Water Proof Connector kit
Discussion in 'Lighting' started by SnrDisregardo, Jan 14, 2025.
  1. Jan 14, 2025 at 7:06 AM
    SnrDisregardo
    SnrDisregardo [OP] New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
  2. Jan 14, 2025 at 7:21 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Which one of these is same as Toyota's connections?
    That Deutsch connector comes with the stripper/crimper tool. Impressive. I'm so last century with my electrical
    stuff, looks like I need to modernize!
    The Delphi Weatherpack look like factory. States OEM but is it OEM to Toyota or US Big 3?? The weakness is finding
    a good crimping tool to go with it.
  3. Jan 14, 2025 at 1:32 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I use the Deutsch connectors, no issues. Just prefer the more streamline multi-connectors when it comes to mounting and running in tighter spaces. Use them for both audio and external wiring for my running lights and light bar and have not had one fail
  4. Jan 14, 2025 at 1:43 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Me too but I only buy a few at a time.
    I wouldn't use 10% of either of those kits in my lifetime..:eek2:
  5. Jan 14, 2025 at 1:55 PM
    SnrDisregardo
    Wade
    IL
    That's where I miss working at a HD shop.
    1lowlife[QUOTED] likes this.
  6. Jan 14, 2025 at 1:56 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  7. Jan 14, 2025 at 1:57 PM
    JRS
    JRS New Member
    2012 DCLB
    You want line-to-line, right? Not talking any line-to-panel (bulkhead)?
    I don't use WeatherPack and have more often seen Deutsch. That kit is really cheap and makes me question if they're legit TE connectors. But I'm a big fan of the DTM/DT/DTP series. I'd upgrade the crimper to an iWiss HD-2612 though.
  8. Jan 14, 2025 at 1:59 PM
    SnrDisregardo
    Wade
    IL
    Yeah, line to line. I just need something basic, maybe 4 pins tops. I'd like to get something with the appropriate crimp tool too.
  9. Jan 14, 2025 at 2:03 PM
    JRS
    JRS New Member
    2012 DCLB
    On Amazon I've bought 'JReady' kits. For the more obscure stuff, have to go to deutschconnectorstore.com or similar. The crimper is a separate purchase from what I remember when shopping if you don't want to use that cheap one. Which is why I recommended iWiss. They make nice crimpers for the hobbyist/occasional use.
    SnrDisregardo[OP] likes this.
  10. Jan 14, 2025 at 2:05 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I used to make OEM fog light to Rigid fog (Deutsch) connectors and sell them before they were available on Amazon..
    I'm so low class I never had a crimper, I'd just solder the wires to the pins..:eek2:
  11. Jan 14, 2025 at 2:07 PM
    JRS
    JRS New Member
    2012 DCLB
    Yeah, you really don't want to solder these. There's a reason you don't see soldered pins in automotive... Vibrations will eventually crack it. JST (Japan Solderless Terminal) has bazillion inventory catalog for this very reason.
    1lowlife likes this.
  12. Jan 14, 2025 at 2:14 PM
    Snert
    Snert New Member
    2021 SR5
    Another vote for Deutsch connectors. Used them for the first time on my amp rack disconnects and I'll use them for anything beyond a two wire disconnect moving forward. For two wires I still prefer the marine grade/fully insulated spade terminals since they're quick and cheap, but for a bunch of wires Deutsch is the way to go imo.
    SnrDisregardo[OP] and 1lowlife like this.
