ALL 12V Outlets NOT working - Post 12V USB charger install - 2017 Toyota Tundra SR5 4x4 5.7L
Discussion in '2.5 Gen Tundras (2014-2021)' started by jayhawknavy02, Dec 30, 2024.
  1. Dec 30, 2024 at 12:12 AM
    jayhawknavy02
    jayhawknavy02 [OP] New Member
    SOCAL
    2017 Tundra 5.7L SR5 Crew Max TRD Off Road 4x4
    Dirty Deeds 10” exhaust TRD Accelerator OTT Tune Sony XAV-9000ES Head Unit AJT Interior Upgrades
    Working on a 2017 Toyota Tundra SR5 V8 Tundra 4x4.
    Just did a radio install, with the AJT knobs for the 4WD and climate controls, while I was at it, I thought I would get cute and install a 12V USB-C 65 watt from Amazon in place of the regular 12V Toyota plug in the front.
    Everything works from Trail Grid Pro like a champ (except TPMS and Fuel % - odd, but I'll call them on Monday).
    Started the truck, and no power to any front or rear 12V outlets. I found one blow 15 Amp fuze, but all the other 15 and 30 AMP fuzes in the engine bay and under the driver side were good. Replaced the fuze, still no power, so I disconnected the 12V I just installed, and still no power.
    At this point not sure what I else I can trouble shoot or replace.
    Appreciate the help on figuring out how to restore power to the 12V outlets (front and rear)
    Thank you in advance for the help.
    Jay
  2. Dec 30, 2024 at 4:06 AM
    @texasrho83 didn't you have this issue with yours?
  3. Dec 30, 2024 at 4:50 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Did your radio kit come with an obd2 plug so it can get data to display on the radio?
    jayhawknavy02[OP] likes this.
  4. Dec 30, 2024 at 5:44 AM
    jayhawknavy02
    SOCAL
    I got the Maestro idata link RR with the stereo and it has an OBD plug which I didn’t connect as it wasn’t in the video. However, it was in the directions on the website.....
    Soooo.....looks like I'll be connecting the OBD plug to the SONY 9000ES, which kicks butt.
    Now....just got to figure out why the 12V outlets are not working...lol. While I'm connecting the OBD, hopefully someone will have some help on that one...lol.
    In that arena, there were no directions (thank you China) so at least I'm pure, shooting .500 today :(
    As always thank you for the help! The forum kicks butt!
  5. Dec 30, 2024 at 5:59 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sure did. It was a terminal I hadn't connected when I did my install. I pulled up the console and it was laying there unplugged staring at me...
    jayhawknavy02[OP] and KNABORES like this.
  6. Dec 30, 2024 at 6:02 AM
    BrandonL812
    Brandon
    You need to connect the obd plug so the maestro can read data from the obd port..
  7. Dec 30, 2024 at 7:53 AM
    jayhawknavy02
    SOCAL
    Yep! Done - now just need to figure why I lost 12 V to all the locations front and rear :(
    BrandonL812[QUOTED] likes this.
  8. Dec 30, 2024 at 4:43 PM
    BrandonL812
    Brandon
    How did you wire up the USB C? How did you tap for power?
    I would remove each individual fuse and check each for continuity..verify each one then put it back. To rule out if you had missed one.
  9. Dec 30, 2024 at 4:47 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Here is your outlet wiring diagram.
    It has it's own fuse.
    Might be a relay issue..
    Tunrod and jayhawknavy02[OP] like this.
  10. Dec 30, 2024 at 4:56 PM
    jayhawknavy02
    SOCAL
    I wired it using a connector to the same + and - wire that were there from the original 12V for the truck. I removed the fuze from the Amazon 12v USB-C charger (65W) and soldered in a connector on the OEM a the Amazon so I could connect them.
    Will do!
    Any idea on which relay?
  11. Dec 30, 2024 at 5:35 PM
    BrandonL812
    Brandon
    But you did verified which wire on the truck is + and - before you add your connectors, correct? By verify i mean using a multimeter to see which wire is + ..
  12. Dec 30, 2024 at 6:28 PM
    jayhawknavy02
    SOCAL
    yep - sure did
    what has me confused is that I disconnected the 12V (front right) that I played with and the rest still don’t work. Unless they’re all wired in series I should be able to remove the front right 12V outlet from the circuit and the rest function as normal. On the road but I’ll check the diagram.
  13. Dec 30, 2024 at 6:41 PM
    BrandonL812
    Brandon
    Just seems weird both died. I’m lost. Sorry cant help ya much.
  14. Dec 30, 2024 at 7:00 PM
    jayhawknavy02
    SOCAL
    me too! Right!
  15. Dec 31, 2024 at 7:35 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    They are not wired in series..
    Did you test the circuit for a good ground with your meter?
    They do seem to all have a common ground - J2.
    As to your relay.
    You can find wiring diagrams here is you need them.
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum
  16. Dec 31, 2024 at 8:36 AM
    jayhawknavy02
    SOCAL
    This is exactly what I need!
    Thank you! I’ll test this and see what I find
    1lowlife likes this.
  17. Dec 31, 2024 at 7:31 PM
    jayhawknavy02
    SOCAL
    Auto part store didn't have a new relay, so I swapped the "DEICER" relay with the adjacent "TOW TAIL" relay. No change to any 12V outlets in the vehicle.
    DEICER fuze looks to be in the position of * 8 P/Outlet No. 1 Relay based on the diagram and I have my fuze box images in the post for reference.
    About to go check the ground. I have the day off tomorrow so I can play around with this.
    Any other thoughts/ideas? Connection that could be lose somewhere that I should verify (center console?), etc.
    Cheers, and Thanks,
    Jay
  18. Jan 1, 2025 at 4:09 PM
    jayhawknavy02
    SOCAL
    Okay! I am the ultimate bonehead, the problem is that, yes, I had a blown 15 Amp fuze, and the guidance above is good, but the reason I lost all the outlets is that after installing the Head Unit (HU) / Car Stereo I failed to connect the center console 12V back. Once I did that, huzzah, power to all 12v outlets! Problem solved!
    BrandonL812 likes this.
  19. Jan 1, 2025 at 4:59 PM
    BrandonL812
    Brandon
    Lol..
    Doh! Moment.
    glad you git it sorted out..
  20. Jan 1, 2025 at 5:01 PM
    jayhawknavy02
    SOCAL
    100% - volt meter for the win and......embarrassment to reinforce not doing work when you're tired....lol
    Let my stupidity be a lesson for others.....photos attached to help anyone else.
