Warm up on cold mornings
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mp269, Jan 2, 2025.
  1. Jan 2, 2025 at 4:58 AM
    Mp269
    Mp269 [OP] New Member
    Tundra
    Lift
    Hello ,my recently purchased 2015 limited takes a long time to warm up on cold morning,specially the defrosting mode.
    I know it’s a bigger engine but it seems like thermostat might be wrong temp.
    Is that possible?
    Mp269
  2. Jan 2, 2025 at 4:59 AM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    Can you give a rough estimate on a long time so people can compare.
    5, 10, 15, 20 min?
  3. Jan 2, 2025 at 6:07 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I live in socal and it still tales a while to warm up. I typically let it get to at least 100 degrees. If you leave the heat off until it warms up it's faster.
  4. Jan 2, 2025 at 6:17 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Do you mean it takes a while to warm up if you just leave it idling, or it takes a while even after you begin driving?
    I usually let mine warm up about 30-60 seconds, and then drive off, but drive it pretty gently until the coolant temp gets to normal, and this usually only ends up taking about a couple minutes.
    Just idling it'll take forever
  5. Jan 2, 2025 at 6:23 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Since switching to 5w-30 in New England with 20* weather, I usually let it sit for a bit until I see oil temps reaching above ambient. Then I’ll take it slow.
  6. Jan 2, 2025 at 10:12 AM
    Mp269
    Tundra
    Lift
    At a cold start idling takes at least 10-15 minutes to get defrost to start working. My 4 cylinder is much quicker.
  7. Jan 2, 2025 at 10:34 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    If you have to park outside of a garage, I'd suggest getting one of those windshield blankets. Then you can start driving well before the coolant is warm enough for the defroster to be effective, and the whole truck will be warm much quicker overall. It'll pay for itself in fuel savings.
    Your 4 cylinder probably holds much less coolant and therefore heats that smaller volume much quicker.
  8. Jan 2, 2025 at 2:40 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Much can depend on the actual temp and moisture in the air, but I generally get some defrost happening in 5 min. 10 min idle is enough to get warm enough to start ice melt effectively.
    But, ANY idle time for a v8 Tundra absolutely kills your average MPG for the tank of gas. Idling just a few times, few minutes each will bring down tank average MPG by 1MPG or more. Tundras just suck fuel at cold idle.
    But you have to do what is needed and sometimes defrost/defog before driving is required :spending:
    Tundras heat up to operating temp fastest by starting, then driving immediately, careful and light throttle until temps come up.
    Ebrperk and HulkSmurf14 like this.
  9. Jan 2, 2025 at 2:49 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Windshield Blanket (of snow!):rofl:
  10. Jan 2, 2025 at 2:51 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    Thermostat could be stuck open.
  11. Jan 3, 2025 at 4:49 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Idling doesn’t do much. Start it up and idle for less than a minute. Then drive easy until you see your needle start to move.
    Don’t rely on defrost. Scrape that window.
    You could always get a scan tool to watch your actual temps to rule out anything wrong. Comparing a half ton V8 to a 4cyl isn’t a direct comparison.
    AZBoatHauler likes this.
  12. Jan 3, 2025 at 5:01 PM
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    Get a scan tool to monitor temps to see if your thermostat is working. You can get a cheap Bluetooth one off Amazon
    There's also a Toyota block heater you can order if you want to go that route. I believe most Canadian Tundra's come with them
    Wynnded likes this.
  13. Jan 3, 2025 at 7:59 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds normal, and your 4 cylinder has a lot less mass and coolant to get warmed up.
    My 6-cyl bed mounted radiator mini truck will take half an hour to maybe reach operating temp in the middle of summer if I leave it idling, not a lot of heat at idle and a lot of coolant. A big V8 is in a similar ballpark.
    Wynnded, HulkSmurf14 and AZBoatHauler like this.
  14. Jan 3, 2025 at 10:40 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Drive it to warm up faster. Start it, wait for you SAIP to shut off and away you go! They drink too much to just sit, running. The fastest way to warm up is to move!
    snivilous and Sugar’s4x4 like this.
  15. Jan 4, 2025 at 6:52 AM
    overbeatsunder
    overbeatsunder New Member
    2018 Tundra SR5 Double Cab Long Box
    Having just joined the Tundra family, it is affirming to see the same observation from others. I guess it just doesn't warm quickly at idle.
    HulkSmurf14 likes this.
  16. Jan 4, 2025 at 9:47 AM
    akpowrider
    akpowrider New Member
    2019 DCLB
    I have to park at the trailhead (at cabin). It’s been around -20F for the last week. The 5.7 warms up much faster than my Silverado. IMG_8680.jpg
