Front Bumper Extension Insert - how important?
Discussion in '3rd Gen Tundras (2022+)' started by Hammertimerrrr, Jan 2, 2025.
  1. Jan 2, 2025 at 3:32 PM
    Hammertimerrrr
    Hammertimerrrr [OP] New Member
    2024 MGM Limited OR
    In the process of upgrading to a Heritage grill, I broke this piece that is near the fender well area on the right hand side underneath the front part of the fender flare. With as many clips and bolts are holding that thing on I can’t imagine it wouldn’t still be secure but is this something I should replace? means I’ll reassemble the front end only to take a lot of it back off to replace once I can get the part.
    part #
    52115-0C140
  2. Jan 2, 2025 at 3:47 PM
    Observer
    Observer New Member
    BoomBoomGanoom likes this.
  3. Jan 2, 2025 at 3:50 PM
    Hammertimerrrr
    2024 MGM Limited OR
    yeah, found the part. But that description makes it seem this is a part that primarily helps cushion in a collision. And it’s a piece of plastic that I broke with only a little force - how on earth that would absorb much of any impact is beyond me…
    I will probably just reassemble, order the part and roll with it until I feel like taking the bumper apart again.
    i figure I’m not the only one who’s likely broken this piece when removing the bumper
  4. Jan 2, 2025 at 3:55 PM
    Observer
    Observer New Member
    I'm sure you aren't . As I said it bothers me that there are so many "plastic" parts. At least the price isn't too bad I guess.
    Hammertimerrrr[OP] likes this.
  5. Jan 2, 2025 at 4:00 PM
    Hammertimerrrr
    2024 MGM Limited OR
    yes, way too much plastic everywhere. I just don’t want to take the bumper on and off again for fear I’ll break something else trying to get the clips undone. I’ll put it all back together tomorrow, order the part and replace it when I have the time - which will be awhile with the new year in high gear
    Tundrastruck91 likes this.
  6. Jan 2, 2025 at 4:31 PM
    lapoolboy
    lapoolboy New Member
    Have a wider-view pic? Where exactly is this located on the truck? Did you learn from that side and then successfully remove the other side without breaking?
    Agreed, all the plastic has me nervous about this project. Is there any way to get to the backside to help release the clips instead of just pulling on the panel in hopes they'll pop free without breaking?
  7. Jan 6, 2025 at 12:07 PM
    Hammertimerrrr
    2024 MGM Limited OR
    Sorry, I did not get a better picture but you can see from that diagram where it is. It's literally right below the part of the bumper that doesn't get removed. Doesn't appear to be super important, I mean everything went back together and is snug. However one of the fender well bolts into this piece so I only have 3 bolts on that fender well side for now. I've ordered the part and will replace it in the next couple of weeks. Gonna go ahead and swap from the Rave amber lights to the OEM ones that aren't quite so bright :) so I'll wait for that to come in and replace the part and lights all at once.
    Once you've done it once, it's not terrible to take the bumper off just have to be more careful around the fenders w/ the clips
  8. Jan 6, 2025 at 12:08 PM
    Hammertimerrrr
    2024 MGM Limited OR
    Still turned out quite nice in the meantime!
  9. Jan 6, 2025 at 12:23 PM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    Grill looks good. It's not a critical part but I'd probably replace it if it were me. It's main function is to hold in the part of the bumper below the headlight near the fender. You can see on the top there are 3 tabs that the bumper snaps into. The piece you broke has the tab closest to the fender. If you don't replace it, there's a chance that part of the bumper may pop out slightly by the fender. When I took the grill/bumper off, it took me a minute to figure out that part. If you pull downward a bit and then outward, it comes out easier.
  10. Jan 6, 2025 at 12:43 PM
    Hammertimerrrr
    2024 MGM Limited OR
    Agreed. Not critical to drivability and everything does feel very secure - no looseness anywhere, but YES, I have ordered the part and will replace it. Dumb not to on such an expensive new vehicle esp for the low cost. I'll report back if I have any issues replacing this.
    Thanks for the down then out advice. I just kept pulling and prying on the first side but took my time w/ the 2nd. And I'm sure the tabs get easier to remove with repetition lol
