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    The small end (USB-C) will plug into the back of your new Sony head unit, and the other end will connect to what is likely a loose plug behind the stereo. The loose plug is what feeds to your USB in the dash. The bad/annoying news is you or your installer will have to pull the head unit back out to get it plugged in.
  17. Jan 13, 2025 at 1:55 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Thanks. So how do I know it works. Before reinstall?
  18. Jan 13, 2025 at 2:21 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I'd just plug your phone into the USB port before you button everything back up and see if it's charging and/or if the head unit recognizes it.
  19. Jan 13, 2025 at 2:30 PM
    Sonicbluerider
    Dennis
    2019 Tundra
    Thank you soooo much...
  20. Jan 14, 2025 at 7:41 AM
    Snert
    Snert New Member
    2021 SR5
    This is the back of the 9000ES that I have but 9500ES should be the same, USB will plug in back here: upload_2025-1-14_9-33-38.png
    other end will plug into the only USB slot/cord it fits with. To be cautious I'd disconnect your battery negative before pulling the radio, wire it up, set the radio back in but don't bolt it in, reconnect your battery negative and start the truck, and then plug your phone into the USB data port
    The other two USB slots are charging only so be sure to plug into the correct one.
  21. Jan 14, 2025 at 7:57 AM
    Sonicbluerider
    Dennis
    2019 Tundra
    Thanks they r sending me 2new cables. Hopefully that's the problem
