Solution for accidently opening tailgate from key fob
Discussion in '3rd Gen Tundras (2022+)' started by SR72, Jan 5, 2025.
  1. Jan 5, 2025 at 2:24 PM
    SR72
    SR72 [OP] New Member
    Devin
    2025 Tundra TRD Rally Ice Cap White
    OEM tonneau cover, door edge guards, all-weather mats and spray on bed liner.
    I put my fob inside a waterproof case. It is meant for a Samsung smartag2 but works perfectly with some trimming around the chip and battery. I was sick of accidentally hitting the tailgate release with the fob inside my pocket. The case doesn't have any buttons so nothing can be pressed (I use proximity and the app on my phone/watch to lock, unlock and remote start my truck anyways).
    I hid the metal key under my truck in case the battery dies as the key doesn't fit inside the case. As an added bonus, the case is now a little smaller than the factory fob. Also, it has screws to hold it together so it shouldn't bust into pieces if you drop it. For $10, it's a cool mod and the waterproofing is good insurance if someone pushes you into the pool or you drop them at the lake or beach (several other scenarios of course).
    https://www.amazon.com/gp/aw/d/B0CST23K7Y?ref=ppx_pop_mob_b_asin_title
    22whatwedo and 1lowlife like this.
  2. Jan 5, 2025 at 2:37 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
  3. Jan 5, 2025 at 2:42 PM
    SR72
    Devin
    1lowlife likes this.
  4. Jan 7, 2025 at 4:11 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    Let's see what you had to do to the actual insert to make it fit.
  5. Jan 8, 2025 at 3:31 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    1lowlife and Hella Krusty like this.
  6. Jan 8, 2025 at 4:25 PM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    I took the fob apart used an exacto knife and shaved off the tail gate knob.
    It's a convenient option I personally think it's pretty damn cool,but it doesn't serve a function for my needs,honesty I'm in fear of it accidentally opening on someone's front end,a wall my garage ect...
  7. Jan 9, 2025 at 8:16 AM
    extremes074
    extremes074 New Member
    West Coast, Florida
    22 1794 TRD Off-Road
    Had the dealer disable this feature a while back.
  8. Jan 9, 2025 at 8:36 AM
    tronz151
    tronz151 New Member
    2024 Tundra Platinum
    You can also have the dealer change the setting to double press. I have had no issues since with accidental opening. The setting can also be changed with TechStream or any other similar OBDII device.
    Hella Krusty likes this.
  9. Jan 9, 2025 at 10:17 AM
    wayne73
    wayne73 New Member
    Wayne
    Minnesota
    2022 limited crewmax trd offroad
    I am going to have to have the dealer disable this feature from my remote. I am paranoid as well, when;
    • my truck is in the garage either against the wall or against the garage door
    • I have a short tongue trailer and the jack would crash into the tailgate
    • I have my bike rack installed in my hitch
    Not sure why they don't have a selection on the dash or in the menus somewhere to disable.
  10. Jan 9, 2025 at 11:44 AM
    Hella Krusty
    Hella Krusty New Member
    Because they cant charge you the per hour rate if you do it
  11. Jan 9, 2025 at 12:18 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I, too, have a few trailers that would cause damage if the tailgate was accidentally opened.
    I don't recall, does Carista allow you to disable the FOB button?
  12. Jan 9, 2025 at 12:23 PM
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    I don't think Carista does it.
  13. Jan 9, 2025 at 4:44 PM
    Hella Krusty
  14. Jan 9, 2025 at 5:16 PM
    DRP
    DRP Old Member
    Dave
  15. Jan 9, 2025 at 9:51 PM
    Bigbadpoppa
    Bigbadpoppa New Member
    Just change the settings and turn it off or double click like others had said, vs fumbling with a case etc...
    Dealerships will do this for free if you are nice as part of servicing for your next oil change.
  16. Jan 10, 2025 at 7:28 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Enlighten us on the similar OBDII devices that poses the ability to adjust this setting outside of techstream.... or were you just ass-u-me-ing
  17. Jan 12, 2025 at 3:19 PM
    SR72
    Devin
    A picture of the inside as requested. It's very snug and doesn't rattle at all. You can see the red o-ring on the inside to provide the waterproof protection. I've pressed down on the case very hard and none of the buttons get pressed. It's been a great solution so far.
  18. Jan 12, 2025 at 3:23 PM
    SR72
    Devin
    Here is a size comparison as well
  19. Jan 12, 2025 at 3:32 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Seems like a solution looking for a problem to me.
    I think I'll just have the dealership disable the tailgate button on my FOBs, and call it a day.
    Glad it's working for you, though.
  20. Jan 12, 2025 at 5:04 PM
    jctmundra
    Northern VT
    Where is the spare key?
  21. Jan 12, 2025 at 5:10 PM
    SR72
    Devin
    I did a hide-a-key under my truck.
  22. Jan 12, 2025 at 6:03 PM
    Rockpig
    08 Limited
    Thanks, for some reason I thought it was considerably smaller that the original fob. I've personally never had a concern that I would hit the tailgate button, before I even took delivery of my truck I bought this fob cover from Amazon.
    https://www.amazon.com/gp/product/B0CL2HS2L1?ie=UTF8&th=1
    It's a tough push to get the buttons to react so I don't have any concern of accidentally releasing the tailgate.
  23. Jan 12, 2025 at 6:10 PM
    Tidechaser
    Tidechaser New Member
    Paul
    GLOUCESTER Va & Virginia Beach
    2022 Tundra TRD Off Road (Lunar)
    DRP[QUOTED] likes this.
  24. Jan 13, 2025 at 12:09 AM
    tronz151
    tronz151 New Member
    I have a XTool D8BT scan tool that works great and allows all the same settings that TechStream offers.
  25. Jan 17, 2025 at 6:32 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    These are the feature settings I had the dealer adjust at delivery.
