  1. Dec 28, 2024 at 10:38 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    May as well go for a grilled BLT. :stirthepot:
  2. Dec 28, 2024 at 10:40 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My brother will eat anything for breakfast other than thin, brothy soups. His girlfriend is a strong proponent of only traditional breakfast foods for breakfast.
  3. Dec 28, 2024 at 10:41 AM
    NWPirate
    Zach
    WA
    Your mountains don't even have that much yet?? :eek2:
  4. Dec 28, 2024 at 10:42 AM
    Would.
  5. Dec 28, 2024 at 10:43 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Dec 28, 2024 at 10:45 AM
    Oh I’m sure they do. This was expected overnight
  7. Dec 28, 2024 at 10:53 AM
    NWPirate
    Zach
    WA
    Ah, gotcha
  8. Dec 28, 2024 at 11:04 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    She hates it when I eat cold leftover pizza from the night before for breakfast...:eek2:
    No imagination..:thumbsup:
  9. Dec 28, 2024 at 11:05 AM
    Cold pizza for breakfast was a staple for me growing up. Love it.
  10. Dec 28, 2024 at 12:05 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I may have to pick up some pastrami. :drool:
  11. Dec 28, 2024 at 12:29 PM
  12. Dec 28, 2024 at 1:15 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My dad used to travel a lot for work and he would always buy a bottle of whisky on his way through duty free, even though he doesn't drink a ton. I'm not sure how good it used to be right off the shelf but we discovered that Seagram's VO is pretty good after it's been aged in the basement 20+ years.
  13. Dec 28, 2024 at 2:34 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  14. Dec 28, 2024 at 2:48 PM
    Why do his fingers look like wrinkly scrotum skin? It's odd detail given the lack of detail in the rest of the cel.
  15. Dec 28, 2024 at 2:57 PM
    French Avocado
    Utah / Wyo
    @Zeus or other electrical wizards:
    I have a circuit that has shut down. I believe that it splits into two GFIC circuits. I thought it was one of the GFIC outlets so I replaced it but still no power. I am frustrated and open to suggestions from the most knowledgeable group I know. Thanks
  16. Dec 28, 2024 at 2:58 PM
    @bmf4069 @NWPirate
  17. Dec 28, 2024 at 4:06 PM
    NWPirate
    Zach
    WA
    This has me perplexed.. can you explain a little more?
    Usually there's only one GFI on a circuit. You can have more than one on a circuit if the wires are all on the Line side
  18. Dec 28, 2024 at 4:10 PM
    Azblue
    The Dirty T ( ^_^)_且
    I have 2 bathrooms, only one has a GFI plug. If that plug trips, the outlet in the other bathroom is dead.
  19. Dec 28, 2024 at 4:15 PM
    NWPirate
    Zach
    WA
    That's pretty standard, most new houses run separate circuits now
  20. Dec 28, 2024 at 4:19 PM
    French Avocado
    Utah / Wyo
    First - all electricians should provide a list for each circuit breaker as to every outlet and receptacle on the circuit. A small notation of a room is insufficient.
    Second - in my panel there is a notation for one 20 amp circuit breaker that reflects “Gfic outlets garage”. I have three GFIC outlets in the garage along with other outlets. At least one of the GFIC outlets is clearly not on that circuit.
    Third - I have too much garbage in my garage and need a spring cleaning with a dumpster.
  21. Dec 28, 2024 at 4:20 PM
    Do you know where that line leads to? Did you test the GFI?
    AZBaldy and Azblue like this.
  22. Dec 28, 2024 at 4:22 PM
    French Avocado
    Utah / Wyo
    Completely dead.
    Between the panel and the GFI I do not know if there are other outlets or receptacles (reason for point 1). There are load outlets after the GFIC but not certain which ones.
    AZBaldy and T-Rex266[QUOTED] like this.
  23. Dec 28, 2024 at 4:28 PM
    https://www.homedepot.com/p/Milwaukee-Circuit-Breaker-Finder-w-LED-2222-20/329877364
    AZBaldy likes this.
  24. Dec 28, 2024 at 4:32 PM
    NWPirate
    Zach
    WA
    The Line side is dead with the breaker on?
    AZBaldy and T-Rex266 like this.
  25. Dec 28, 2024 at 4:32 PM
    Unless @NWPirate disagrees, you can begin testing other outlets to see what has power around it. If it has power, probably off a separate line. If it’s dead, same line. Pull off that outlet and check connections. GFi’s can also go bad (from what I’ve read before)
    AZBaldy likes this.
  26. Dec 28, 2024 at 4:56 PM
    French Avocado
    Utah / Wyo
    AZBaldy, GODZILLA, 1lowlife and 2 others like this.
  27. Dec 28, 2024 at 4:59 PM
    French Avocado
    Utah / Wyo
    Correct
  28. Dec 28, 2024 at 5:02 PM
    NWPirate
    Zach
    WA
    Well that's not right :monocle:
    Did you test it with a meter or just the GFI button?
  29. Dec 28, 2024 at 5:03 PM
    Hmmm
    You can get a line tracer and find it that way (to see what else it ties into)
    AZBaldy likes this.
  30. Dec 28, 2024 at 5:14 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Intriguing that that's where your thoughts went first...
