New HD rear springs
Discussion in '1st Gen Tundras (2000-2006)' started by GN36PZ, Jan 4, 2025.
  1. Jan 4, 2025 at 9:38 AM
    GN36PZ
    GN36PZ [OP] New Member
    2004 V8 4wd AC "Off Road" w/ tow package
    Bull bar, Warn Wench, Nerf Bars, rear Cattleman's bumper, camper, 2 Starting batteries, 4 aux batteries for camper, cold air intake, 2 spare tires, Roof rack with jerry can racks, 200W solar panel, cot in back with 4" memory foam pad.
    Just got new HD rear springs from ATS installed on my 04 AC. Ordered the HD Spring kit with all the hardware and bushings 20250104_110643.jpg 20250104_110656.jpg 20250104_110724.jpg . Had it done at a nearby shop. Should have only taken about 3 hours turned into 5 hours due to whoever at ATS when they put the "kit" together, they packaged it with the shackles on the wrong ends.
    Anyway, the truck sits and rides good. Has a slight front rake to it unloaded but sits level w/ 20psi in airbags and about 500 lbs extra weight when going camping.
  2. Jan 4, 2025 at 9:41 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Any pictures of what all came in the kit? Is it just that big beefy leaf added on the bottom of the stack? And then some additional hardware?
  3. Jan 4, 2025 at 9:49 AM
    GN36PZ
    Elevatorguy likes this.
  4. Jan 4, 2025 at 2:21 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Looks great! How do you like the ride of those springs so far?
  5. Jan 4, 2025 at 6:07 PM
    GN36PZ
    Rides good and smooth so far. Haven't re-installed rear Hellwig swaybar yet but seems to be as stiff in the rear without it. Will install swaybar later and see how it does.
    Desert Dog likes this.
  6. Jan 4, 2025 at 6:12 PM
    Desert Dog
    Right on. I was just curious. Quite a few of here have the ATS HD's. I like how they ride and respond. I rarely ever have a load on them, though. Ymmv.
  7. Jan 4, 2025 at 6:23 PM
    GN36PZ
    As it's sitting in the pic, it has about 260 lbs of auxiliary batteries in the bed sitting 2 ft in front of the rear axle and 10psi in the airbags. unloaded
  8. Jan 5, 2025 at 6:58 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Did you already have the bags before the hd springs?
  9. Jan 5, 2025 at 7:24 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    What's your front suspension setup?
    I need new rear springs and I'm leaning toward HD. Undecided on how high to go in the front.
  10. Jan 5, 2025 at 9:07 AM
    GN36PZ
    The airbags were on it when I bought it about 7 years ago but have been replaced with new ones.
    Just have 1" spacers on the front, otherwise stock setup.
  11. Jan 5, 2025 at 11:29 AM
    MT-Tundra
    Montana
    Nice. Surprising that's all you've got up front. I hardly see any rake. Guess the weight in the back has something to do with that.
    Maybe I can get away with HD rear springs and OME 2883s up front.
