  1. Jan 3, 2025 at 11:56 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yes
    bmf4069[QUOTED] likes this.
  2. Jan 3, 2025 at 2:34 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I love this man. Making changes for the positive is awesome. Happy new year!
  3. Jan 3, 2025 at 4:08 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's actually new :D
    Let me find the one I posted a few days back...
  4. Jan 3, 2025 at 4:13 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yes. The 4.10's and the third member in the T3 came from a Sequoia. The difference is the flange for the driveshaft. Which is swappable.
    bmf4069[QUOTED] and FrenchToasty like this.
  5. Jan 3, 2025 at 4:15 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    ...it gets better!
  6. Jan 3, 2025 at 5:12 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Very similar experiences with them as well.
  7. Jan 4, 2025 at 7:50 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I’m super stoked you found your lane. I hope your blessings and happiness are compounded this year!
  8. Jan 4, 2025 at 10:35 AM
    We replaced John's radiator today.
  9. Jan 4, 2025 at 10:48 AM
    "Rad" :rofl:
    Hopefully you filled it up with jPink long-life fluid.
  10. Jan 4, 2025 at 11:49 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Weekend project experiment. Really like live edge shelves so trying to make my own since they’re ridiculously expensive. 93DA2001-3BB1-48B8-BE66-BF1DC62A65D6.jpg
    Fun fact, 10”+ wide wood is much better quality than shorter widths like 2x4’s etc. They’re a good option for wood working projects.
    bmf4069, CodyP, whodatschrome and 5 others like this.
  11. Jan 4, 2025 at 12:36 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    That’s a cool idea.
    Larger wood is pretty much always better quality, has to be cut out of bigger trees usually more heartwood, small dimension stuff is usually produced from around the outside or smaller trees, lots of sapwood and knots.
    If I’m making something that I want to be nicer and I need small dimension wood I’ll get bigger dimensions and cut my own.
    BroHon, KNABORES and Voss[QUOTED] like this.
  12. Jan 4, 2025 at 5:12 PM
    Voss
    2003 AC TRD 4x4
    Two different grains/styles. Now to decide if I should get a blow torch and spice things up a bit… hmmm525C8408-2F1F-4FF4-929A-18035ACD8733.jpg
    bmf4069, KNABORES, JakeJake and 8 others like this.
  13. Jan 4, 2025 at 6:34 PM
    Sho Shuggie Bahn
    JakeJake and Voss[QUOTED] like this.
  14. Jan 5, 2025 at 5:24 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    bmf4069, khooiii and BroHon like this.
  15. Jan 5, 2025 at 6:09 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Charred wood/Charcoal is good for so many things. I've emptied our fire pit into the garden for several years along with mulching/pulverizing our leaves and adding them in the mix. That soil is so rich now.20241026_121218.jpg
    Our indentured servants work it into the ground, and add some nitrogen :poking:
  16. Jan 5, 2025 at 9:01 AM
    JakeJake
    2000 Tundra AC 4X4
    Speaking of finishes...
    I spent the last six days painting the frame and bodywork for my welder. I had to stay focused on getting it done instead of getting it perfect. These kinds of projects can quickly spiral out of control for me if I don't give myself some kind of quality standard and deadline.
    Post media blasting:
    Midway through a couple of coats of high build and bumping/filling the worst of the dents
    Final Product. A few runs, and plenty of visible sanding scratches. I probably should have hit it with a final coat of primer and finished with a higher grit, but it is "done" so mission accomplished. Looks damn good from 10 feet :rofl:
    Cleaning the shop today and looking forward to working on something else for a while.
  17. Jan 5, 2025 at 1:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Long travel Sequoia axle?
  18. Jan 5, 2025 at 2:54 PM
    Neo
    Neo New Member
    Alabama
    Like a lot of folks, it's hard for me to keep a work bench clean and I'm always searching for place to set a tool box or parts or whatever. I've managed to put together a generic portable workspace for a quick popup in the garage or for use away from home. It's a 4-foot folding table topped with a non-slip mat and a roll up Kobalt tool set. Strictly for automotive work, the tool kit is missing combination wrenches and deep well sockets. However, it is stocked for a variety of projects. It is the only set I found of this size that has both sockets and several types of pliers. Most sets have one or the other, but not both.
    daveeasa and 455h0le_dachshund like this.
  19. Jan 6, 2025 at 9:56 AM
    It’s already a bad year when you go into work and facilities has tossed out all the 20+ year older comfortable chairs and replaced them with some uncomfortable ergonomic POS.
  20. Jan 6, 2025 at 10:50 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    What is the process for adding a live edge?
  21. Jan 6, 2025 at 11:43 AM
    JakeJake
    2000 Tundra AC 4X4
    Dislike, unless of course the ergonomic POS is a Herman Miller Aeron...thems fightin' words.
    455h0le_dachshund likes this.
  22. Jan 6, 2025 at 11:46 AM
    I went from a Steelcase Criterion highback to one of their newer models. Nobody here likes them.
    I’d love to get one of the newer Herman Millers with the newer lumbar support. I don’t like the older ones.
  23. Jan 6, 2025 at 2:54 PM
    Voss
    2003 AC TRD 4x4
    I cut the edge at an angle then took a grinder to it lol. Good enough for what I wanted93961253-E95D-4B74-A2B7-44896D894293.jpg
  24. Jan 6, 2025 at 2:55 PM
    “Good enough for who it’s for”
    bmf4069 and Voss[QUOTED] like this.
  25. Jan 6, 2025 at 2:57 PM
    Voss
    2003 AC TRD 4x4
    Question, would a clock spring from a double cab 04 be interchangeable with my 03 AC?
    Switched mine out a couple weeks back but it started making a whining sound. Junk yard cool enough to give me another but thought I’d check with folks more knowledgeable than me.
    Only visible difference is the 04 has 4 mounting location vs 3 available on mine.
    Thanks!!
  26. Jan 6, 2025 at 5:46 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    They don't look compatible to me, Voss. 03 has a single harness and clip. 04 has 2 harnesses and 2 clips.
  27. Jan 6, 2025 at 5:56 PM
    I want to say the '03 uses a single-stage airbag and '04 uses dual. This may be a question for @daveeasa to chime in about, he has some knowledge on single/dual on the airbags I think.
    Voss likes this.
  28. Jan 6, 2025 at 6:02 PM
    Desert Dog
    That would make sense because it accounts for the separate harnesses. The MY applications are definitely not the same.
  29. Jan 6, 2025 at 6:03 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Pretty sure that's to add steering wheel controls
  30. Jan 6, 2025 at 6:07 PM
    Desert Dog
    That's possible.
    Voss, what is the date of manufacture for your 03 and date of manufacture of your 04? That will narrow down the possibilities for swapping.
