Tacoma OEM wheels first gen tundra
Discussion in '1st Gen Tundras (2000-2006)' started by 03tunradude, Dec 30, 2024.
  1. Dec 30, 2024 at 11:57 AM
    03tunradude
    03tunradude [OP] New Member
    2003 TUNDRA
    Anyone running these on their first gen tundra? I do not have my truck currently and not sure if they fit. Before I buy them .
    They are Off a 2012 Tacoma.
    Thanks
    these are 265/65r/17
    I currently am running 265/70r/16
  2. Dec 30, 2024 at 12:26 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Those are 4th gen T4R wheels I think. Some super Chinese junk rubber too.
    G_unit3000 likes this.
  3. Dec 30, 2024 at 12:28 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  4. Dec 30, 2024 at 12:37 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Yes they fit, off memory they sit inward about 15mm more than the stock wheel i believe which is barely over a half inch.
    This wheel was on the 4th gen 4R and 2nd gen Tacoma.
    The lug pattern and all is fine, it will bolt right up
  5. Dec 30, 2024 at 12:37 PM
    03tunradude
    2003 TUNDRA
    thanks for the thread! Looks like someone has used them, guy is selling all 4 for 100 bucks. I just want the wheels. I will get new tires. just not sure what size tires, and what guys are running- if they have these wheels. i appreciate u thanks
  6. Dec 30, 2024 at 1:02 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    with +15mm offset from stock wheels. You may or may not need spacers to clear. Depending on what size tires you go with. If you keep it stock sizes I'm guessing it should be fine.
  7. Dec 30, 2024 at 1:05 PM
    The backspacing is not favorable. I don't recommend buying them unless you plan on installing wheel spacers. They'll tuck the tire in farther than stock, and there's risk of suspension rub. Others have had issues in the past.
    Mr Badwrench likes this.
  8. Dec 30, 2024 at 1:06 PM
    Those tires are actually decent. I ran a set of Maxxis Bighorn mudders on my truck for 40k miles or so. Legit company that also makes really good bicycle tires. Made in Taiwan I believe.
    shifty` likes this.
