First oil change on purchased Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by texasvortex, Dec 26, 2024.
  1. Dec 26, 2024 at 5:18 PM
    texasvortex
    texasvortex [OP] New Member
    Just finished first oil change on the 18 Tundra I purchased. Bought it with about 100k miles and just did the oil at 107k. pulled the filter out and it was twisted up. Anyone seen this before?
    First post here, sorry if this isn’t the correct location.
  2. Dec 26, 2024 at 5:23 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  3. Dec 26, 2024 at 5:23 PM
    RobertD
    Robert
    DFW, Texas
    Definitely not a filter from Toyota, at least none of the ones I've bought have looked like that. I could see it twisting if the filter was too long (it looks like it compressed a little too) and when the cap was threaded on that rubber on the top gripped while the cap was tightened.
    Tundra234 likes this.
  4. Dec 26, 2024 at 5:26 PM
    That looks like the wrong filter was installed during the last oil change. The OEM filter should look like this. It does not have caps on each end.
    DrunkenChewbacca likes this.
  5. Dec 26, 2024 at 5:27 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Was there a metal tube in the housing going through the filter when you pulled it out?
  6. Dec 26, 2024 at 5:29 PM
  7. Dec 26, 2024 at 5:31 PM
    texasvortex
    Wow lots of quick responses! Amazing. Thank you.
    Certainly not OEM. I installed OEM but the one I pulled out could have been wrong size for the truck? It was difficult to pull out, but it always is. Also, o-rings were red and blue… dead give away that it’s not oem. Don’t love that considering I just bought the truck but the right parts are installed now.
    Leo's first likes this.
  8. Dec 26, 2024 at 5:38 PM
    texasvortex
    Yes. This part was still original. Didn’t appear anything was wrong there.
    TILLY[QUOTED] likes this.
  9. Dec 26, 2024 at 6:01 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    yea aftermarket oil filter like others stated. nothing wrong with running aftermarket oil filters imo, lots of good options out there.
    looks exactly like the FRAM filters, which personally I stay away from.
    from posts I've seen of guys having that twist issue on FB groups either they were missing the metal tube in the middle of the housing
    or their oil filter housing had a shorter tube for some reason, like the one on this housing
  10. Dec 26, 2024 at 6:10 PM
    texasvortex
    thanks for the info! Everything looked fine and I’m 99% certain that tube was the correct length. After I installed the new filter I actually backed it back out because the last couple of turns felt odd and I wanted to make sure the o-ring didn’t fold over. When I pulled it back out everything looked fine so hopefully I don’t have the same issue.
  11. Dec 29, 2024 at 4:37 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    If the metal tube is shorter it is because someone switched to a metal cap and did not swap the tube.
  12. Jan 6, 2025 at 3:45 PM
    DrunkenChewbacca
    DrunkenChewbacca New Member
    Josh
    2020 Tundra TRD OR
    Walmart sells OE Oil filters. With collapsing filters, seems to be a lot of aftermarket ones collapsing, you're better off going OE. Idk about you but I wouldn't want one to collapse or fall apart and block oil passages.
