Please help! TRD Pro grill
Discussion in '3rd Gen Tundras (2022+)' started by typk33, Jan 11, 2025.
  1. Jan 11, 2025 at 7:09 PM
    typk33
    typk33 [OP] New Member
    Tyler
    2024 Lunar Rock SR5
    TRD factory 3" lift
    Just purchased a TRD Pro grill and switch for my 24 SR5. I've done lighting in the past for my jeep but it was simple setups. What am I missing here? Clearly the cord for the lightbar isn't long enough and wiring doesn't line up. Any help will be greatly appreciated as I'm starting the swap in the morning!
    Thank you!
  2. Jan 12, 2025 at 7:04 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    Hard to say without wiring diagram for this specific switch but, your switch should be red to power (on/off) white and black tied together and grounded (ground) green completes circuit and yellow ties into illumination (I used brown wire on existing truck switch). You want to run a relay and a fuse from battery.
    typk33[OP] likes this.
  3. Jan 12, 2025 at 7:11 AM
    lapoolboy
    lapoolboy New Member
    Is that the Rave light bar? It looks like you are missing the relay harness.
  4. Jan 12, 2025 at 7:36 AM
    Hammertimerrrr
    Hammertimerrrr New Member
    2024 MGM Limited OR
    Mine was missing a harness as well. Contacted Rave - they quickly responded and are sending the missing harness that will connect the switch to the fuse relay and o-terminal ground.
  5. Jan 12, 2025 at 7:37 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
  6. Jan 12, 2025 at 9:41 AM
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Where did you buy it?
  7. Jan 12, 2025 at 3:10 PM
    typk33
    Tyler
    2024 Lunar Rock SR5
    TRD factory 3" lift
    No, got it from Amazon
  8. Jan 12, 2025 at 3:11 PM
    typk33
    Tyler
    2024 Lunar Rock SR5
    TRD factory 3" lift
    Amazon
  9. Jan 12, 2025 at 3:11 PM
    typk33
    Tyler
    2024 Lunar Rock SR5
    TRD factory 3" lift
    Do you know if they sell that separately?
  10. Jan 12, 2025 at 3:12 PM
    typk33
    Tyler
    2024 Lunar Rock SR5
    TRD factory 3" lift
