  1. Jan 12, 2025 at 2:54 PM
    @shifty` This might be worthy of adding to the mega thread for easy access. Great find @Neo.
    shifty`, BroHon and Voss like this.
  2. Jan 12, 2025 at 3:20 PM
    Azblue
    The Dirty T ( ^_^)_且
    Which place did you go to get it?
  3. Jan 12, 2025 at 4:20 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    A cord is a stack 4 x 4 x 8 feet. 128 cubic feet.
    A dry cord of oak is roughly 2800 lbs as a min.. Green is over 4000 lbs.
    So, not in my bed please.
  4. Jan 12, 2025 at 4:32 PM
    Some dude off market place
    Voss and Azblue[QUOTED] like this.
  5. Jan 12, 2025 at 4:36 PM
    My man just created a new band, the Oak Rich Boys. :rofl:
  6. Jan 12, 2025 at 4:47 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Thanks. This one has really had me by the balls.
  7. Jan 12, 2025 at 4:50 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    We love Sue around here.
  8. Jan 12, 2025 at 5:01 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    So it'll sit a little low. :)
    You have to know someone probably tried it!
    tpope[QUOTED] and Voss like this.
  9. Jan 12, 2025 at 5:11 PM
    Funny, I didn’t see a video on how to use common sense. Half of those videos could be eliminated with a video describing common sense.
  10. Jan 12, 2025 at 5:40 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Injen made an actual CAI for the 1st gen Scion xB. People would install them, and upon splashing through a deep puddle (not a flooded puddle, just a deep puddle) the intake would vacuum up water and hydro lock the engine. After reading multiple reports on that problem, i swapped back to the stock airbox on my xB.
  11. Jan 12, 2025 at 5:46 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    My truck came with NO fender liners. For a while I removed the inlet pipe and covered over the hole into the fender so it wouldn't suck in debris and water. Then I made my own liners with a couple big ass tree pots. They have held up like a boss so far, 3 yrs.
  12. Jan 12, 2025 at 5:46 PM
    whodatschrome
    lots of dents
    Well, it is a vacuum, and snow likes to build up right on top of the cowl vents. Water (deep mud puddles) also likes to splash up over the hood and cascade back down the windshield and into the cowl vent. I doubt it would ever be an issue. Just clean all the snow off the hood and vent areas, and don't go bombing though any standing water.
  13. Jan 12, 2025 at 5:53 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    When you're too drunk to get the mileage from the right vehicle. what is this cluster from???
    Voss likes this.
  14. Jan 12, 2025 at 6:01 PM
    des2mtn
    SW
    Tonto cover
    2003-2005 Dodge Caravan
  15. Jan 12, 2025 at 7:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's it? :boink::p
    This mix of oak and pecan was collect around my hood after Hurricane Beryl
    Gave most of this to Casey.
  16. Jan 12, 2025 at 7:42 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Idk if you have an an actual filter tucked in there, but you could put a pre filter sock over the inlet just for peace of mind.
  17. Jan 12, 2025 at 7:50 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's what I did for my Volant because the PO removed the liners and had a shitty hot air intake. The passenger tire was pitching road debris right at the filter. Volant has an air box, but it was extra piece of mind to add the pre filter sock, since the liner is gone and the opening to the air box is bigger than stock air box opening
    Voss likes this.
  18. Jan 12, 2025 at 8:09 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I keep wanting to buy a volant cai just to eke out an easy hp or two when towing. Is it even worth it?
  19. Jan 12, 2025 at 8:18 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Hard to say because I was replacing a no name hot air intake the PO had installed. I know this one is a little quieter and gives me piece of mind because of the air box. I'm a fan of an air box with smooth tube style intake. Also keeps the intake temp lower than the hot air intake did, according to my scanguage.
    Now I think my Volant is great paired with long tube headers and a tune. This truck scoots compared to when I bought it with just the hot air intake and TRD exhaust.
    But I've also got the DD 12 hole injectors and ditched the 3.91 gears for 4.10 gears from a Sequoia.
    I don't think an intake alone is going to make much difference.
    I think you'd be better off regearing. It's more expensive, but not that much more than long tube headers, and will likely help more with towing.
    However for the cost of a Volant or maybe less, you can get your truck tuned. That would likely also be more helpful than an intake for towing.
    CodyP[QUOTED] and Voss like this.
  20. Jan 12, 2025 at 8:45 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Yeah all my firewood this winter is from a red oak down the street. Free workout splitting it all. And free wood to burn. Circle of life.
  21. Jan 13, 2025 at 5:26 AM
    This is necessary
    This is necessary
    Life feeds on life feeds on life feeds on life feeds on ...
  22. Jan 13, 2025 at 6:00 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've been getting my batteries from Walmart lately. A 24f is about $135 or so. 3 year warranty isnt terrible I guess. Parts store batteries have gotten ridiculous. When the 7 year old battery in my truck dies I'll probably find a nice 27f to replace it with, may be a bit harder to find for a good price.
    Here's the best TITS I have to offer. They salt the hell out of the roads here so it stays put right in the driveway during snow times.
  23. Jan 13, 2025 at 7:06 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Have been using the Costco Interstate in multiple vehicles.
    txagg, BroHon and NickB_01TRD[QUOTED] like this.
  24. Jan 13, 2025 at 7:18 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm still going to try it.
  25. Jan 13, 2025 at 8:27 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, i’ll try it, but i’m already disappointed.
    shifty`, bmf4069 and Voss like this.
  26. Jan 13, 2025 at 1:55 PM
    With the higher voltage and stronger starts of the new battery and alternator, I wish I got a new alternator a few years back. A new battery never was as good at keeping a charge with all the short trips I make.
    I guess the real test is whether the alternator still does a good job of charging when it drops down to single digits.
    shifty` likes this.
  27. Jan 13, 2025 at 4:23 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Shifty or anyone know the correct Toyota part number for radiator for 2006 doublecab 4.7 2wd? Site shows two but does not specify if they are both compatible or not. Thanks for any help.
  28. Jan 13, 2025 at 4:57 PM
    www.densoautoparts.com
  29. Jan 13, 2025 at 5:00 PM
    KTM_AJ421 and FrenchToasty like this.
  30. Jan 13, 2025 at 5:13 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
