what is the best power steering fluid for gen 2 tundra 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by OLDTIMER, Mar 31, 2021.
  1. Mar 31, 2021 at 1:16 PM
    OLDTIMER
    OLDTIMER [OP] New Member
    stock 2010 tundra sr5 5.7 flex fuel
    None
    What is the best power steering fluid for gen 2 5.7 Manual calls for dextron 2 or 3 which has been superceeded with dextron 6
  2. Apr 8, 2021 at 9:07 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    You can use the superseded versions.
  3. Apr 9, 2021 at 1:47 AM
    KingKong
    KingKong New Member
    Asher
    2008 Super White Double Cab Long Bed 4x4
    I just buy the OEM stuff off Amazon
  4. Jun 19, 2022 at 10:33 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    What is the OEM stuff? A quick search just shows ATF.
    YardBird likes this.
  5. Jun 20, 2022 at 10:14 AM
    KingKong
    KingKong New Member
    Asher
    00718-ATF00 is the part number for it.
    Joe333x[QUOTED] likes this.
  6. Jun 20, 2022 at 1:01 PM
    Joe333x
    Joe333x Member
    Boston
    Thats ATF though, so it will be red unlike whatever comes in there from the factory.
  7. Jun 20, 2022 at 1:31 PM
    KingKong
    KingKong New Member
    Asher
    The fluid used in the power steering loop is Toyota 00718-ATF00 ATF. It's what's specified in the manual and even on the power steering fluid reservoir cap. These pumps don't use a "power steering fluid." Fluids change color over time and heat cycles/use, so it's probably not red anymore.
  8. Jun 20, 2022 at 2:36 PM
    Joe333x
    Joe333x Member
    Boston
    My manual just says use Dexron II or III. Cap doesn't say anything about type of fluid. Truck only has 33k on it and pulling the cap you can tell the fluid was never red.
  9. Jun 20, 2022 at 3:13 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    Whatever the cashier says at advance auto parts..
    Works fine. Changed about 5yrs ago, wheel still turning.
    :drunk:Oh oh o-...o'riley? Auto parts AYY!!!:yay:
    FrenchToasty, WVI and Joe333x like this.
  10. Jun 20, 2022 at 3:20 PM
    MGMTundra18
    MGMTundra18 New Member
    Charlotte NC
    2018 MGM Tundra 4x4 TRD Sport
    I just did a flush with Valvoline Max Life ATF (Dex III ATF), she’s cherry red.
    WVI and Piki like this.
  11. Jun 20, 2022 at 7:01 PM
    KingKong
    KingKong New Member
    Asher
    Which is exactly what the formulation of 00718-ATF00 ATF is. Literally says "Formulated to replace Dexron II or III in applicable Toyota models. Please consult your owner's manual to ensure the correct application," and the manual calls for Dexron II or III. Cap should say Dexron II or III. Found this on another forum, "Don't let the Red "dye"color of Dexron ATF fluid throw yu off. Even though factory fill is not red, Dexron is the recommended fluid." Here's the link: . @ViktorG could you chime in on this please.
    WVI and Joe333x[QUOTED] like this.
  12. Jun 20, 2022 at 7:06 PM
    KingKong
    KingKong New Member
    Asher
    Joe333x and WVI like this.
  13. Jun 21, 2022 at 11:26 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    That is the correct fluid to use in the Tundra power steering system.
    KingKong[QUOTED] and Joe333x like this.
  14. Jun 26, 2022 at 9:00 PM
    Joe333x
    Joe333x Member
    Boston
    Thanks for the info guys, I guess the only thing that's confusing is what vehicle that ATF fluid is even meant for? I wouldn't think Toyota made a transmission that requires Dexron so did they make this simply to replace power steering fluid?
    EDIT: I answered my own question with some googling, it appears some older Toyota did spec for Dexron II.
    https://bobistheoilguy.com/forums/threads/dexron-ii-for-my-02-4runner.308664/
    Also it seems Mobile has caught on that Toyota Specs for Dexron II or III in the power steering since the back of this bottle actually read that it is a replacement for that. Considering the Mobile 1 and Toyota Fluid are about the same price, I'll just pick up some of the Toyota stuff.
    WVI likes this.
  15. Jul 2, 2022 at 11:41 AM
    Joe333x
    Joe333x Member
    Boston
    Hey guys thanks for all the info and it seems Toyota has now taken measures to make it a little less confusing. The new packaging for 00718-ATF00 now says ATF and Power Steering Fluid.
    bulldog93, KingKong, Sumo91 and 2 others like this.
  16. Jul 8, 2022 at 11:49 AM
    KingKong
    KingKong New Member
    Asher
    Glad to help man!
    Joe333x likes this.
  17. Jul 13, 2022 at 2:52 PM
    SFTundra
    SFTundra New Member
    Jimmy
    So Toyota is the best fluid versus Mobil one, or the other name brand fluids?
  18. Jul 13, 2022 at 3:01 PM
    SFTundra
    SFTundra New Member
    Jimmy
    Is it a myth about synthetic oil damaging the seals?
    Leo's first likes this.
  19. Jul 13, 2022 at 3:55 PM
    Joe333x
    Joe333x Member
    Boston
    I don't know if it's the best but it's the only one that actually meets the requirements that makes sense since the manual says dex 2 or 3 and those are not produced anymore so now you can only buy fluids that say they meet everything. This is the only one that says it just meets dex 3 for Toyota psf and atf. Can you use any other atf? Probably, id be willing to bet dealers throw WS in there but this stuff is cheap enough that to me it didn't make sense not to use it.
    Tsm503 likes this.
  20. Jul 14, 2023 at 1:44 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    How much per quart was it? And is it red like typical ATF?
  21. Jul 14, 2023 at 2:25 PM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    I went through this with my daughters 07 FJ. Never could get a correct answer. Is the 00718-ATF00 good for the FJ also? I went to several auto parts store and everybodys answer was different and they seemed to be guessing.
  22. Jul 14, 2023 at 8:53 PM
    Joe333x
    Joe333x Member
    Boston
    I paid around $10 a quart about a year ago. It is red.
    If the manual calls for Dex III then yes.
  23. Dec 29, 2024 at 8:01 AM
    2010SR5NIC
    2010SR5NIC New Member
    2010 Salsa red pearl DC
    Dobinson lift front and rear, SPC UCA’S, icon add a leaf, coach builder shackles, 18x8 method wheels with 295/75 falken wildpeaks.
    I copied and pasted that part number and I can’t find that exact bottle. I want it to say psf too but the ones I find only say atf.
  24. Dec 29, 2024 at 10:09 AM
    Joe333x
    Joe333x Member
    Boston
    If you order it from a dealer it will more than likely look exactly like this. I ordered it not expecting it to say power steering fluid on it but was surprised when it did. Regardless it's the same fluid, they just changed the label. I purchased that box online from Fred Anderson Toyota. As you can see they still show the old bottle label but have it listed as power steering fluid as well. https://autoparts.fredandersontoyota.com/products/product/automatic-transmission-fliud-00718atf00
