Tire size question
Discussion in 'Wheels & Tires' started by Db300, Dec 27, 2024.
  1. Dec 27, 2024 at 8:14 AM
    Db300
    Db300 [OP] New Member
    I have a 23 platinum and wanted to know what size bigger and more aggressive would fit on the stock ride height with out leveling the front .
  2. Dec 27, 2024 at 8:23 AM
    SDT-Online
    SDT-Online New Member
    2024 Tundra Platinum (Red)
    You can try this website to do comparisons...
  3. Dec 27, 2024 at 8:25 AM
    DRP
    DRP Old Member
    Dave
  4. Dec 27, 2024 at 10:10 AM
    Observer
    Observer New Member
    https://www.tundras.com/threads/gen-3-2022-wheels-and-tires-photo-thread.101215/
    177 pages of nothing but tire and wheels for 3rd gens. Short answer is 33" tire no problems and most likely can go to 34" . You have to also consider width.
  5. Jan 3, 2025 at 8:16 AM
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    I just put new shoes on my ‘25 Platinum. It has the factory lift as well. These are Toyo LT285/65-20’s and the fronts slightly rub the mudflaps near full turn. They do not rub the sway bar. I need to buy the bracket (from Westscott I think) to pin the flap back a little.
  6. Jan 3, 2025 at 9:00 AM
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    I just drilled a small hole in the liner by the cab Mount and zip tied the liner back for a quick fix
    vichmr likes this.
  7. Jan 3, 2025 at 3:02 PM
    vichmr
    vichmr New Member
    Scott
    And that is on the front side of the front tires?
  8. Jan 4, 2025 at 9:29 AM
    Crawldad
    Crawldad New Member
    It’s behind the front tire.
    I removed the mudflaps because my tires rubbed them then after removal found out they rubbed the liner so I zip tied it back as shown above. It looks like you can zip tie the mud flap back according to this post.
    Mud flap trimming
