What is this part?
Discussion in '3rd Gen Tundras (2022+)' started by pyoung62, Dec 26, 2024.
  1. Dec 26, 2024 at 1:41 PM
    pyoung62
    pyoung62 [OP] Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    I know this has been posted before - I distinctly remember seeing the same pic earlier this year but can’t find the thread. I found this on my garage floor roughly under the right front wheel well area. A Google picture search says it’s a door plug, but nothing on my 2023 doors look anything like this. Could also be a floor plug. But I’ve scoured the bottom of the truck. 1) No empty hole. 2) I see two other sized floor plugs, one smaller than this and one bigger. But none this size. 3) This thing is really clean. One side is spotless like it’s never seen the light of day, so clearly the “inside”. But even the other side has no signs of any dirt whatsoever on it. No way it’s been exposed to road grime for a year like a floor plug would. Edge to edge, it’s 1 3/16” across. Based on what I believe to be the inside, it looks like it plugs a 3/4” hole. Any clues what and where?
  2. Dec 26, 2024 at 1:45 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    The tundra used to get plugs put in a couple of the lower control arms holes to stop the wind noise. Might be that.
  3. Dec 26, 2024 at 1:53 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Yeah, I found one in my driveway and my son and I couldn't for the life of us figure out which truck it was off of and where it goes. Nothing else has fallen off our trucks yet, so it must not be that important.
  4. Dec 26, 2024 at 2:01 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  5. Dec 26, 2024 at 2:04 PM
    SDT-Online
    SDT-Online New Member
    2024 Tundra Platinum (Red)
    The plug that covers the wheel bearing grease fitting on my utility trailer looks like that.
  6. Dec 26, 2024 at 2:06 PM
    pyoung62
    Paul
    Raleigh, NC
    Really interesting that he found it in the exact same place as mine near the front right wheel well area, and that his also looked to be in new condition like mine. I know mine didn’t come from any other vehicle as no other vehicle has ever been parked in my garage/workshop. The mystery continues…
    Tundrastruck91 likes this.
  7. Dec 26, 2024 at 4:15 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    Check behind the cab right where it meets the bed about a foot up from the bottom. Each side has a grommet similar to that.
  8. Dec 26, 2024 at 4:35 PM
    pyoung62
    Paul
    Raleigh, NC
    I see the ones you’re talking about. Similar, but not quite the same. Mine are both still in place. Those are a little bigger, and definitely get a little dirty from road grime. Plus a good six feet farther back from where I found mine on the floor. That’s the weird thing, how stinking clean this thing is to have just fallen out onto the floor after over a year and 11k miles.
  9. Dec 26, 2024 at 4:48 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Is there a plug like that on the passenger side firewall?? I know there's one on drivers side by brake booster. But if there's one on passenger side as well it could have popped out when closing door? Maybe?
  10. Dec 26, 2024 at 4:57 PM
    Wade23454
    Wade23454 New Member
    Wade
    2022 SR5 Double Cab 6.5’ bed
    TRD 3” lift, trac bar alignment block, katzkin leather seats, bed step, talon skid plates, rough country cat cover, airlift air bags
    I found the same plug in the same place under my truck a few weeks ago. 2022 SR5 with factory TRD lift. Spent a good amount of time trying to find where it might have fallen from to no avail.
  11. Dec 26, 2024 at 5:10 PM
    pyoung62
    Paul
    Raleigh, NC
    Just checked. There is one on both sides, but they’re a little smaller, and both are in place.
  12. Dec 26, 2024 at 5:11 PM
    pyoung62
    Paul
    Raleigh, NC
    Clean as a whistle too?
  13. Dec 26, 2024 at 5:12 PM
    Wade23454
    Wade
    Yes, clean as a whistle. And fell out where I park the truck is the most confusing thing. You would think it would fall out while driving over a bump or something.
  14. Dec 26, 2024 at 5:20 PM
    pyoung62
    Paul
    Raleigh, NC
    There’s no way it’s a coincidence that quite a few people have reported it in the exact same location and all like it’s a brand new part. This one’s going to drive my OCD through the roof. Problem is, since the thing is so clean, it’s likely not coming from a place that’s going to be easily seen from the underside, else it would be dirty. So I’m guessing more likely from the engine bay. And it’s tough looking around in there.
  15. Dec 26, 2024 at 5:22 PM
    pyoung62
    Paul
    Raleigh, NC
    And why the hell do they just fall out when the damn thing is sitting there overnight?
  16. Dec 26, 2024 at 7:15 PM
    DRP
    DRP Old Member
    Dave
    Drones from New Jersey are responsible.
  17. Dec 27, 2024 at 12:12 PM
    nbridgeman
    nbridgeman New Member
    24 Tundra Limited
    This is crazy. In Knoxville, in my driveway, 3 days ago see the same thing sitting in my driveway. Passenger side, probably mid door area of the front. Driveway has a bit of a slope so it could have rolled a foot easy towards the back.
  18. Dec 27, 2024 at 1:02 PM
    pyoung62
    Paul
    Raleigh, NC
    What I can’t believe is that as many people as have reported it, nobody has figured it out yet. It’s really consistent as far as where it’s found and that it’s usually pretty clean. And that it just magically drops off when the truck is parked. I’ve just begun the hunt.
  19. Dec 27, 2024 at 1:14 PM
    BillorJackorPeteorDennis
    BillorJackorPeteorDennis New Member
    Washington, DC
    ‘25 TRD Pro - Mudbath
    It's Toyota's answer to Elf on the Shelf. It's the Grommet To Make You Vomit!
    Sorry, too much Egg Nog. Er, or maybe not enough??? :cheers:
    Anyway, two 3rd Gen's have lived at my house and I haven't had the pleasure of finding one of these. Not yet at least.
  20. Dec 27, 2024 at 2:14 PM
    pyoung62
    Paul
    Raleigh, NC
    It took 14 months and 11k miles before I found mine. There’s still plenty of time for you.
  21. Dec 27, 2024 at 3:28 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Congratulations, your truck is now a man :cheers:
  22. Dec 27, 2024 at 8:41 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    'Subbed for answer
    TacomaTRD4x402 likes this.
  23. Dec 27, 2024 at 8:48 PM
    TacomaTRD4x402
    Southern California
    Me too and I don't even have a 3rd gen:popcorn:
  24. Dec 28, 2024 at 5:36 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My guess is these are temporary body plugs that get removed and misplaced during the manufacturing process.
    I also know that similar plugs are often removed from the frames in order to strap the vehicle down for transport, and the dealer is suppose to re-install them after delivery.
  25. Dec 28, 2024 at 6:36 PM
    pyoung62
    Paul
    Raleigh, NC
    I might buy the temporary plug theory if it weren’t for the fact that everyone reporting it has found it in nearly the exact same place under the right front wheel well/firewall area. That’s not a coincidence.
  26. Jan 1, 2025 at 10:23 AM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    Is that the same part? It's on a tailgate; both sides, by the hinges (did not remove it to cross reference to P/N).
  27. Jan 1, 2025 at 1:08 PM
    pyoung62
    Paul
    Raleigh, NC
    Close, but a little bit different. And both of mine are in place.
  28. Jan 1, 2025 at 2:09 PM
    Kerplunk
    Kerplunk New Member
    That's absurd.
    It is well known in some circles that Grommet Elves distribute these every so often in case we need one.
    DRP[QUOTED] likes this.
