Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Dec 6, 2024 at 2:06 PM
    #2521
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    You may need to go into the settings and check how it's setup.PW is 126
    TNDRA6!9 likes this.
  2. Dec 6, 2024 at 3:00 PM
    #2522
    SCTundy
    SCTundy New Member
    Gotcha. There now. Unde canbus I'm 08 camry&RAV4. Any other to try?
  3. Dec 7, 2024 at 7:09 AM
    #2523
    SCTundy
    SCTundy New Member
    I got it. Had to go into amp settings and change to all
    TNDRA6!9 and BR73 like this.
  4. Dec 16, 2024 at 7:41 AM
    #2524
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    Gents, I just installed the G13 this weekend in my 2018 Platinum, which came with the JBL. I love the look but I have a slight problem with the audio. There is a slight hiss when audio is playing (mainly tested with CarPlay). It is very noticeable when you are at the end of a song and beginning of another, you will hear the hiss, then dead quiet between the songs, and then when the second song starts you hear the hiss come in. So its not constant, only when there is audio output.
    Things I have tried:
    • I made sure to use the ground wire during the install, its currently grounded to one of the four bolts that mount in the radio.
    • I have played with the settings on the unit, including disabling the "loudness" function in the equalizer, as well as enabling it and trying various settings.
    • I have gone into the factory settings menu, and changed the amp gain from the factory 0dB to various settings, all the way down to -15dB and this doesn't fix it. I can tell its adjusting the gain though, because the max volume on the radio changes signficantly when I do this.
    Any more thoughts guys? I am really hoping to fix this.
  5. Dec 25, 2024 at 2:12 PM
    #2525
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Thank you for the links. Santa dropped off my Dasaita g13 this morning. I don't see a g13 mic adapter on Dasaita's web site. Will the g12 one work? I also see some people are buying adapters to use they factory gps antenna opposed to the one that comes with the head unit. What does the gps antenna actually do? I'm wondering if that's something I'd actually need? I don't use XM or anything like that. Thank you for any input gents
    BR73 likes this.
  6. Dec 25, 2024 at 3:25 PM
    #2526
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    The G12 adapter will work with the G13
    purplenova likes this.
  7. Dec 25, 2024 at 4:22 PM
    #2527
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Sick, thanks man! I'll order it up. Is the Dasaita head unit able to toggle between front and rear cameras at anytime?
    BR73 likes this.
  8. Dec 25, 2024 at 4:23 PM
    #2528
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    I only have the rear camera that works when the truck is in reverse
    18DCTRD[QUOTED] likes this.
  9. Dec 28, 2024 at 8:04 AM
    #2529
    drgordon13
    drgordon13 New Member
    2020 Gray Tundra TSS
    Well...we got trouble...unit was working perfectly and I love it...however...rode to a friends house everything worked fine...started truck up to leave and black screen with no lights on the unit working...turned truck off and on and NOTHING!!!! Where do I begin to troubleshoot???
    BR73 likes this.
  10. Dec 28, 2024 at 8:25 AM
    #2530
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Start by checking the fuse to the unit then maybe pull it out and check the power wire
  11. Dec 28, 2024 at 9:03 AM
    #2531
    drgordon13
    Well...I tried the little reset button...pushed it for about 5 seconds and the lights flashed and the unit reset and worked on my drive to Academy and back...we shall see!
    bulldog93 likes this.
  12. Dec 28, 2024 at 9:16 AM
    #2532
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    So it definitely has power
  13. Dec 28, 2024 at 10:35 AM
    #2533
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    My experience with Dasaita is they’re very buggy. I switched to Joying and at least the one I have seems to be more solid.
    Yours probably got locked up in boot up or something. Glad the reset button worked!
  14. Dec 28, 2024 at 11:13 AM
    #2534
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Just bought this unit and it’s on its way. I have front and rear cameras on my truck, does the unit come with all adapters to connect both cameras or do I need to buy something extra?
  15. Dec 28, 2024 at 11:24 AM
    #2535
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Yes, they come with RCA connectors for front/rear cams
    GELCW likes this.
  16. Dec 28, 2024 at 1:35 PM
    #2536
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Thank you
  17. Dec 28, 2024 at 1:40 PM
    #2537
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    I have a platinum so it has the JBL system. Based on so many pages I also need to order of these adapters? Is that correct?
    BR73 likes this.
  18. Dec 29, 2024 at 2:30 PM
    #2538
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Installed the Enfig mic in the overhead slot and added the SIM card to my Dasaita Android 13
  19. Dec 31, 2024 at 12:39 AM
    #2539
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    I just ordered these same 2 items. I don't think it is model trim specific, but an upgrade to any Dasaita head unit. Based on the reading I have done, seems like it would be worth the purchase. I should receive them by the end of the week then I can finally install my G13 head unit.
    GELCW[QUOTED], Norfolk757 and BR73 like this.
  20. Dec 31, 2024 at 5:12 AM
    #2540
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Me too, received headunit yesterday and still waiting on these two items. Not sure how long it takes from China, bit I will be patiently waiting
  21. Dec 31, 2024 at 5:38 AM
    #2541
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I was just about to ask you if the G12 worked with the 13...
    Did you order the adapter directly from Dasaita or elsewhere?
    It appears you purchased the enfig mic "Housing only"
    Im also going to order both. Thanks for the info !!!
    Happy New Year !!!
  22. Dec 31, 2024 at 6:00 AM
    #2542
    purplenova
    Tom
    Ohio
    Lnguy79 and Norfolk757 like this.
  23. Dec 31, 2024 at 1:40 PM
    #2543
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
  24. Jan 1, 2025 at 12:28 PM
    #2544
    TNDRA6!9
    TNDRA6!9 New Member
    Leo
    2017 Tundra TRD
    I haven't had a chance to install the adapter. I have been using CarPlay/iPhone. And, it's much better than the old head unit. So, I am in no rush. I have been installing new headlights and taillights. So, I've been working on a hyper-flash issue. But, I am impressed with this new head unit and I am sure I haven't even scratched the surface of what it can do. The stereo was a 100% upgrade and it sounds SO much better. I recently replaced my puddle lights and license plate lights with LEDs and now when I hit the brake the head unit goes into dark mode. So, I am troubleshooting that as well.
    I got these two adapters.
    https://www.amazon.com/dp/B0BVPBPB1X
    https://www.amazon.com/dp/B0CBP5TQ6Z
    https://youtu.be/eIYHAqqELyw?si=g9OVoNUx8d3VlyfW
    Norfolk757 likes this.
  25. Jan 1, 2025 at 1:00 PM
    #2545
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    ive been thinking about getting a new HU and its between this as most people get it or a tesla style (no company or brand specific).
    my thing is i have XM and all i use for music unless traveling sometimes ill play cds or use an old ipod. also use nav.
    so main question is does it HAVE to be connected via carplay etc to even use apps like nav and xm? i dont like having to connect my phone to my truck.
    thanks for any info
  26. Jan 1, 2025 at 1:59 PM
    #2546
    Jjeielrod
    Jjeielrod New Member
    Joseph
    2013 Blk Crewmax 4x4
    Not sure if it's been addressed, but does it work with the backup camera as well?
  27. Jan 1, 2025 at 3:02 PM
    #2547
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    if you're asking if the Dasaita Head Unit works with the factory back up cam, then yes it
    does. Happy New Year and welcome to the forum
    Jjeielrod[QUOTED] likes this.
  28. Jan 3, 2025 at 12:58 PM
    #2548
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Got it installed! Have a few hiccups that I’m still working on.
    1. Additional Cables - I ordered the two cables that everyone was speaking about, it when I opened the radio box I already had one in there! Ugh, guess I should have looked first. I double checked that it is the exact same as the one I ordered.
    2. Cam-bus - I didn’t have to switch out the cam-bus since both sets came with one. My truck is a 2018, so I used CB004.
    3. Grounding - I’ll be honest it took me awhile to install it but it’s not that bad. I did have a little issue with installing the grounding on the back radio bolt, I had to crimp the grounding to keep it in place. It kept coming off.
    4. Cameras - I had previous installed a front camera and I was able to connect it to the radio so both the front and rear cameras work.
    5. Electric start - The previous owner installed an Automate model 7145A. It works fine, I know there were a few stating that electric start doesn’t work with the radio, but I have no issues.
    6. Gray Cable - had a gray cable left over from the original radio and not sure where that goes. Any ideas?
    7. Refuel Notification - not sure if anyone else has that notification, but I have never seen that before and I have 3/4 of a full tank. Any ideas on why?
    thanks everyone
  29. Jan 3, 2025 at 2:16 PM
    #2549
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    bulldog93, Norfolk757 and 18DCTRD like this.
  30. Jan 3, 2025 at 6:01 PM
    #2550
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    When hooking up a front camera, is it powered through the head unit or does it need a separate 12v source?
