Excessive bed movement
Discussion in '3rd Gen Tundras (2022+)' started by kramerv, Feb 28, 2024.
  1. Feb 28, 2024 at 5:00 AM
    kramerv
    kramerv [OP] New Member
    Had my 2024 for about a week and have noticed how the bed moves in a way that I think is a little excessive when going over bumps. Initially I thought it was the gate but it seems isolated to the drivers side however it might just be more obvious since it's closer to the mirror. Ran over the same bumps in my 2009 Tacoma and nothing. Is this indicative of a longer bed truck? I've seen the video of the wobbling Tundra bed over washboard bumps...it's not severe like that. Just enough to make me question if it's normal or not.
  2. Feb 28, 2024 at 1:54 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Have the dealer take a look since it's brand new.
    Or test drive another 2024 and drive over the same bumps to compare/contrast.
  3. Feb 28, 2024 at 2:14 PM
    kramerv
    Yeah I'm going to do that. In thr meantime I'm going to air down the tires since they have freaking almost 50 psi in each.
    j-utah likes this.
  4. Feb 28, 2024 at 2:39 PM
    Breathing Borla
    AZ
    are those the stock P rated tires you have? if so, ya dude, way too much air
    Colotundie and Mattedfred like this.
  5. Feb 28, 2024 at 2:42 PM
    kramerv
    Yeah I believe they're P rated. Didn't notice until I looked at the app.
  6. Feb 28, 2024 at 2:44 PM
    Breathing Borla
    AZ
    ya, check your door, but mine is 35 psi. 50 is way too much
    Mattedfred likes this.
  7. Apr 11, 2024 at 5:29 PM
    kramerv
    Update. Took it to a dealer to have my first oil change. Mentioned the bed movement and they said they couldn't recreate the problem. I took a video of the shaking today just for sh$ts and giggles. This look normal? I'm going over a series of bumps. Both sides recorded.
    https://www.youtube.com/watch?v=cZFksw7VsLg
  8. Apr 11, 2024 at 5:58 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    That does not look normal. Is everthing torqured down tight?
  9. Apr 11, 2024 at 7:21 PM
    23 Platinum
    23 Platinum 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    Better than excessive bowel movement
  10. Apr 11, 2024 at 7:57 PM
    BigElliott
    BigElliott New Member
    Portland OR
    2025 TRD Pro
    I’m not sure if mine is wobbling but I am taking my truck back to the dealer for the 2nd time this week to fix an incredibly loud rattling from my bed going over bumps. Also rattles when I close my doors. They told me they fixed it the first time it was there on Monday only to find out on my way home that it was even louder and worse!!! So it goes back in tomorrow. We will see what happpens.
  11. Apr 12, 2024 at 3:58 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Dealers are really good at not being able to recreate problems they would have to fix under warranty.
    HUTCHJ, Tundra family and SDHNTR like this.
  12. Apr 12, 2024 at 4:21 AM
    kramerv
    Yeah I dropped the PSI to 35 and there is no difference. The tires are stock Michelin 265s.
  13. Apr 12, 2024 at 8:56 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    your video is from 2017. If that is a current video with wrong date and not an optical illusion, then the whole bed is moving which points to an issue under it, where it attaches, and possibly related to the suspension since it appears to go back and forth. I would not expect to see that kind of movement with a boxed frame. It has to go on the hoist. JMO
    Also when you refer to the wobbling Tundra bed, I assume you refer to the previous gen. Its design was from another era. Its bed with Open C frame was a unique design amongst full size pickups. It was designed to compress and go rigid with alot of weight in the bed when hauling, and to articulate really well off road. Horses for Courses.
  14. Apr 13, 2024 at 7:49 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    After seeing this thread, I made a point of watching my bed as I drove over some severely washboarded dirt roads, yesterday. My Gen 3 short-bed barely moved.
    OP, there is definitely something wrong with your truck. As stated earlier, you need to get that thing on a lift and figure out what's not bolted down correctly.
  15. Apr 13, 2024 at 7:56 AM
    Terndrerrr
    Music City
    6UR-FE
    Some things never change.
    2nd gen forums:
    “I thought I’d get better MPG.”
    “What can I do about bed bounce?”
    “Why is my payload so low?”
    3rd gen forums:
    vtown76, HUTCHJ, Half Assed and 5 others like this.
  16. Apr 13, 2024 at 8:05 AM
    Matt2015Tundra
    2023 1794 CrewMax
    The bed bounce on the Gen 3 is much less than than earlier Gens, without a doubt.
  17. Apr 13, 2024 at 8:30 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My 6.5' bed doesn't do that! I really can't see much movement at all. I have 10 ply tires at ~45 psi and I have about 400 lbs. evenly distributed over the bed rails with my cover and tent assembly.
    I wonder if this has anything to do with the hydraulic mounts? And are they supporting the box too? Is the bed moving or is the cab moving?
  18. Apr 13, 2024 at 8:54 AM
    kramerv
    Yeah it's a the dealer right now. They were initially going to have a loaner Tundra so I was also hoping to compare with they were out of loaners...they took it last minute so not really mad and we're 8 miles away so I ended up just running home.
    I've been watching it on the app and they've had it on the lift since 9:30 am so they must have found something. I'll update.
  19. Apr 13, 2024 at 9:02 AM
    Terndrerrr
    Music City
    6UR-FE
    Not all 2nd gens are equal. My crewmax hardly does it at all. Mildly noticeable on some seamed concrete highways. TRD Fox suspension + RAS system.
    My neighbor’s 2020 Limited DC is bad though on the same stretch of highway. His truck is bone stock with the Bilstein 4600s it came with from the factory.
  20. Apr 13, 2024 at 9:04 AM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    Happens a lot in a good marriage. You’re fine.
    Terndrerrr and j-utah like this.
  21. Apr 13, 2024 at 9:21 AM
    Matt2015Tundra
    2023 1794 CrewMax
    I've owned a 2008 Crewmax and a 2015 Crewmax. Both were short beds and non-TRD. Both had a lot more bed bounce than my Gen 3 Crewmax short bed.
    Tundrastruck91 likes this.
  22. May 18, 2024 at 11:16 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Agree. Although my 2.5 gen wasn't bad and even better after installing CB shackles and old man EMU shocks.
    DogRunner2 likes this.
  23. May 19, 2024 at 2:09 AM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    Yeah wayyy to much rolling, somthing's not right. On my crew cab 6.5' bed it doesn't wobble that much over bumps.
  24. Dec 24, 2024 at 11:14 AM
    BLU3C0BRA
    BLU3C0BRA New Member
    2024 Ice Cap SR5 TRD Sport 4x4
    Icon stage 6 3 inch lift 20 inch fuels 35 ridge grapplers Gorhino running boards
    Did you ever get a resolution to this, mine is doing the same. My dealer said they couldn’t replicate, and I know it’s always easier to tell them exactly what’s wrong. @kramerv
  25. Dec 24, 2024 at 1:34 PM
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    You think it shakes over bumps ? Just wait until you get some ice in your rear wheels ! I had to pull over today after just hitting the highway and clean out the rear wheels . Just a small bit of ice, but enough to get the back of the truck dancing like a drunk belly dancer !!!! I should have taken a video .
  26. Dec 25, 2024 at 10:53 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I have 22 crew Max 6.5 bed, had quite a bit of movement on bed and a rattle that was very noticable when back window was down. I loosened all of the bed bolts and it "popped" like tension was being relieved. Re torqued (36 ft/lbs) and rattle/excessive movement is gone.
    The dealer might just be torquing the bolts and calling it good. Backing off all of the bolts is what fixed mine
    BLU3C0BRA likes this.
  27. Dec 25, 2024 at 11:38 AM
    BLU3C0BRA
    @Samuryan thanks for the info. It makes sense (just like torquing wheels without doing a start pattern). Where did you find the torque values from the manual. I was looking and found a diagram online that said something like 67 ft lbs. my only worry doing it myself would be not torquing enough.
  28. Dec 26, 2024 at 6:22 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I found the torque spec in this thread
    https://www.tundras.com/threads/2022-tundra-bed-noise-solved.121127/
    @bsulli91 put a lot more effort into chasing the rattle and posted with pics.
    I had great results loosening and torquing.
  29. Dec 26, 2024 at 8:57 AM
    BLU3C0BRA
    @Samuryan thank you so much for this! I’m gonna give it a try!
