Cracked my oil filter need part #
Discussion in '2.5 Gen Tundras (2014-2021)' started by SoCal_Tundra21, Jan 12, 2025.
  1. Jan 12, 2025 at 8:01 AM
    SoCal_Tundra21
    SoCal_Tundra21 [OP] New Member
    The previous owner must have over torqued it. I had to use a impact gun to take it off. Didn't realize I cracked till I finish.
    Anyone know the part number for this? It's a 2021 SR5. Need to get the truck running by tomorrow for work
  2. Jan 12, 2025 at 8:07 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    ATV25 likes this.
  3. Jan 12, 2025 at 8:14 AM
    SoCal_Tundra21
  4. Jan 12, 2025 at 8:14 AM
    Tundra family
    Tundra family New Member
    If it's consolation I've done it as well. 15620
    The aluminum one I had leaked like a siv and I went back to plastic. Just a heads up
    Philogynist likes this.
  5. Jan 13, 2025 at 5:20 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Might have positioned the O ring incorrectly
  6. Jan 13, 2025 at 6:06 AM
    seydou
    seydou Distinguished Member
    What ft/lbs did you torque it to when you reinstalled?
  7. Jan 13, 2025 at 6:49 AM
    BowChicka
    BowChicka New Member
    25lbs for oil filter housing and 9lbs for the oil filter housing drain plug.
  8. Jan 13, 2025 at 6:55 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    25lb-ft is not correct. I think you mixed up the units.
    Spec is 18lb-ft (which is 25Nm) for the housing.
  9. Jan 13, 2025 at 6:56 AM
    BowChicka
    Thanks for the correction, I will update my notes
    pman9003[QUOTED] likes this.
  10. Jan 13, 2025 at 7:05 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  11. Jan 13, 2025 at 4:05 PM
    SoCal_Tundra21
  12. Jan 14, 2025 at 7:01 AM
    Jeffninjaslayer
    Jeffninjaslayer I37 butterfly murderer
    2014 black dc
    2014 SR5 DC BAKFlip Revolver X4S 2019 TRD LED headlights Swing Case Interior LED upgrade Color match TRD grille and hood bulge Rigid fog lights 3 1/2" lift Toyota bed rail
    Busted one of the teeth off the housing. I didn't think anything of it until I started the truck up and oil went spraying everywhere. :annoyed:
  13. Jan 14, 2025 at 7:21 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    SoCal_Tundra21[OP] and blackoutt like this.
  14. Jan 14, 2025 at 7:23 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Local parts store will carry the aluminum Dorman one. I've seen those leak from the get go due to bad tolerances. Avoid them.
    If you're in a pinch, go pay the dealer for a replacement plastic. Or pay the dealer mark up for the OEM aluminum one. They'll say it won't fit your 5.7. Buy it and swap the inner tube.
    SoCal_Tundra21[OP] likes this.
  15. Jan 14, 2025 at 7:25 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    I vote OEM aluminum if time permits. I swapped mine out recently and haven’t had any issues.
  16. Jan 14, 2025 at 7:34 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    15260-31060
    Jeffninjaslayer likes this.
  17. Jan 14, 2025 at 8:18 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  18. Jan 14, 2025 at 8:23 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  19. Jan 14, 2025 at 10:10 AM
    AZBoatHauler
    So.Arizona
    :eek2:
  20. Jan 14, 2025 at 11:11 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Torqueing plug is some serious OCD. Just snug it up. I don't torque either 1.
  21. Jan 14, 2025 at 12:26 PM
    BowChicka
  22. Jan 14, 2025 at 12:28 PM
    BowChicka
    I also don't torque either one, I just had those numbers in my notes, and one of them was wrong apparently.
  23. Jan 14, 2025 at 12:31 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    And keep your eyes peeled for the rare Jowett engine oil filter cap. :yes:
    sudobash and SoCal_Tundra21[OP] like this.
