Broke nipple on intake
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stumpjumper, Dec 30, 2024.
  1. Dec 30, 2024 at 1:03 PM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Not sure how I broke it but I did. Is it replaceable or am I screwed. 20241230_150108.jpg
  2. Dec 30, 2024 at 1:08 PM
    Should be able to remove the remainder of that broken nipple and drill/tap for a threaded base nipple replacement, brass likely easy to get. If you have the rest of the existing broken nipple, may be able to epoxy repair.
  3. Dec 30, 2024 at 1:11 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Wurth Fix-All or some other plastic specific 2-part epoxy should do the trick.
  4. Dec 30, 2024 at 1:12 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I had the broke off nipple. Cleaned it up and was going to use some JB Weld plastic bonder and I lost it. Been searching for a 1/2 hour.
  5. Dec 30, 2024 at 2:00 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Found a plastic nipple that fit. Through some JB Weld plastic bonder on it to seal at intake. Nipple is a soft plastic but I don't think temps on intake will be a problem.
    It was 1 of days. Changed my oil and was a 1/2 quart low after running engine. Took oil cap off and dropped it. Cap landed on front axle. Anyone who has dropped 1 down there knows what I went through to retrieve it.
  6. Dec 31, 2024 at 3:41 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Found the nipple. I put it in a safe place. Safe from myself that is. If it was a snake it would have bit me. Will stick with my fix for now but have the nipple in case it fails.
  7. Dec 31, 2024 at 3:57 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
