General Supercharger Thread
  1. Jan 7, 2025 at 9:05 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Maybe it's like saying you do sprints when really you go jogging and sometimes sprint. If you go up against someone that actually sprints you get railed, but you both are into running, you just run a lot slower :D
  2. Jan 7, 2025 at 9:08 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Blue line is a smoothed out boost reading like you would see on the gauge, yellow line is the raw data from the prolink, which refreshes 12x a second or something like that. Just to illustrate how much it jumps around
    edit: this is over less than a second
  3. Jan 7, 2025 at 9:10 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    What supercharger are you running? What size pulley? And what elevation?
  4. Jan 7, 2025 at 9:11 AM
    helidave
    flagstaff
    2015 DC 4x4
    mag 2650, 76mm, 7000'
  5. Jan 7, 2025 at 9:12 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    The 7000’ explains why the numbers are so low but you’d think it would raise as rpm climb.
    e30cabrio likes this.
  6. Jan 7, 2025 at 9:12 AM
    snivilous
    SW UT
    Got a 65mm with your name on it Dave :D
  7. Jan 7, 2025 at 9:13 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Boost should move with RPM, so that might explain the spikes if they line up with RPM
  8. Jan 7, 2025 at 9:14 AM
    snivilous
    SW UT
    The supercharger spins a fixed amount relative to the crank (crank pulley divided by supercharger pulley). Even at higher rpm the ratio is the same, so the airflow is roughly the same. The difference in pressure at varying rpms is a byproduct of efficiency changes from the aerodynamics as the rotor speed changes.
    Abell207[QUOTED] likes this.
  9. Jan 7, 2025 at 9:14 AM
    helidave
    flagstaff
    2015 DC 4x4
    I bet that would be a lot of fun until I went down to Phoenix and blew the transmission to pieces :nuclear:
  10. Jan 7, 2025 at 9:15 AM
    snivilous
    SW UT
    Good thing it's only 4 bolts to change it around!
    HulkSmurf14 and helidave[QUOTED] like this.
  11. Jan 7, 2025 at 9:21 AM
    helidave
    flagstaff
    2015 DC 4x4
    What i really need is the 65 and that smoothboost controller. Then I wouldnt have to change any bolts
  12. Jan 7, 2025 at 2:11 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Think we need to add air filter part numbers to the first page
  13. Jan 7, 2025 at 2:34 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Well unfortunately I bumped Silver out of the #3 spot today haha!
    First run with new transmission. Was 10.3psi. Flat farm road. Had on 35” studded tires which likely didn’t help lol.
  14. Jan 7, 2025 at 2:38 PM
    snivilous
    SW UT
    That's nasty! I need to try and claim 4th spot, this shit of .01s being back two places :mad: might have to drive to Nevada just to get that thiccq air
  15. Jan 7, 2025 at 2:55 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    thays odd because im at 7k and my analog gauge shows a lot higher than his. i also have the 2650 and 75mm
    HulkSmurf14 and Abell207[QUOTED] like this.
  16. Jan 7, 2025 at 2:55 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  17. Jan 7, 2025 at 4:48 PM
    blenton
    blenton New Member
    When I installed my SC, I was under the impression that boost increased with RPM, but looking at my boost curve, it was essentially flat. I was perplexed and asked around, including asking Whipple if that was an issue. But after a few exchanges, I was made to understand that positive displacement blowers operate as @snivilous explains - a fixed amount of air is captured with each rotation of the supercharger so it becomes a fixed ratio between crank and blower. Changing a pulley changes that ratio and creates more boost, but a good flowing engine should see roughly the same boost throughout the RPM range with a PD blower. I assume…
    Looking at changes folks have made to intakes, exhausts, and tunes, I’m left to surmise three things about boost:
    - a good flowing exhaust and intake will enable a flat boost curve;
    - a poor flowing (I.e. - inadequately sized or restrictive) exhaust will increase boost pressure with RPM simply as a measure of restriction pressure and not power potential;
    - a poor flowing intake will decrease boost with RPM as you run out of air, causing that fixed ratio to droop at the top end.
    Concerning tuning, I suppose there are several things that could affect boost fluctuations, but I think two of the most significant things would be VVT adjustment and timing. Having valves open too early/late/long would cause disruption in flow, poor exhaust pulse timing, etc. More timing typically makes more power until it doesn’t; flirting with that line should yield optimal power which should equate to optimal flow.
    These are suppositions. I am happy to be wrong, but it’s what makes sense to me. Curious to know if I am misunderstanding things.
  18. Jan 7, 2025 at 5:14 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    BR73, j_supra, M3Tundra-JK and 9 others like this.
  19. Jan 7, 2025 at 5:57 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Nice!!!
    Nothing better than that Supercharger Whine!!!!
    It's funny to see the faces of those who dont recognize it for what it is!!
    I left a lot of O faces behind with my 98 Tacoma with the TRD Blower!!!
    It's now time for the Magnuson Whine from my Tundra!!!!
  20. Jan 7, 2025 at 6:36 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    No issues with crap getting past your inner fender?
    Obviously if it's mainly driven on the street thats not an issue.
  21. Jan 7, 2025 at 6:42 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    No issues so far, only driven on the street.
  22. Jan 7, 2025 at 6:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :monocle:I'd ask you if you had more than one, but I'm currently running very close to the 5V/512grams MAF max with the TurboKits MAF. Then I'd have to open up the intake, then I'd have to go belt hunting to find the right length scratching the shit outta my forearms again and having everyone looking at me like I'm self-harming.:lalala:
  23. Jan 7, 2025 at 7:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    Ever have one of those days? So I'm taking a few thousandth off the pinion on the front diff. I pulled the rag that had my top pinion bearing which goes flying hits the corner of my engine puller and I hear bearings bouncing on the garage floor. Guess I'm delayed a day or 2 until new bearing shows from down south...:frusty:
    blenton, Wynnded and Ponderosa_Pine like this.
  24. Jan 7, 2025 at 7:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I hit it at 5600. I just blindly dump fuel at it.
    e30cabrio and Wynnded[QUOTED] like this.
  25. Jan 7, 2025 at 7:14 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Do you set up an account on the draggy? You got me by a tenth...
  26. Jan 7, 2025 at 7:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Seems okay as long as you're seeing the AFRs that you want.:rofl:
    e30cabrio and Mdl[QUOTED] like this.
  27. Jan 7, 2025 at 7:28 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Yes sir! The account setup was pretty quick and you pick what times to share. Tested my 4runner out and it got this amazing result haha (wild to think this is double the time of a Tundra and still faster than my first Mustang).
  28. Jan 7, 2025 at 8:01 PM
    snivilous
    SW UT
    I have a whole box of 2650 pullies, everyone bought the ones I had so I ordered more and no one ever ordered any more after that :rofl:
    Ryuu, M3Tundra-JK, e30cabrio and 5 others like this.
  29. Jan 7, 2025 at 8:27 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oh, okay. So my rationalization for buying one is "only" to see if I can get away with the same belt that I'm using for the 70mm. :D
    e30cabrio, Mdl and Tripleconpanna like this.
  30. Jan 7, 2025 at 8:28 PM
    snivilous
    SW UT
    Order it now so I can drop it off with some other parts tomorrow, you'll also get the new Sniv Speed Shop fridge magnets :rofl:
    HulkSmurf14, e30cabrio, Mdl and 2 others like this.
