  1. Jan 10, 2025 at 8:10 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Thank you brother
  2. Jan 10, 2025 at 8:24 AM
    As I've said, rear wheel drive doesn't work here when it snows. My eccentric mailman barely made it up our hill. Last year he was rocking some rear chains for a few days.
    bmf4069, Jack McCarthy, Voss and 2 others like this.
  3. Jan 10, 2025 at 8:42 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    What is that walkie? That's an excellent idea. I'll might get one for my dad and I.
    Voss[QUOTED] likes this.
  4. Jan 10, 2025 at 8:54 AM
    Voss
    2003 AC TRD 4x4
  5. Jan 10, 2025 at 8:55 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    This is a Baofeng, they are portable ham radios. They don't transmit with the amount of power as a dedicated ham radio setup. Technically need a ham license to transmit.
    "Walkie-talkies" are generally FRS or GMRS radios and limited to set frequencies/ repeaters. These are the things that are sold in sporting goods stores. FRS doesn't require a license, but GMRS does. GMRS license is much easier to get than ham.
    Newer Baofengs can't access FRS/GMRS frequencies from the factory, but older ones can.
  6. Jan 10, 2025 at 9:32 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  7. Jan 10, 2025 at 9:43 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Here is the table I use when I go camping to find my buddy’s when they are double digit channels
    https://wiki.radioreference.com/index.php/FRS/GMRS_combined_channel_chart
  8. Jan 10, 2025 at 9:46 AM
    des2mtn
    Shady Grove
    Tonto cover
    Those are the FRS and GMRS channels and newer Baofengs are locked out from transmitting over those frequencies. Especially in crowded areas, you're much likely to have other cross traffic and kids messing around on a channel versus a random simplex frequency that can't be accessed by a GMRS/FRS.
    jerryallday[QUOTED] and Voss like this.
  9. Jan 10, 2025 at 10:02 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    If you want a legal walkie talkie that only requires a test free license get a pair of GMRS handhelds.
  10. Jan 10, 2025 at 10:19 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm a huge fan of Costco in general, but the I've had 2 of their interstate batteries die prematurely (different vehicles). Plus the interstate batteries are $125 and 3 year prorated warranty. I bought a Toyota battery from the dealer for $150 with an 8 year warranty. If you have time to wait for the online parts deal, it's $135.
    txagg, khooiii[QUOTED] and Desert Dog like this.
  11. Jan 10, 2025 at 11:11 AM
  12. Jan 10, 2025 at 11:53 AM
    Voss
    2003 AC TRD 4x4
    Some good news. Citizens caught one of the dipshits starting these fires. https://x.com/financelancelot/status/1877555436322263534?s=46
    Woodland Hills is one of 5 or so fires that started after the winds died down.
    Buddy who’s a detective in LA told me yesterday police believe the fires are being started intentionally because “there are way too many far apart to happen naturally.”
  13. Jan 10, 2025 at 11:54 AM
    I did my good deed for the day.
    She was stuck in a drift after sliding and burned a hole in the snow under the tires. Had to pick my box up and had the boy dig the strap out of my cubby. I ended up using the LCA to pull her out. We celebrated with some waffle house.
    I found some "deep" snow.
    Whoever did these donuts is an absolute madlad.
    Then the boy fell down.
    It's about boot deep here.
  14. Jan 10, 2025 at 12:46 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    So starter is next idea?
    The Black Mamba likes this.
  15. Jan 10, 2025 at 1:22 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    I guess if it continues yes, @ 295k I can't be mad at it. But I can still complain, and I will.:rofl:
    It was just 1 hiccup so far, so I'm gonna let it slide. Maybe even until I have to call a tow truck.:cool:
    Teens and twenties temps really put a damper on my motivation to spend hours in my driveway.
    XSP_guy and ToyotaDude[QUOTED] like this.
  16. Jan 10, 2025 at 1:32 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    literally “bringing home the mail”
    bmf4069[QUOTED] and FrenchToasty like this.
  17. Jan 10, 2025 at 1:35 PM
    Sad fail for the once glorious US Mail.
    “come rain, sleet, snow or shine”. Probably due to budget cuts. What is that mail minivan mobile anyway?
  18. Jan 10, 2025 at 1:43 PM
    KO3's did great. I went up my hill in 2WD.
  19. Jan 10, 2025 at 1:51 PM
    whodatschrome
    lots of dents
    It’s definitely a job that i would not want to do in the colder temps.
    Back when i was swapping the two engines between my 2000 and 2004 tundra, i did a little experimenting to see if there was any other way to remove the starter without removing the plenum. If the rear of the engine can be tilted down a smidge, the starter can slip out the back. You have to remove that cast aluminum crossover coolant bracket though (which is quick and easy to do). It’s a tight fit, but i did manage to squeeze it between the firewall and the plenum. That technique would only work if there’s no transmission (or no transmission mount) installed. Simply because the back of the engine wouldn’t be able to be tilted down with either of those items in place.
    If you had a 2” body lift, then the technique might work as well?
    Another option that might possibly work (but i wouldn’t want to test this theory in the dead of winter) is to remove both of the engine mounts and lower the engine down (with a cherry picker of course) a couple inches. Then the starter might be able to be squeezed out through the back. The engine mounts on a tundra can be removed and installed pretty darn easily, but the juice may not be worth the squeeze when compared to removing the plenum? These are just some random thoughts that i’ve been having.
  20. Jan 10, 2025 at 1:52 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    bmf4069, Voss and des2mtn like this.
  21. Jan 10, 2025 at 2:00 PM
    des2mtn
    Shady Grove
    Tonto cover
    I'm currently unaffected but ready to go at a moment's notice. Wind has been pretty bad.
  22. Jan 10, 2025 at 2:00 PM
    Desert Dog
    Yes, I know. Lmk if I can help in any way.
    Voss and des2mtn[QUOTED] like this.
  23. Jan 10, 2025 at 2:02 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    BroHon crushed by transmission, dies in driveway. "What was he doing?" Changing the starter:rofl:
    I'm not really intimidated by it, I've had almost everything BUT that disassembled in there.
    And maybe it will fix an undiscovered leak and drop my idle below 900rpm.
    Mayzle do my valve covers while I'm at it and make it a fkn Fel-Pro party.
  24. Jan 10, 2025 at 2:12 PM
    Desert Dog
    Not a job I'd want to do in the cold. At all. My advice I'd make sure you have every gasket and o-ring necessary. It will make the job go smoother. Some people don't disconnect the coolant crossover at the rear of the block, but I did. It helped facilitate ease of access, and I figured those gaskets needed replaced after 200k anyway. Unless you're @KNABORES and a beast. Lol! I still don't know how he did it with his method.
    Edit: and if you don't have the larger, more powerful starter now, get it. It's actually cheaper than the standard one. Toyota refers to it as part of the 'Cold weather package'.
    whodatschrome and BroHon[QUOTED] like this.
  25. Jan 10, 2025 at 2:17 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Costco battery acquired. Had to pull it and take the wife’s GX to swap it, but at least I got to drive in a little bit. Some kids got their dad’s trucks stuck in a field, but I was hauling ass and having fun so I didn’t stop LOL.
  26. Jan 10, 2025 at 2:19 PM
    Is that a salted road I see you on, @khooiii? :monocle::p
  27. Jan 10, 2025 at 2:20 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I didn't realize all that was involved in replacing the started on the 2UZ. I'm not bragging, but the 5VZ is super simple. I've had it out 3x, changed it once. I don't envy you guys with that job at all.
  28. Jan 10, 2025 at 2:25 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    No salt. This road like most of my area got zero treatment. Just a good ol’ dirt road!
  29. Jan 10, 2025 at 2:28 PM
    Desert Dog
    No, they don't use salt there.
    The 2UZ is kind of laborious, but if one has never done it before, the trick is to have all parts on hand. Just do it all while you're there and be done with it. Having done it once now, I can confidently say I could probably do it in half the time as before now that I know what's involved.
  30. Jan 10, 2025 at 2:36 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Let me tell you about the time I put a new starter in when all I had was a loose ground cable. LOL
