Neutral Safety Switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra179422, Dec 28, 2024.
  1. Dec 28, 2024 at 1:36 PM
    Tundra179422
    Tundra179422 [OP] New Member
    Kansent
    Good evening, I currently have a 2018 4WD 1794 Tundra. I was having issues with the dash gear lights not lighting up and reverse lights. The check engine light came on, took to AUTOZONE they advised possible neutral safety switch. I kept driving car with check engine light for over a month until the car would not start one morning, checked battery and it was good, i went ahead and replaced the PNP (neutral safety switch). The replacement worked as car turned on and all check engine lights turned off. About a week later the car is doing same issue, it will not turn on, I went ahead and used warranty for another neutral safety switch just in case defective. Any other input what it can be?
  2. Dec 29, 2024 at 6:11 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Have you checked your fuses in both locations?
  3. Dec 29, 2024 at 9:25 AM
    Tundra179422
    Kansent
    thanks for the reply, besides starter fuse and relay any other I should check? I also checked IG1. The fuse and relay label does not inidcate any fuse for PNP. (Neutral Safety Switch)
  4. Dec 29, 2024 at 9:50 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Did you try putting it in neutral then start it ?
  5. Dec 30, 2024 at 9:00 PM
    lr172
    lr172 New Member
    07 DC
    I would check wiring an connector at the nss for corrosion.
