skid plate tips
Discussion in '2.5 Gen Tundras (2014-2021)' started by Firstmark, Jan 10, 2025.
  1. Jan 10, 2025 at 5:25 PM
    Firstmark
    Firstmark [OP] New Member
    Mark
    2017 4x4 5.7 crewcab sr5
    20 inch rims
    FYI. when you change your oil the skid plate reinstall is designed to frustrate the average diyer,
    i use a 5 gallon bucket to hold the plate up while your putting the screws in, instead of the goofy
    balancing act that toyota thinks is ok. 4x4 offroad,may not work for standard heights.
    Tundra1988 likes this.
  2. Jan 10, 2025 at 5:38 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Angle grinder a door for the oil filter if you don't want to spend money on an aftermarket one.
    They do it so you take it to the dealer for oil changes lol
    WILLINH, RobertD and chrispick like this.
  3. Jan 10, 2025 at 5:47 PM
    blenton
    blenton New Member
    Or just use your man-hands and follow my buddy Arnold's advice...
    Just heckling a little.. sort of. We understand your frustrations. haha. But once you do it for the sixth or eleventy-seventh time you will get the hang of it.
    Or resort to other tactics like the spinning wheel of death mentioned by @MadMaxCanon , pretending you have Tourette syndrome so you neighbors ignore all the cussing, or maybe just crying on the shoulder of your good friend Jack Daniels and assuming the fetal position on the garage floor. Personally, I don't drink so I can't tell you how well the latter works, but the former options... well... my neighbors still like me, but for some reason give me an extra large bubble whenever we are in the same vicinity..
  4. Jan 11, 2025 at 9:19 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    I modified mine like shown. Cut two slots and only loosen those two bolts (do not remove). Plate is held in place to remove the rest of the bolts. When replacing, slide plate into position and replace the rest of the bolts. Tighten these two last. Works like a charm!
  5. Jan 11, 2025 at 11:04 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    RCI skid for the win. Before I had it, it wasn't hard to push it up there and zip the bolts on with my M12 ratchet.
    Toyota has been doing this forever. On my T100 with the 5VZ, you either need to pull the skid plate to make less of a mess, or since the thing leaks oil already stuff rags under the filter and pull it from the top (which is what I do).
    CaptRussia253 and OHwendTrd like this.
  6. Jan 11, 2025 at 12:10 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Just get one of the knock off TRD skid plates from Ebay. A bit of pain to get it installed, but then it never has to come off again.
  7. Jan 11, 2025 at 12:16 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    +1 RCI Skid
  8. Jan 11, 2025 at 1:30 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
  9. Jan 11, 2025 at 2:09 PM
    MadMaxCanon
    Rci ftw
    ejes and CaptRussia253 like this.
  10. Jan 14, 2025 at 5:18 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    This is what I did. For anyone thinking about doing this use SS self tappers on door hinges and latch.
    WILLINH[QUOTED] likes this.
  11. Jan 14, 2025 at 3:11 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    easier and cheaper just to cut a door and put on hinges and a latch. plenty of ideas out there from simple to extravagant
  12. Jan 14, 2025 at 3:20 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I say this to my dogs in Arnold's voice at least once a day..:thumbsup:
    To the OP, I just got a TRD skid plate..:eek2:
    But I do like your suggestion.
    I used 5-gallon buckets to hold up my cat shields when I installed them.
  13. Jan 14, 2025 at 3:22 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    RCI. TRD PRO is squeaky.
    ejes likes this.
  14. Jan 14, 2025 at 3:25 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I've got huge rubber washers between the frame, cat shield, and then skid plate.:eek2::cool:
    AZBoatHauler likes this.
  15. Jan 14, 2025 at 3:27 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes. Was thinking the same: do the rubber O-rings to stop wife's TRD PRO Sequoia squeaking. My Tundra's steel RCI skid is silent.
    1lowlife[QUOTED] likes this.
  16. Jan 14, 2025 at 5:18 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    RCI for me too. :thumbsup:
  17. Jan 15, 2025 at 7:10 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Installed my RCI plate over the holiday break. Looking forward to my next oil change with that access door. Still on the fence about a Fumoto valve however for even easier oil changes.
  18. Jan 15, 2025 at 7:29 AM
    2014 Black tundra
    2014 tundra sr5
    I also have the Fumoto valve with the RCI skid plate. It may be a little slower. But I’m usually doing something else while it’s draining. It’s up and out of the way too. I thought I had a pic of oil draining, but can’t find it. IMG_4017.jpg
    Rlachermeier and M3Tundra-JK like this.
  19. Jan 15, 2025 at 7:29 AM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    Best thing I ever did on this truck….
    M3Tundra-JK and WILLINH like this.
  20. Jan 15, 2025 at 7:32 AM
    2014 Black tundra
    2014 tundra sr5
  21. Jan 15, 2025 at 7:56 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Just not having to deal with the initial surge of oil getting all over the passenger tire was enough of a push for me. I wasn't going to do it in this truck because the oil gets changed only once or twice a year, but after two messes I ended up doing it. Stick a piece of tube on it and drain it into jugs, no more pouring oil out of pans.
  22. Jan 15, 2025 at 8:08 AM
    blenton
    blenton New Member
    SAME HERE! My fumoto valve has been installed for the last 7 years or so, without issue. I put them on all my vehicles now. My tundra has CBI skids, my sequoia has RCI. I like the CBI skids better and feel like they have better coverage, but they only come in steel and are HEAVY. But the aluminum RCI skids are sufficient.
  23. Jan 15, 2025 at 11:08 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Installed the Fumoto valve on first oil change. Only issue is if you drain into a 5 qt jug you have to switch jugs at some point. I just hang out under truck and work on pulling the filter.
    Rlachermeier and MadMaxCanon like this.
  24. Jan 15, 2025 at 11:57 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    Not with the radio on.:rimshot:
    Rlachermeier likes this.
  25. Jan 15, 2025 at 12:16 PM
    00h2itr
    00h2itr New Member
    Carolina's
    This is the biggest pro for me. As a DIY, today it goes into my catch pan, and then I put it back into the 5qt/gallon jugs. That process sucks. Going straight to the jugs would be awesome. My hangup I suppose is that what if the Fumoto doesn't close/seal all the way? What if it leaks? It's probably my ignorance likely having never used them in all of these years of DIY on my vehicles but those are my concerns. That said, I also have full RCI skid plates, so the likelihood of it getting bumped off road is probably diminished as well. Perhaps next oil change.
    Jhon[QUOTED] likes this.
  26. Jan 15, 2025 at 12:59 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I have the Talon Garage skid plate.. heavy but worth it . Also using Fumoto valve..
    Talon2006 likes this.
  27. Jan 15, 2025 at 3:25 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    The lever latches into a notch on the valve. Unlocking it takes firm pressure against a spring. As far as leaks, haven't had one yet. In addition to my Tundra, my Subaru and my mom's Subaru have Fumoto valves installed. Mine is coming up on 85k miles, no leaks. My mom's has 60k on it, also no leaks. You might get a few drops of used oil after a change, but that's just residual.
    M3Tundra-JK and AZBoatHauler like this.
  28. Jan 15, 2025 at 7:35 PM
    seydou
    seydou Distinguished Member
    18 bajillion people have used the Fumoto, Stahlbus, Valvomax, EZ oilchange... Virtually all of them without any issue whatsoever. With RCI plates, it is almost impossible to damage.
  29. Jan 16, 2025 at 7:32 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Fine fine fine, so much :gossip: and not a lot of money either. I guess I'll just order one and have it ready for the next oil change.
    Now, last I looked a few months ago, there's a few different Fumoto PN's that fit our trucks. I can't recall the differences, but is there one preferred by the community over others?
  30. Jan 16, 2025 at 7:53 AM
    BrandonL812
    Brandon
    I have the F103SX..
    People have use the F133S. With the short nipple that way they can hook up a hose and direct flow into a container.
    I just let mine drain straight into a catch bucket. Works for me.. the F103SX is swivel.. you can angle it where you want before torque it tight..
