Garage Ventilation Input
Discussion in 'Home Improvement' started by Dsptundra, Oct 7, 2024.
  1. Oct 7, 2024 at 5:47 PM
    Dsptundra
    Dsptundra [OP] Still a new member...
    Austin TX Area
    2021 Silver Limited CM
    Looking for input and advice on how to approach the current challenge with my garage temperatures.
    Facts:
    Three car garage.
    Doors face south, painted dark brown.
    All walls full insulated.
    Close to two thirds of ceiling is insulated as there are rooms above.
    Remaining third of ceiling not insulated, just open to roof framing.
    Only ventilation for “attic” space is soffit vents.
    It’s hot in Texas so I thought insulating the walls would help but the temps still quickly climb to higher than outside. Trying to find ways to make it more comfortable short of installing a split system.
    Add insulation to the garage doors?
    Insulate the remaining ceiling?
    Add solar powered vent to the roof to draw air out of the attic space?
    I already have two 18” fans hanging on the ceiling to move air but hoping to do more. Any advice welcome including just throwing down the cash for a split system.
  2. Oct 7, 2024 at 5:53 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Why does the garage need to be climate controlled?
  3. Oct 7, 2024 at 5:54 PM
    Dsptundra
    Austin TX Area
    Not looking for full climate control just knock it down so it is more comfortable as I have a home gym in the third bay and like to work at my workbench in something less than 100 degrees.
  4. Oct 7, 2024 at 5:58 PM
    Danman34
    Danman34 New Member
    Danny
    There’s no real way to induce a draft unless you open a window, if there is one, and put in some type of attic fan, or some other means of pulling negative air. But you don’t want the garage air in your attic either, so it need to be pumped directly to the exterior. A mini split is probably the most effective way to keep temps somewhat regulated when you want it to be.
  5. Oct 7, 2024 at 6:07 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Swamp cooler works well during low humidity periods
  6. Oct 7, 2024 at 6:28 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    I just might have the answer :monocle:...
    This past summer I also suffered from my garage temps being ridiculously high and unbearable so I did some research and found something that I 100% want to do to my garage that has zero insulation. I installed a wall mounted fan up high but quickly found that all it's doing is pushing all of the hot air downward so that was pointless.
    The answer could possibly be this...
    https://www.amazon.com/dp/B07T81RKH8
    They come in different sizes and are available at Home Depot. Research them and you'll see that you can program it to automatically turn on when it reaches a certain temp. Installation should be in a high location where all of the hot air is.
    Hope this helps and if you do go this route, please keep us updated :thumbsup:
    WAtundra4x4 likes this.
  7. Oct 7, 2024 at 6:29 PM
    JRS
    JRS New Member
    2012 DCLB
    Same boat here. As I was insulating my 3 bay, it was somewhat noticeable as I finished roof sections. You might as well finish that off and put a small vent fan... I haven't put up any drywall yet, because I'm still debating if I want that for the walls, but that'll certainly help since the insulation doesn't cut it on its own.
    Also, search for a HVAC unit someone has replaced. I picked up an old packaged 3 ton for I think $200. Spent more on a run of 25' flex duct and 15" flex line.
    Dsptundra[OP] likes this.
  8. Oct 7, 2024 at 6:30 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Attic fan for the win. Makes a HUGE difference - and can hook up to a thermostat to automatically turn on at a certain temperature
  9. Oct 7, 2024 at 6:56 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Attic fan and the best insulation you can get for that exposed roof, the doors, and blinds/shades for the windows.
    If $$ is no object, roof vent, insulation, solar, proper HVAC.
    nobodyintexas and Dsptundra[OP] like this.
  10. Jan 5, 2025 at 1:07 AM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    Farmers Branch , Texas
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    You would still want air being pumped in. Helper vent the air out. Also be sure no air is leaking from the inside of the house to the garage. Also, would be ideal to place the fan at the outside of the house and add a damper in the ducts. Don't want hot air to come back into the garage.
  11. Jan 5, 2025 at 1:50 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    If you are only wanting to make it a bit more bearable for a couple hours while you work out - I would try a mister fan first (there are some really powerful batt ones you can take along other places for multi-uses) - they really cool the air about 15 degrees and feels oh so much better. If that is not enough then I suggest a small mini-split. Luck and enjoy the workouts.
  12. Jan 5, 2025 at 2:06 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    For me, this thing was an absolute game changer...
    https://www.homedepot.com/p/Bonaire...ative-Cooler-for-1900-sq-ft-6280035/303666271
    I used one on my kennel building in Vegas, and I swear there were days I'd go sit in the kennel cuz it was nicer than it was in the house....
    So, a bit different than a traditional swamp cooler in the fact that it works off a box fan design, which also means you're not dealing w/the fan belt, squirel cage, weight and bulk of the exterior cabinet, etc... this was also less expensive (in terms of electricity to run)... Maintenance and down time was about an 1/8 of a traditional swamper for me w/this unit; pad replacement and corrosion is much less frequent than tradtional swamper too
    Plus if humidity climbs too much during the summer or if you're just looking to move stale air during the winter, you can just run the fan only and OMG this thing moves some air for minimal cost. The couple of times we'd hit freezing there, I'd turn on a little space heater and set the fan on this to low and it was perfect for moving air around.
    So, apparently this brand was originally designed/used for cooling homes in Australia and has been around for a really long time....
    nobodyintexas likes this.
  13. Jan 5, 2025 at 2:23 AM
    Frank_TRD23
    Frank
    O yes, Humidity. I had to add a gable fan in my attic. This was due to the shitty install of my a/c handle in my attic. Had/have air leaks from the unit and on summer days, the thing would sweat. So, I had to help draw some heat and humidity out of the attic.
  14. Jan 5, 2025 at 3:17 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    South Houston Swamp area
    detached garage - unfinished
    home gym in 3rd bay
    I put in a whirly bird, at top of roof peak to pull the hot air out....then I mounted a vornado fan just under the whirly bird to accelerate the air pull.
    it makes a remarkable diff.
    We use swamp fans during the Africa season.
    we have a total of 7 fans during summer workout.
    and the ambient is still 95'.
    unless you enclose & insulate the area, you are spinning your wheels.
    Dsptundra[QUOTED][OP] likes this.
  15. Jan 11, 2025 at 11:45 AM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    I’m currently having an issue with my tundra start up when warming up inside garage. I normally let it run in the winter about 5-10 mins with remote start and garage door closed. Exhaust is causing a major amount of fumes and condensation. I have a tool box next to my truck and a lot of my tools are starting to rust. I’m looking to find an extractor that can automatically detect to turn on. Any one using something similar for this issue?
  16. Jan 11, 2025 at 12:07 PM
    bflooks
    bflooks New Member
    Metrowest MA
    this made me think of a fire station and older emissions inspection stations/bays. if you google exhaust evacuation or firehouse exhaust extraction, you'll see a bunch of options. i do confess that i don't know more than what my own curiosity just uncovered.
  17. Jan 11, 2025 at 12:49 PM
    Don’t do this. Open the garage door if you start your car.
    Tripleconpanna and Tunrod like this.
  18. Jan 11, 2025 at 6:39 PM
    Tripleconpanna
    Serious reply... You should not be doing this.
    Co2 is lethal in confined space and at best you're exposing yourself and anyone else entering those conditions to elevated blood gas levels. There's a reason FD won't even enter a garage during a suicide attempt or after completion of the act w/o full self contained gear on when a running vehicle is involved...
  19. Jan 11, 2025 at 6:50 PM
    Frank_TRD23
    Frank
    And another reason I have an app for my garage door.
