  1. Jan 13, 2025 at 12:45 PM
    It would appear there are two part numbers for 2004 DC Limited, depending whether you have off-road package; I don't know what the difference is. The EPC shows the parts below come a piece of hardware that looks (in the image, to me) like a clevis and pin.
    This is for rearward strap part, note what I've underlined
    And the strap closest to cab, see the same notes, without underline:
  2. Jan 13, 2025 at 1:00 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Looking up the two part numbers on Ourisman, instead of it mentioning OFF-ROAD or not, it lists one for 2wd and the other for 4wd in the description. However the 2wd part number is discontinued.
  3. Jan 13, 2025 at 2:31 PM
    See in the parts info, where one part says UCK this and VCK that, like "VCK30" and the other says "VCK40"? Here's what those mean, note the corresponding info in the left quadrant (see image below).
    The top part number is valid for any truck chassis starting "UCK3" and the VCK30.
    The bottom part number is valid for any truck chassis starting "UCK4" and "VCK40" and even some "UCK3" trucks (I'm assuming ones with TRD offroad pkg on the latter)
    It does indeed appear DC w/2WD is UCK31 and DC w/4WD is UCK41 so yes, in your year, the correct part is likely the 2nd one, regardless. I believe you can confirm your chassis by looking at the door jamb sticker, driver's side. If it says UCK41, the 2nd part numbers are yours.
    If you PM me your VIN#, I can try to check it out for you, your call.
  4. Jan 13, 2025 at 2:41 PM
    And for example, here's the chassis info on that door sticker. Your sticker may look a bit different but will have same info on it, maybe in different positions.
    C/TR is your body color (C) and trim color (TR), in my case 056 (natural white) for body, and FB12 (charcoal/MD grey) for trim
    A/TM is your gearing type and ratio (A03B, a 3.91 LSD) and transmission (A750F, a 5spd auto)
    oscardog86 and des2mtn like this.
  5. Jan 13, 2025 at 4:01 PM
    Hmmm, sounds like that's a permanent solution then.
    NUDRAT likes this.
  6. Jan 13, 2025 at 4:36 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Car wash
    BTW, the 5100s in the rear pair really nicely with the 2885s up front. I didn’t expect to notice as big of a difference as I did.
  7. Jan 13, 2025 at 5:06 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    If we had salt I’d definitely be doing the same.
    I've been toying with the idea for orange LED's in the gauges to match the 1G taco and now you've sold me.
  8. Jan 13, 2025 at 6:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Next time you're out this way, let's hit up some junkyards.
  9. Jan 14, 2025 at 1:41 PM
    The Black Mamba
    DFW
    Imma keep it stock
    I commandeered a back seat all weather mat from a Turd Gen Crew Max. It fits OK. I really like it for the price of $0.
    NUDRAT, khooiii, des2mtn and 7 others like this.
  10. Jan 14, 2025 at 1:57 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    I'll give you double!
  11. Jan 14, 2025 at 3:20 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Good job on the mat! I'll probably order Weathertech on that note.....come to think of it, better do that now since they seem to enjoy cancelling whatever they have that fits my old vehicles.
    *Just ordered set of front and rear floor mats for the Tundra. WeatherTech brand.*
    The Black Mamba likes this.
  12. Jan 14, 2025 at 4:08 PM
    Neo
    Neo New Member
    Alabama
    Managed to finish routing the microphone cable for the new head unit.
    Also snagged this hitch insert at an estate sale for $7.50.
    NUDRAT, Hutcheson, RealTruck and 8 others like this.
  13. Jan 14, 2025 at 4:10 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Nice score.
  14. Jan 14, 2025 at 5:49 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Unfortunately, to my knowledge, weather tech does not offer anything for the rear floor of the access cab. If I’m wrong, I trust that I will be corrected so that I too may order
  15. Jan 14, 2025 at 7:16 PM
    I got one for my AC. I was also disappointed by the fitment. I wrote a big hoopla on here about it. But I think for some reason it only showed as compatible for 2005-2006 AC. Maybe I’m remembering wrong though.
  16. Jan 14, 2025 at 8:57 PM
    Methodical
    Methodical New Member
    Maryland
    2006 Tundra SR5 DC TRD 4x4
    It's even smiling at us?
  17. Jan 14, 2025 at 9:02 PM
    Methodical
    Maryland
    Use both.
  18. Jan 14, 2025 at 9:03 PM
    Methodical
    Maryland
    Handy like duct tape.
  19. Jan 15, 2025 at 6:07 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Power steering flush
    RealTruck, khooiii, bmf4069 and 6 others like this.
  20. Jan 15, 2025 at 6:10 AM
    The Black Mamba
    DFW
    Imma keep it stock
    At the time I bought my front set, (10 years ago) I don’t remember anything offered for the 00. Now that you mention it, I do remember your rant about it. It makes me even happier with the five finger discount I got on this one
    bmf4069 likes this.
  21. Jan 15, 2025 at 6:29 AM
    From a shop local(ish) to you, this is the mat I bought: https://truckaccessorystore.com/weathertech-440442-rear-floorliner-black
    440442 is the model number for AC. I had to trim my mat to make it work with my power seats. Others had to trim to make it work with slider seats. I don't know why WT says their mat won't fit in the earlier year AC trucks; I'm not aware of any monumental differences in the rear floorboard from 00-06. Still, worth mentioning you may be in guinnea pig territory if you choose to accept the challenge of taking one for the team.
  22. Jan 15, 2025 at 6:53 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    https://youtu.be/21Cqazgk13M?si=V8UvIuKEli_dXa_H
  23. Jan 15, 2025 at 6:55 AM
    Outbound
    Aaron
    Northern Alberta
    I made some adjustents to my Thule TracRac so it worked better with my tonneau. Then I began fighting with my tailgate latch. It's stick and I have to yank on it to open. No dice though. Gotta figure that out.
    RealTruck likes this.
  24. Jan 15, 2025 at 6:57 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You try pushing on the tail gate then using the latch? Maybe the tonneau is putting stress on it
    CodyP likes this.
  25. Jan 15, 2025 at 6:58 AM
    bmf4069 and The Black Mamba like this.
  26. Jan 15, 2025 at 7:01 AM
    Fragman
    Fragman New Member
    Sounds to me like they think the DC is the 2005-2006 version of the AC? Maybe?
  27. Jan 15, 2025 at 7:29 AM
    Outbound
    Aaron
    Northern Alberta
    Tonneau isn't causing issues. I have to yank the
    tailgate back and forth to get it to release. The rods aren't fully disengaging the latches.
  28. Jan 15, 2025 at 7:29 AM
    Outbound
    Aaron
    Northern Alberta
  29. Jan 15, 2025 at 7:31 AM
    The Black Mamba
    DFW
    Imma keep it stock
    shifty`[QUOTED] likes this.
  30. Jan 15, 2025 at 11:07 AM
    I have to lift my latch all the way. Like, 105% up to get mine to open. Cheap ass RA handle.
    Outbound[QUOTED] likes this.
