2021 Tundra lock problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by vmoss0363, Nov 16, 2024.
  1. Nov 16, 2024 at 4:23 PM
    vmoss0363
    vmoss0363 [OP] New Member
    Van
    Upstate South Carolina
    2021 Tundra SR5
    I have a 2021 Tundra that I bought new. Recently I've been having a problem locking it. The lock sensors on the front door handles don't work and I have to push the lock button on the fob repeatedly to lock it. The unlock sensor on the door handle and the unlock button on the fob both work fine. This occurs with both the key fobs and the key fob batteries are fresh.
  2. Nov 16, 2024 at 4:51 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Have you installed aftermarket led light bulbs at all?
  3. Nov 16, 2024 at 4:55 PM
    vmoss0363
    Van
    2021 Tundra SR5
  4. Nov 16, 2024 at 4:58 PM
    MadMaxCanon
    Probably just a bad sensor, do you still have warranty?
  5. Nov 16, 2024 at 5:01 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    How strong is the battery on your fob?
    my '21 senses me from quite a distance
    MadMaxCanon likes this.
  6. Nov 16, 2024 at 5:23 PM
    vmoss0363
    Van
    2021 Tundra SR5
    I have an extended warranty. The batteries are not as fresh as I thought. Read slightly below 3 volts. I will get new ones tomorrow and see if it makes a difference.
  7. Nov 17, 2024 at 3:14 PM
    vmoss0363
    Van
    2021 Tundra SR5
    I replaced the batteries in the key fobs. They work better than they did but still don't lock consistently with the key fob or the door lock sensor. I have a 2011 Prius and I've never had a problem locking it with the key fob or the door lock sensor.
  8. Nov 17, 2024 at 4:16 PM
    MadMaxCanon
    Gotta be a weak sensor receiver or something. How old is your car battery
  9. Nov 17, 2024 at 4:20 PM
    vmoss0363
    Van
    2021 Tundra SR5
    It's the original battery. Starts and runs the truck fine.
  10. Nov 17, 2024 at 4:28 PM
    MadMaxCanon
    It could be on its way out though. Do you have a meter you can check the voltage when starting?
  11. Nov 17, 2024 at 4:55 PM
    vmoss0363
    Van
    2021 Tundra SR5
    i do have a multi meter but no way to hold the probes on the terminals and start it.
  12. Nov 17, 2024 at 5:59 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    It could be an actuator going out….
  13. Dec 29, 2024 at 2:00 PM
    vmoss0363
    Van
    2021 Tundra SR5
    I finally found out what was causing my issue with the door locks. LED bulbs in the map lights. I put some LED bulbs in the map lights pretty soon after I bought the truck and never had a problem. I bought some brighter LED bulbs for another vehicle I have a couple of months ago and replaced the ones in my Tundra with the new ones also. That's when the problem started but I didn't realize that the new bulbs were causing the problem. Put the old ones back in today and the locking problem disappeared.
    Ponderosa_Pine likes this.
  14. Dec 29, 2024 at 2:30 PM
    DoublePro
    DoublePro New Member
    What brand led causes the problem? So we can stay away.
  15. Dec 29, 2024 at 2:41 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I have vleds and zero locking problem on my 2021.
  16. Dec 29, 2024 at 2:52 PM
    vmoss0363
    Van
    2021 Tundra SR5
    Super Bright LEDS
  17. Dec 29, 2024 at 3:42 PM
    MadMaxCanon
    Cheap Amazon LEDs for licenseplate lights caused my cameras to act funny also. Put the regular stock ones in and they work perfectly now.
    DoublePro likes this.
