Help with these codes
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cam_619_SD, Dec 29, 2024.
  1. Dec 29, 2024 at 11:11 AM
    Cam_619_SD
    Cam_619_SD [OP] New Member
    Cameron
    2019 tundra crewmax
    Man! Got in the truck and dashboard LIT UP! no idea what these mean/are tried googling and a ton popped up. Anyone on here experience this? Funny thing is I haven’t towed anything with this truck since I got it 8 months ago so I’m confused.
  2. Dec 29, 2024 at 11:29 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I'd bet money it's a slew of "Me too" codes. Basically, one computer throws out a trouble code, and the rest of the various computers on the CAN communication line throw up a code saying "Look at that guy, he's got something wrong." I think the most common cause of all these is a malfunction in the brake controller, which is usually fixed by a reflash. But don't take the brake controller suggestion as gold, there are plenty of other possible causes. My '15 displayed similarly a few months back because of a momentary loss of communication with the gauge cluster. I had codes in the ABS/Trac computer, engine ECM, and various others all saying loss of communication in the gauge cluster. At the end of the day, it'd be best to get it into the shop and get the codes read.
  3. Dec 29, 2024 at 1:39 PM
    Cam_619_SD
    Cameron
    2019 tundra crewmax
    Thank you!
    250000yota[QUOTED] likes this.
  4. Dec 29, 2024 at 2:32 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    These are the exact two error messages I had last week on my Tundra. Check your under hood wiring carefully for rodent damage. Rats chewed up the fuel injector wiring harness on the passenger side of the engine. Replaced that and all error messages cleared.
  5. Dec 29, 2024 at 2:34 PM
    Cam_619_SD
    Cameron
    2019 tundra crewmax
    Stupid question but would this have anything to do with me switching out the old grill/insert? I’m thinking the collision control maybe?
  6. Dec 29, 2024 at 2:36 PM
    JDR76
    JDR76 New Member
    WA
    Anything is possible. When did you swap grilles?
  7. Dec 29, 2024 at 2:42 PM
    Cam_619_SD
    Cameron
    2019 tundra crewmax
    About 2 weeks ago. TSS sensor and all.
  8. Dec 29, 2024 at 2:46 PM
    JDR76
    JDR76 New Member
    WA
    I’d start there. Maybe double check the radar connector. I’ve had that issue before as well.
  9. Dec 29, 2024 at 2:58 PM
    Cam_619_SD
    Cameron
    2019 tundra crewmax
    Right on. Thank you brother
    JDR76[QUOTED] likes this.
  10. Dec 29, 2024 at 6:29 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Yeah I was gonna say those codes look like the TSS sensor codes. I’ve seen similar in snow storms when the sensor is blocked, also if something is covering it like a bull bar.
  11. Dec 30, 2024 at 8:20 AM
    Cam_619_SD
    Cameron
    2019 tundra crewmax
    Yeah I’ve got the sensor vinyl’d black but it’s worked for weeks now there seems to be a problem?
