Cable routing from driver side rear to bed
Discussion in '2nd Gen Tundras (2007-2013)' started by PNWtundrite, Jan 4, 2025.
  1. Jan 4, 2025 at 9:31 PM
    PNWtundrite
    PNWtundrite [OP] New Member
    2010 Tundra TRD rock warrior black
    Demello front number with winch and lights, Bilstein 5100 Eibach spring 3" front lift and 5100 rear 2" lift, Android auto stereo with front camera
    I'm installing an auxiliary switch that will run from my house battery in my bed to a dc/dc charger that is installed behind my rear seats. I need to run two 1/0 cables out of the cab one that I will run into the bed and one I will run under the chassis through the engine bay and to the battery. Anybody have any ideas for this? So far I'm thinking about drilling a couple holes and throwing in cable glands.
  2. Jan 4, 2025 at 10:14 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
  3. Jan 4, 2025 at 10:24 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    PNWtundrite[OP] likes this.
  4. Jan 5, 2025 at 9:11 AM
    PNWtundrite
  5. Jan 5, 2025 at 9:44 AM
    Porschetech29
    Francis
    Driver’s front corner just behind and below the cargo tie down points.
    07 Tundie, Twinky, k0diak8o8 and 2 others like this.
  6. Jan 5, 2025 at 10:08 AM
    PNWtundrite
    What did you use for those floors man they look amazing! If you have more pics of your interior would love to see. Also how did you connect the floor to the bed did you use rivuts?
  7. Jan 5, 2025 at 10:11 AM
    Porschetech29
    Francis
    1/2” birch ply and a layer of EVA foam boat decking
  8. Jan 5, 2025 at 10:38 AM
    PNWtundrite
    Did you just lay it in or did you fasten it to the bed?
    Did you use FRP board for the cabinets?
  9. Jan 5, 2025 at 1:32 PM
    Porschetech29
    Francis
    1/2” birch is bolted to nutserts in the steel subframe.
    Cabinets are 10 series extrusion for the framing and 1/4” ECM for the paneling
    installed threaded inserts into the subfloor so I can easily unbolt the cabinets if needed
  10. Jan 5, 2025 at 3:35 PM
    PNWtundrite
    Sounds like our thinking was pretty much syncing. Thanks to Ton for your help. I'll drop a link to my build when I get it going. Installing some of the electrics today.
    Porschetech29[QUOTED] likes this.
  11. Jan 23, 2025 at 8:55 AM
    Porschetech29
    Francis
    Oops, I thought I posted more pictures of the floor system. I welded up a steel subframe that raises the birch subfloor up 1/2” making room for 1/2 foam insulation under the wood. The frame is mounted to the bed using the existing bed bolts. I added two extra nutserts for good measure.
    07 Tundie likes this.
  12. Feb 2, 2025 at 10:51 PM
    PNWtundrite
    This looks great man I'm going to see what I can do. My thoughts were to try and keep it as light as possible using 8th-in Birch. I was going to fill the slats with quarter inch Marine decking strips and put the Birch on top of it with more marine deck on top. How much weight do you think the substructure added?
