Front Diff Drop?
Discussion in 'Suspension' started by OBXTundra, Oct 11, 2017.
  1. Oct 11, 2017 at 9:06 AM
    OBXTundra
    OBXTundra [OP] Member
    Southeast USA
    2018 Nissan Armada, 4x4
    See attached picture. This is the passenger side mount for the front Diff. The truck already has a 3" spacer lift on the front. Is this diff mount spacer stock or is this a diff drop spacer?
    I am removing the stock coilovers + spacers and replacing with 3" adjustable coilovers. At that time I would install a diff drop, if it hasn't already been done.
    I am just asking for someone to take a look at their diff mounting points on a vehicle that is known for fact to have a diff drop installed.
    Thanks in advance.
  2. Oct 11, 2017 at 9:07 AM
    OBXTundra
    Southeast USA
  3. Oct 11, 2017 at 9:07 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  4. Oct 11, 2017 at 9:11 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    thats a diff drop spacer installed.
    joonbug likes this.
  5. Oct 11, 2017 at 9:13 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I have @BlueBottle truck. I'll take a pic of his setup when I get under if you need.
    BlueBottle likes this.
  6. Oct 11, 2017 at 9:13 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    yeppers. it be dropped.
    dcsleeper408 likes this.
  7. Oct 11, 2017 at 9:21 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Here is my truck with a diff drop up front.
  8. Oct 11, 2017 at 9:28 AM
    blizz86
    blizz86 New Member
    you managed to get the TRD Pro skid installed properly with a diff drop? show me the ways!
  9. Oct 11, 2017 at 9:47 AM
    OBXTundra
    Southeast USA
    Awesome. Thanks for the quick replies. The spacer lift, rear block, and diff drop were done by the previous owner. I'm ordering parts for the front, now I can check diff drop off the list. Thanks again.
  10. Oct 11, 2017 at 9:55 AM
    Cfincke
    San Antonio
    Was not pretty, I have a post about it somewhere. I had to leave out the center 3 bolts, because i had to add spacers on the back end of the TRD skid and have a bull bar mount that acted as a spacer up front. I wanted the pro skid for protection from road debris over the sheet metal skid Toyota provides more than anything else. If you plan on wheeling where there is rock or you would be putting a lot of the trucks weight on the skid, I would recommend looking into the RDI skid plate system. @Sean266 has the full RDI system with diff drop and can install all the bolts.
    T-Rex266 likes this.
