Fuel Gauge Always On Full
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mandrews, Dec 31, 2024.
  1. Dec 31, 2024 at 4:47 PM
    Mandrews
    Mandrews [OP] New Member
    NJ
    2016 Black Tundra SR5 CM
    Hi All,
    Does anyone here have any experience with their fuel gauge always reading full? (I wish it really was always full lol). Sometimes, it will read correctly which leads me to it being the float. If you have any other ideas let me know! Thanks and Happy New Year!
  2. Dec 31, 2024 at 9:50 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I had a Ford that did that and it was a ground wire for the float that was loose .
    Mandrews[OP] likes this.
  3. Jan 1, 2025 at 4:50 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Have you had the fuel pump replaced anytime recently? Or has this been an ongoing issue for a long time? I'd believe the float is stuck in the up position.
  4. Jan 1, 2025 at 6:03 AM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    I wish my fuel gauge was always on full, some people are so lucky.
    Mandrews[OP] and 250000yota like this.
  5. Jan 1, 2025 at 11:45 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Fuel sending unit issue...could be loose connections, chewed on wires from oesrs ir just a faulty unit itself...use as much fuel as you can and drop the tank to "check" or replace the fuel sending unit...7 have one available (non flex fuel) if you need...just swapped out to a DW340 fuel pump and swapped the fuel sending unit as a just in case I need my oem...which I do not...
