CarPlay Issues
Discussion in 'Audio & Video' started by cmo630, Dec 26, 2024.
  1. Dec 26, 2024 at 4:47 PM
    cmo630
    cmo630 [OP] New Member
    2021 Tundra Nightshade
    Ok, so my CarPlay issues include:
    1. phone calls are delayed. Once I speak, it takes a few seconds for my message to be relayed. So there are long gaps in conversations
    2. Call recipient says it’s difficult to understand me. Lots of crackling.
    3. During the call, the call timer will remain at 0:01. the Once I hang up, the call timer will go through the sequence until it hits the minute & second length of the call. No other features on CarPlay will work until it goes through this sequence
    I just tried the software update and it didn’t help. Traditional Bluetooth calls and Siri voice command text work perfect. Any suggestions are appreciated. I use CarPlay phone & text for work as I spend some time in the truck. Local shop said they can install aftermarket for around $850. Thanks in advance for your knowledge & input!
  2. Dec 26, 2024 at 5:10 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Do you use any of the aftermarket wireless Apple carplay devices? I use one and assumed that the delay in my spoken messages were due to that device.
    BTW, Welcome from LA (Lower Alabama)!
  3. Dec 27, 2024 at 5:42 AM
    cmo630
    Morning, Bakershack. Thanks for the welcome words! I’m in north central WV (home of Nick Saban).
    I’m not using any after market adapters. Mine is the original equipment in the truck.
    I did have an f150 w carplay and it was flawless. The turbo engine however, was not flawless. But the tech in ford was way better.
    Called the local audio shop and they rough quoted $850 for new in dash multimedia w CarPlay. I’m sure there’s other options, but the primary goal is to fix the one I have if possible.
  4. Dec 27, 2024 at 6:11 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    The only issue I have had with my 2020 platinum is when using a non-Apple cable. Can’t remember exactly what it did, but I would definitely have issues with aftermarket cables
  5. Dec 27, 2024 at 6:20 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You said you did a software update, but didn’t specify:
    1. Phone software update
    2. Radio over-the-air update
    3. Radio downloaded update using USB
    Each of those is different. Also would be helpful to know if you have the JBL audio or not.
    There were download/USB updates to specifically address several CarPlay issues, though I haven’t kept up on if there are any newer ones since I swapped to the Alpine. Over-the-air updates were not the same.
    And there are times when new IOS updates will cause screwy behavior in CarPlay (though 18.1.1 has been solid for me)
  6. Dec 27, 2024 at 6:27 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
  7. Dec 27, 2024 at 3:00 PM
    jmanscotch
    jmanscotch New Member
    Jake
    2020 Tundra TRD OR CM
    For the past few months, I’ve been having issues with phone calls through Apple CarPlay. They’re choppy, just audio cutting out ever 1-3 seconds. When I finally unplug to take the call normally, the Tundra screen freezes for 10-30 seconds and then the whole system reboots.
    For me, it’s just the phone calls, everything else works perfectly.
    I’m using a nice Anker cord, but have been meaning to buy a genuine Apple one as I’ve tried everything (confirmed it wasn’t my phone or iOS, tried a radio update though none were available, tried another random cord) and it hasn’t help.
    It’s driving me nuts.
    @RainMan_PNW Is there a procedure for the radio update via USB? Download something from Toyota and DIY or dealership visit?
    **found it**
    https://www.toyota.com/firmware-updates#
    Input vehicle information at the top of page and verify availability of updates. If updates are available, follow these instructions:
    Will try (as soon as I find an old USB) and report back.
    gabrenas likes this.
  8. Dec 27, 2024 at 3:23 PM
    CementCrew20
    CementCrew20 New Member
    I had a lot of CarPlay issues as you've described when I updated to iOS 18. I checked for software updates on the head unit and it always said there were no new updates. However when I went to the Toyota site (https://www.toyota.com/firmware-updates/updates) to check on the latest versions of the Audio and Navigation systems I found that my radio was well out of date. I downloaded the updates to a flash drive and updated the head unit that way. I haven't had any issues with CarPlay since I updated it.
    Also, I had to format the flash drive to Fat32 as the file system to get the vehicle to recognize the flash drive to perform the updates.
    Simple Man AZ and jmanscotch like this.
  9. Dec 27, 2024 at 3:31 PM
    RainMan_PNW
    Casey
    Clark County, WA
    It can be done DIY.
    https://www.tundras.com/threads/rainmans-2021-lunar-rock-trd-pro-build.77317/page-19#post-2704949
    2wheeledfaith likes this.
  10. Dec 27, 2024 at 3:51 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Why doesn’t Toyota push these updates?
  11. Dec 27, 2024 at 4:18 PM
    cmo630
  12. Dec 28, 2024 at 3:07 AM
    Creepbam
    Creepbam New Member
    2020 SR5 4x4
    Ive been having the same phone call issues. Everything else works great except calls. For what its worth I have a Anker cable also which I've used since the truck was new with no issues until past few months.
  13. Dec 28, 2024 at 5:12 AM
    cmo630
    I’m using Apple cords. I always put the original cords in the vehicles because no one uses them at home.
    though I’ve had issues sporadically in the past, it got really bad about a month ago. Looking back at iOS release dates, 18.1 was released Oct 28.
    I installed 18.2 last night. I’ll try that in the truck today and see if it works.
    all that being said, I’ve updated the Toyota software and I’m using an Apple cord.
  14. Dec 28, 2024 at 6:41 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Several of us have moved to a wireless CarPlay dongle/adapter... I think it has a $20 coupon as well, so only $59 right now....
    https://www.amazon.com/gp/product/B09Q176WHH?ie=UTF8
    I have this installed on my '21 Pro and the wife has one in her '22 Forester (both vehicles came only w/wired CarPlay).
    When I used the wired method in the past it would drop calls, have trouble re-connecting after turning off the vehicle, music cutting in and out, etc...
    After we started using the dongle, its been a much more seamless experience; there is still the occassional connectivity issue (as w/any device), but it's only a fraction of what it used to be.
    Might be a good alternative for you to try if you're wanting to avoid swapping out the head unit right now :thumbsup:
    Here's a link to a recent thread w/similar issues and feedback on the above unit. I believe the OP and a few others in their tried this unit and had good luck w/it...
    Apple CarPlay Issues on Stock Head Unit
  15. Dec 28, 2024 at 7:23 AM
    JohnWhicker
    JohnWhicker New Member
    You need to try another phone all together and eliminate one of them. Could be the HU or the Phone or the cable.
  16. Dec 28, 2024 at 9:27 AM
    Clemsonman14
    What kind of iPhone do you have OP? Just wondering if it is a really old model that may causing some of your issues
  17. Dec 30, 2024 at 7:46 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I've been having the same problems with audio cutout and lag as described here in the OP. It drives me insane, becasue if I take a call and it's all messed up once I unplug my phone it is perfect if I'm only using the phone. I'm going to try to do an update on the headunit as I haven't ever done one.
  18. Dec 30, 2024 at 8:19 AM
    cmo630
    I have an iPhone 14 and just downloaded 18.2 update. I’m thinking it could be related to the updates.
  19. Dec 30, 2024 at 9:04 AM
    Clemsonman14
    Interesting. I have the 16 and have not gone to 18.2 yet. Currently on 18.1.1. Makes me a little weary because I haven’t ever had any CarPlay issues with this phone or my 12 that I traded in
  20. Dec 30, 2024 at 9:54 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    I have an iphone 15 pro max, IOS 18.2
  21. Dec 30, 2024 at 12:22 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    I just installed the current update from the Toyota website and everything works exactly as it should. Easy fix for me.
    CementCrew20 and jmanscotch like this.
  22. Dec 30, 2024 at 3:25 PM
    jmanscotch
    Jake
    I got to test mine today, after the update via USB, and am able to confirm it fixed my CarPlay call issues.
    iOS 18.2 on a iPhone 13. My issues started at like the first version of iOS 18.
    CementCrew20 likes this.
  23. Dec 30, 2024 at 3:38 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    I would agree and say that's about when my issues started.
    jmanscotch[QUOTED] likes this.
  24. Mar 18, 2025 at 2:31 PM
    Simple Man AZ
    Simple Man AZ New Member
    2021 Platinum Crew
    Had the exact same issues / Head Unit will not show available updates if flash drive not formatted to Fat32 / Everything operating smoothly since the software update- Thank You CementCrew20
    DoublePro likes this.
  25. May 23, 2025 at 5:22 PM
    2wheeledfaith
    2wheeledfaith New Member
    I had the crackling and cutting out voice on CarPlay phone calls and after doing the update I saw on this post it's all working perfectly.
    SnrDisregardo and Tripleconpanna like this.
  26. Aug 21, 2025 at 3:42 PM
    Sequoyeah
    Sequoyeah New Member
    **found it**
    Will try (as soon as I find an old USB) and report back.[/QUOTE]
    Thanks for the link, jmanscotch. The dealer had no ideas when I had taken my Tundra in for other work, but then I found this thread in about four seconds and did the fix when I got home. Step it up, Toyota Plano.
  27. Aug 25, 2025 at 5:04 PM
    warunner
    warunner New Member
    WA
    2021 Limited DC
    I went from an iPhone 8 that worked perfectly with CarPlay to an iPhone 16 that was really spotty. I had the voice delay problem, and it rendered calling unusable. Did the ios updates, correct cable, resets on the phone and head unit to no avail. The USB update did the trick. I think it was version 1162.
    Tripleconpanna likes this.
