The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Dec 26, 2024 at 7:29 AM
    #1891
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The guys I run with like to go fast in the desert, but the truck likes to cut power via traction control when you try to pin it in the softer stuff. The disabler simulates the press-and-hold operations that you'd need to do to fully disable traction control while playing in the dirt, and uses a toggle switch so that you don't need to remember to do it every time you get back in and start the truck up (this last part is the real reason - I hated hauling ass, losing power because I forgot to disable the nannies, then having to stop for 15 seconds to do the procedure). @KevinK has a really nice writeup of all the traction options our trucks have, at least for the 2.5 gen and prior. Some of it still applies to the 3rd gen I'm sure. https://www.tundras.com/threads/traction-control-everything-you-want-to-know.21697/
    RobertD, reywcms, BiggHertz and 2 others like this.
  2. Dec 26, 2024 at 7:43 AM
    #1892
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The guys you wheel with sound like a bunch of jagaloons lol
  3. Dec 26, 2024 at 7:45 AM
    #1893
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    They are that, 100%
  4. Dec 30, 2024 at 5:51 PM
    #1894
    JXMILEM
    JXMILEM New Member
    Almost Heaven, WV
    2025 Mudbath Tundra
    This is the solution I came up with…
  5. Dec 30, 2024 at 7:23 PM
    #1895
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Bro… the amount of shit on your console is making me itch
    Fotnot, RainMan_PNW, Mater and 4 others like this.
  6. Dec 30, 2024 at 7:48 PM
    #1896
    JXMILEM
    JXMILEM New Member
    Almost Heaven, WV
    2025 Mudbath Tundra
    It’s an organized mess
  7. Dec 30, 2024 at 8:11 PM
    #1897
    RobertD
    Robert
    DFW, Texas
    That's how I describe my life
    TRDFerguson[OP] and JrJrOffroad like this.
  8. Dec 31, 2024 at 1:34 PM
    #1898
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Picked up a sloppy seconds Revesol steering wheel from @RainMan_PNW. I had previously put a leather wrap over my SR5 wheel, and it was fine, but this thing is much nicer.
    Removal is pretty easy. The sketchiest part is dealing with the airbag, but just disconnect the negative terminal on your battery, wait 20 mins, and you're fine...ish.
    First step (after the first step) is popping the panels off each side of the steering wheel
    That will expose the Torx screw on each side that holds the airbag assembly in the steering wheel. Once you get them loose, pull out gently on the airbag while unscrewing and you'll feel it release
    The airbag has 3 connections - the ground and then orange and black clip connections. CAREFULLY pry straight out on the yellow tabs until they pop out about an eighth of an inch. You can then pull straight out on the connectors. Remove the ground connection last. Set the airbag out of the way, somewhere safe.
    To remove the wheel, you'll first disconnect the two white plugs at the clock spring, then remove the 19mm nut. An impact makes that part much easier, but it can also be done with a breaker bar and a second set of hands. Just don't wrench against the steering assembly or you'll probably break shit. PRO TIP: leave the nut partially threaded so the wheel doesn't come flying off at speed when you remove it. Gently rock the wheel back and forth, up and down until it loosens and pulls off.
    From there, you'll have 4 screws for the steering wheel control panels and 2 for the cruise control stalk. It's pretty self-evident how that part works, so not documenting any of it. Reverse the removal process and enjoy your new bacon leather wrapped goody.
  9. Jan 1, 2025 at 6:36 PM
    #1899
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Such a carefully written and helpful post…
    Who are you and what have you done the real @TRDFerguson ???
  10. Jan 1, 2025 at 6:39 PM
    #1900
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    #newyearsresolution
  11. Jan 1, 2025 at 6:50 PM
    #1901
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Hey, I yada yada’d the ending to balance it out a little bit…
    Azblue, RobertD, Mater and 1 other person like this.
  12. Jan 1, 2025 at 6:50 PM
    #1902
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    but post was dec 31?
  13. Jan 1, 2025 at 6:51 PM
    #1903
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Octothorpeiwillbethesameoldpieceofshitintwoweeks
  14. Jan 1, 2025 at 6:57 PM
    #1904
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Azblue, RainMan_PNW, RobertD and 3 others like this.
  15. Jan 1, 2025 at 7:03 PM
    #1905
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Wheel looks slick. Hows the fit and finish?
    Azblue, RobertD and TRDFerguson[OP] like this.
  16. Jan 1, 2025 at 7:10 PM
    #1906
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s really nice. It has a thicker feel than the stock steering wheel, and a flat back with finger grooves that give it a sports car feel. The leather and stitching are both done well. 10/10 would do again.
  17. Jan 1, 2025 at 7:18 PM
    #1907
    RainMan_PNW
    Casey
    Clark County, WA
    Compared to the stock Toyota leather wheel, that one was a major upgrade. I really liked it - only reason for me to let it go was because I wanted a heated one (that I am currently loving)
  18. Jan 1, 2025 at 7:20 PM
    #1908
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’m able to get sweaty palms all on my own. You weirdos in the north can have that heated crap.
  19. Jan 1, 2025 at 7:22 PM
    #1909
    Azblue
    The Dirty T ( ^_^)_且
    TWSS
  20. Jan 1, 2025 at 7:22 PM
    #1910
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Much girth.
    Mater, BiggHertz and Azblue[QUOTED] like this.
  21. Jan 12, 2025 at 8:53 PM
    #1911
    AZBoatHauler
    So.Arizona
    Living up to the thread name. No fish were harmed.
  22. Jan 12, 2025 at 9:23 PM
    #1912
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Aye matey!
    Azblue, RobertD and reywcms like this.
  23. Feb 10, 2025 at 8:22 AM
    #1913
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Knocked out a few things last week and this weekend. First up is an eBay speshul MagSafe charging tray for the center console. I had previously hacked up an RMF prototype tray, and before that epoxied a wireless charger pad in the tray, but this looks much cleaner, and works well.
    The fire extinguishers on the truck and Can Am got upgraded to larger bottles. Still hoping I never need them, but I feel better with them on board.
    Installed L-track/VersiTrack in the truck bed for better storage tie down options. This allowed me to move the spare tire and jack rearward, and will hopefully help with the jouncing I'm getting on paneled highways and choppy desert terrain.
    Oil change, swapping to 5w30, along with tire rotation and cabin filter swap were also done.
    Also mounted a bunch of lights on the Can Am, using an AuxBeam switch controller to simplify wiring a bit.
    Baja Designs Squadron R Sports on the front A-pilars
    https://youtu.be/voRGv58eSlI
    Baja Designs RTL for chase functions in the back
    https://www.youtube.com/watch?v=4snMNSo-gRM
    Blue Line Whips 2 ft whips on the roof
    https://youtu.be/zRIY4tL4Jxc
  24. Feb 10, 2025 at 9:36 AM
    #1914
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    L-track is brilliant. Does it sit proud of the other ridges? Link please :D
  25. Feb 10, 2025 at 9:42 AM
    #1915
    RobertD
    Robert
    DFW, Texas
    I asked him the same thing in a PM!
    @TRDFerguson guess you need to state that and add pictures hahahahaha
  26. Feb 10, 2025 at 9:47 AM
    #1916
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    God, you people are so needy... :D
    It's pretty close to flush, but does poke up about a half millimeter above the ribs. It's pretty smooth, though, so I wouldn't think it would hurt much from stowing on top or sliding over the track.
    Here's where I got it all: https://www.uscargocontrol.com/collections/l-track-tie-down-rails
    FrenchToasty, 1794TX, Azblue and 3 others like this.
  27. Feb 10, 2025 at 10:12 AM
    #1917
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Final question: does your driver side sag with the extra weight of the tire shifted or is it similar to having one-too-many donuts in the morning. Maybe the pro eagle counter-balances it?
    TRDFerguson[OP] likes this.
  28. Feb 10, 2025 at 10:22 AM
    #1918
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Pretty sure the PE balances the weight, or at least that's what I'm trying to tell myself. I haven't noticed any (new) lean after moving the payload around.
    AZBoatHauler and Mater[QUOTED] like this.
  29. Feb 10, 2025 at 12:47 PM
    #1919
    RobertD
    Robert
    DFW, Texas
    You've met a few of us so that should not be a surprise
    :rofl::rofl:
    Thank you for the info, this seems pretty useful while still letting you slide items in and out of the bed or to have larger lumber laying flat across these locations without damaging the wood.
  30. Feb 13, 2025 at 9:11 AM
    #1920
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    BOX the frame to rid yourself of bed bounce. lol
