2017 Tundra Blowing Dome Light Fuse
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stonefly13, Jan 7, 2025.
  1. Jan 7, 2025 at 7:30 PM
    Stonefly13
    Stonefly13 [OP] New Member
    Hello Friends-
    My 2017 Tundra keeps blowing the 7.5 Amp Dome Light fuse. I can usually make it a day or two before it blows after replacing. Any suggestions on troubleshooting? I have not changed anything with the wiring and all interior bulbs are original.
  2. Jan 8, 2025 at 6:35 PM
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    Have you checked the voltage through it with a multimeter? Any chance a wire in the area is lose and grounding out?
  3. Jan 8, 2025 at 7:38 PM
    Stonefly13
    Thanks for the advice. I have not. Should I start looking for loose wires at the interior light fixtures?
