2019 LED head light high/low beam alignment
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Banichi, Jan 5, 2025.
  1. Jan 5, 2025 at 2:08 PM
    Banichi
    Banichi [OP] New Member
    Nathan
    2017 Tundra TRD Pro Stock
    I have a 2017 TRD pro double cab that I just upgraded to the 2019 OEM LED headlights using iHacker's harness. It went well though I do have a slight issue and it may be with the headlight assembly itself.
    I have differences in how the high and low beams are aligned on each side. Meaning on the right side the bottom edge of both high and low beams are the same, (high beams do of course reach higher when on but the bottom edge is still the same). Whereas on the left side the high beams are about 5-10 degrees higher almost to the point where at 20 feet there is about a foot of separation between the 2 beams. I don't know which one is correct. See the drawings below for detail. I'll try and grab a photo tonight as well.
  2. Jan 25, 2025 at 3:14 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    Not sure if this mighty help.
