‘21 platinum OEM bed lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra1209, Jan 11, 2025.
  1. Jan 11, 2025 at 4:17 PM
    Tundra1209
    Tundra1209 [OP] New Member
    Just got my ‘21 platinum back in July and like the look of the OEM bed lights but have no idea where to purchase them. Has anyone installed them and where did you buy them.
  2. Jan 11, 2025 at 4:32 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    I got mine from a south east toyota dealer. Install was straight forward, routing the wires from the cab sucked but wasn't hard.
  3. Jan 11, 2025 at 4:35 PM
    Tundra1209
    Do you happen to have the part number?
  4. Jan 11, 2025 at 4:38 PM
    Why not look at the MattGhecko kit?
    https://mattgeckoleds.com
    Henry1jg likes this.
  5. Jan 11, 2025 at 4:48 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
  6. Jan 12, 2025 at 5:40 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had bed lights in 2 Tacomas. They are pretty much worthless if you have anything in the bed. Tundra has LED bulbs in the cargo light. They light up the bed and area behind the truck. I can skin and quarter a deer with the cargo light on.
    1lowlife likes this.
  7. Jan 12, 2025 at 6:25 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
  8. Jan 12, 2025 at 8:14 AM
    French Avocado
    Utah / Wyo
    This is what I did. I did the two color option With the under hood light as well. Great product.
  9. Jan 12, 2025 at 8:18 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    I'll snap a picture at night, they are pretty good at lighting up bed in addition to led cargo lights. If you're running a cover of any kind the strip lights would probably work better.
    French Avocado likes this.
  10. Jan 12, 2025 at 10:20 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I was just checking out the website. I was looking for an explanation on the website but I didn’t see it, for what is the power source for these kits? Can they be toggled on at any time as in the truck doesn’t have to be on or anything? Just wondering where the power gets hooked up and is it relatively plug and play? Thanks!
  11. Jan 12, 2025 at 11:07 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Most tap off the cargo light circuit..
    That is what the Toyota OEM instructions say as well.
    Here is a thread on an install.
    Installed Toyota Bed Light Kit today. | Toyota Tundra Forum
    The OEM install PDF
    00016-34187inst-20Tundra.pdf
    I initially installed the OEM in my 2014.
    When one of the LEDs petered out a few years later I made my own using LEDs from Amazon.
    Aftermarket strips are a much better option, especially if you have not already drilled or have holes for the OEM corner lights.
    Amazon.com: Xprite White Truck Pickup Bed Light Kit, 24 Led Cargo Rock Lighting Kits w/Switch for Van Off-Road Under Car, Side Marker, Foot Wells, Rail Lights - 8 PCS : Automotive
    Whatever you chose you can tap into the cargo light circuit, they don't raw much power.
    Then you can use the cargo switch to turn them on if the truck isn't running.
    Or they will come open whenever the cargo lights come (unlock and/or opening doors) on depending on your switch setting.
    You could wire them directly to the battery, but I know I'd forget about them they would rain the battery.
    I only put mine on the sides..
    Silver17[QUOTED] likes this.
  12. Jan 12, 2025 at 11:52 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    In my Tacomas I toggled off the cargo light circuit. Lights came on with door open. I tried the strip lights. They did not last long. I switched to 8" IP68 rated marine lights and NPs.
    Silver17 likes this.
  13. Jan 12, 2025 at 12:01 PM
    French Avocado
    Utah / Wyo
    Wired directly to battery with switch in back. @mattgecko will answer any questions. I have a Renegade cover and a BedRug and these lights are fabulous.
  14. Jan 12, 2025 at 4:29 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    I've got the Morimoto 3rd brake light. The bed lights are angled inwards towards the cab. I would have gone with the VLEDS but I got these for 50 dollars. Not disappointed with the output, totally worth it.
  15. Jan 12, 2025 at 5:21 PM
    French Avocado
    Utah / Wyo
    Here are pictures in white and red.
    smokint likes this.
  16. Jan 18, 2025 at 11:16 PM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    Matt Gecko easy to do
    Tigereye and French Avocado like this.
  17. Feb 8, 2025 at 2:18 PM
    SLOWER
    SLOWER New Member
    Can the Gecko ones be wired to come on when the door opens?
  18. Feb 8, 2025 at 3:30 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Any lights you put in the bed can be wired to come on when doors are opened. Just after to know which wire to tap into. On a Tacoma I had I tapped into a wire under the rear door.
