OFFICIAL: Oil Analysis Report Thread ONLY
Discussion in '3rd Gen Tundras (2022+)' started by eddiefromcali, Jun 13, 2024.
  1. Nov 8, 2024 at 3:42 PM
    #211
    Retired...finally
    Good.
  2. Nov 10, 2024 at 11:16 AM
    #212
    Sunstealer
    Sunstealer New Member
    2024 Platinum TRD HV Celestial Silver
    1st sample from when I changed the factory oil. I also cut the filter apart and inspected the media. I saw a couple of very small shavings, about like a splinter in your finger. I didn't see any of the stuff that Car Car Nut saw in his at the first change. I'll change again at the first scheduled service by Toyota. I refilled this time with Mobil 0W-20 and Mobil filter.
    Also, this is a hybrid with a build date of 3/2024.
    Tundrastruck91 likes this.
  3. Nov 22, 2024 at 4:29 PM
    #213
    carbinefreak
    carbinefreak New Member
    Ran M1 5w-30 for 5k from 35k to 40k and it sheared down to 20 weight. Currently filled with Kirkland 5w-30 will test at 5k when I get there next month.
  4. Nov 27, 2024 at 3:47 AM
    #214
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    Oil Sample #2:
    Ausfahrt likes this.
  5. Dec 21, 2024 at 3:10 PM
    #215
    Third-Reef
    Third-Reef New Member
    Gary
    2025 1794 TRD offroad
    Any oils analysis posts here that track and engine form running fine to failure? I see lots of analysis and comments about this could be from that and so on. i am looking for 10,20,30K analysis then boom!! kind of data. basically a signature of a failing engine. I will post my 1500 mile change here in a month or so when it gets done 2025 1794 TRD OR 10/24 build date.
  6. Dec 21, 2024 at 6:11 PM
    #216
    Kap1
    Kap1 New Member
    San Francisco, CA
    No I don't believe that we have identified a pattern yet that can show an upcoming failure.
  7. Dec 23, 2024 at 2:17 PM
    #217
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Second oil sample I’ve done - Valvoline extended protection + M1-103a filter over a ~6300 mile OCI. Probably ~30/70 city/highway driving with a lil off-roading mixed in.
  8. Dec 23, 2024 at 4:13 PM
    #218
    eddiefromcali
    eddiefromcali [OP] New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Not the right thread
  9. Dec 23, 2024 at 4:24 PM
    #219
    FrankG
    FrankG New Member
    Francois
    2022 Lunar Rock Sr5 TRD Off Road
    My second report also. Wanted to do a 10,000km OCI but the weather and road conditions were not cooperating on the day of my appointment. That’s the note the report references.
  10. Jan 4, 2025 at 4:29 PM
    #220
    Third-Reef
    Gary
    In another thread someone mentioned a steady increase in Silver in someone's analysis (3) and then an engine failure. first piece of info (conjecture?) like this I have seen.
  11. Jan 4, 2025 at 4:39 PM
    #221
    eddiefromcali
    Eddie
    100% Stock
    My truck is the one with high silver, but the engine hasn't failed.
  12. Jan 4, 2025 at 7:29 PM
    #222
    FrankG
    FrankG New Member
    Francois
    This is how rumours get started. You should have read a bit further before jumping to conclusions.
  13. Jan 4, 2025 at 7:52 PM
    #223
    Third-Reef
    Gary
    I do not want to be the rumor mill. I am an engineer and I like data. I will post my 2K (first change) results from my 25 1794 (10/24 build date) hopefully next week. I did not cut the filter open.
  14. Jan 6, 2025 at 10:38 PM
    #224
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    1st OFFICIAL sample. The 1st sample was only with 1200 milles. Pretty relieved with the results obviously beeing a 1/22 build. Towed my 5K TT twice about 150 miles each time and my new 8K trailer once on this sample. I also am a little heavy on the skinny pedal. Ironically, I just got the recall notice in the mail. I think I'll hold off for a while.
    Ausfahrt and FrankG like this.
  15. Jan 14, 2025 at 12:25 PM
    #225
    eddiefromcali
    Eddie
    100% Stock
    interesting report....Silver dropped
  16. Jan 14, 2025 at 12:38 PM
    #226
    Breathing Borla
    AZ
    how can that still be from solder like they said, can that still be getting into the oil?
    4mm likes this.
  17. Jan 14, 2025 at 12:40 PM
    #227
    eddiefromcali
    Eddie
    100% Stock
    The only change was the oil used...went from Amsoil to Kirkland. The lowest silver content samples were from non-Amsoil brands...coincidence?
  18. Jan 14, 2025 at 12:43 PM
    #228
    AZBoatHauler
    So.Arizona
    Kirkland light on the moly…
    according to Lake Speed, ZDDP eats silver. If the AMSOIL had more ZDDP, that could explain the test results. The question becomes what is leaching the silver into the oil…
    Breathing Borla likes this.
  19. Jan 14, 2025 at 12:44 PM
    #229
    Breathing Borla
    AZ
    need a duplicate sample and a equipment blank with fresh oil that had high silver while used
    ok, sorry, my environmental consulting sampling alarm went off there, ha, after 25 years of this shit, it hard wired
  20. Jan 14, 2025 at 12:50 PM
    #230
    eddiefromcali
    Eddie
    100% Stock
    #1- Toyota....2-4 Amsoil and 5 is Kirkland. You can tell the differences in Silver, Moly, Boron and Magnesium.
  21. Jan 14, 2025 at 12:56 PM
    #231
    AZBoatHauler
    So.Arizona
    And TBN.
  22. Jan 15, 2025 at 7:21 PM
    #232
    Third-Reef
    Gary
    just got my analysis back on MY 25 1794
    Looks pretty normal for break in oil.
    This was with about 1.5K of the milage as Ca freeway and the rest around town
    PNW Tundra Mike and Ausfahrt like this.
  23. Jan 30, 2025 at 8:52 AM
    #233
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Well everything is in the green now, did ask Lake if there was a typo on the Oxidation level if it should be 8.81 instead of 88.1. Going to stay at 3K or 4K oil changes and staying with Redline and Donaldson Filter.Screenshot 2025-01-30 at 11.42.37 AM.png . Now going back to
    eddiefromcali[OP] likes this.
  24. Jan 30, 2025 at 10:48 AM
    #234
    bailey bulldog
    bailey bulldog New Member
    Where do you get the filters and do you know the part number?
  25. Jan 30, 2025 at 11:31 AM
    #235
    machd08
    machd08 New Member
    CLARENCE
    Donaldson P502019 Filter, got it from Amazon
  26. Feb 1, 2025 at 9:04 AM
    #236
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    This is an early 600 mile report from a few months ago. I already did a 5000 mile oil change but I didn't save a sample so I will collect and send a sample from my next change at 10,000 miles.
    PNW Tundra Mike likes this.
  27. Feb 1, 2025 at 11:16 AM
    #237
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Such a waste of time sampling a short interval. Especially on new engine. Get rid of the break in material first then sample on the next change.
    I haven’t sampled mine but I did run the oil through a filter. At 5K no metal flakes visible.
    Kap1 and eddiefromcali[OP] like this.
  28. Feb 1, 2025 at 11:23 AM
    #238
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Everyone has their own thoughts and reasons for when to test. I did my first at 5K mostly interested in viscosity, coolant contamination and fuel contamination values.
  29. Feb 1, 2025 at 11:41 AM
    #239
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    As noted, these oil tests have not confirmed any relationship between the results and an imminent engine failure.
    While a good report might give some owners a warm and fuzzy feeling, I really don't see the point of them.
    Can a poor report lead to any actionable fix under warranty? Or do they just lead to unnecessary anxiety?
    G3ardnut likes this.
  30. Feb 1, 2025 at 12:09 PM
    #240
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    I get that. I wanted an early change and I sent in the sample just to see.
