  1. Dec 24, 2024 at 6:13 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Can’t wait to see what it looks like when it’s finished. Take plenty of pics
  2. Dec 24, 2024 at 6:15 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Here's a quick ride report.
    Truck is stock weight other than a skid row trans skid...
    Sorry I can't give you a stock comparison but here's what I do got.
    I bought the truck a few weeks ago and it had no skid, stock springs, 5100s with a ~2" spacer lift. Stock UCAs
    Imo it rode pretty bad (harsh) so I took the sway bar out and have road tripped it once as is with E rated 265/70R17 Yokohama G018s.
    In that configuration it has quite a bit of body roll but was much more compliant. With my body roll than I'm comfortable with long term or with anyone else driving, so there's been some maxx links on my workbench which I thought would remedy the roll but not be as harsh as stock links with a 2" lift.. I ran my 2015 Tacoma with 884s and 5100s with no swaybar for quite a while and it felt less rolly than the 06 herein.
    The 6112s with 650lb springs have much less body roll in day to day driving like roundabouts, country roads and also test evasive maneuvers that I wouldn't dare do with the stock springs 5100 and no sway bar. Noticably more stable without the swaybar.
    I am debating leaving it without a swaybar now but it's so easy to take on and off I'll probably experiment.
    Small bumps.. they are maybe a little firmer than the 5100s but not really? I am optimistic that altho something is sprung/valved different for body roll, that they will be quite nice off road.
    Oh and they are notched 8/6. Drivers side is currently sitting 3/4" higher at 22.5 vs passenger 21.75. that's with a full tank.
  3. Dec 24, 2024 at 6:21 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I’ve managed changing the filter with it in place reaching from above, I did spill a reasonable amount of oil on the skid plate as a result and it leaked onto the ground wherever I parked for a couple days…
  4. Dec 24, 2024 at 6:35 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    That's how we used to do em and the 3.4L when I worked at a lube shop. But we'd spray em down with water after.
  5. Dec 24, 2024 at 8:09 PM
    PenderBen
    2003 Tundra AC 4x4
    I figured it was passive rust proofing ;-)
  6. Dec 25, 2024 at 7:28 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    I haven’t looked at it in awhile nor had it on the truck in months but is there a way to modify the stock skid to make filter changes easier? I have a fumoto valve in the sump so that’s no issue
    455h0le_dachshund likes this.
  7. Dec 25, 2024 at 7:31 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    You could possibly cut this wing off where you can access the filter from beneath
  8. Dec 25, 2024 at 9:33 AM
    PenderBen
    2003 Tundra AC 4x4
    Not easily from the looks of it. I wonder if anyone has installed a remote oil filter on one of these trucks, move it up top?
    I’ve always appreciated the oil filters on BMWs I’ve had, cartridge filter from the top on the engine.
  9. Dec 25, 2024 at 9:51 AM
    I saw a thread on it once, but not on this site.
  10. Dec 25, 2024 at 10:49 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    The Skid Row skid plate doesn't have the wings on the side, so oil filter changes are easier. I would rather upgrade the skid plate than relocate the filter.
  11. Dec 25, 2024 at 3:43 PM
    Azblue
    The Dirty T ( ^_^)_且
    When I had my 1st Gen, I always just took an old rag or piece of carpet and set it under the filter on top of the skid plate. Reach in from the top to take out the filter, put the new one on, throw away the carpet. Little to no mess.
    oscardog86, FrenchToasty and shifty` like this.
  12. Dec 25, 2024 at 5:28 PM
    The box that an air filter or oil filter comes in cut open and laid flat makes a good deflector into the oil pan when changing the oil filter. I never take the skid plate off anymore.
    oscardog86, BroHon, Azblue and 2 others like this.
  13. Dec 25, 2024 at 7:04 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    Christmas wine got to me.
  14. Dec 25, 2024 at 8:35 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    That was some expensive wine.
    bmf4069 and KTM_AJ421[QUOTED] like this.
  15. Dec 25, 2024 at 8:44 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Discount on RockAuto expires on January 24, 2025
    288936499256102147
    EDIT, heh, meant to post this in the lunch room o_O
    bmf4069, shifty`, Filthyphil and 3 others like this.
  16. Dec 25, 2024 at 8:46 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    Been saving for awhile didn’t know what to go with and just said screw it haha
  17. Dec 25, 2024 at 8:49 PM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    Google RA discount codes. They have always worked for me.
    BroHon[QUOTED] likes this.
  18. Dec 25, 2024 at 8:51 PM
    Desert Dog
    Yeah, just razzin' you. I've had some of that wine before :D cuz, toys.
    KTM_AJ421[QUOTED] likes this.
  19. Dec 25, 2024 at 8:51 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    yup, that's what I do if I don't have a current one handy, I like to post it here for the guys, for convenience.
    Edit: I seem to get one after a couple months go by and I haven't ordered anything... it's comforting, like they are checking in on me to see if I'm still alive :rofl:
  20. Dec 26, 2024 at 6:48 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Did my second drain & fill of transmission pan yesterday.
    Took the cold chisel to the front diff drain plug but couldn't get any movement. Hard to get the right angle with the truck on the ground. I'll buy these today or tomorrow and give it another shot.
  21. Dec 26, 2024 at 7:00 AM
    You enter the code in the “where did you hear about us?” Box, correct?
    BroHon[QUOTED] and des2mtn like this.
  22. Dec 26, 2024 at 7:02 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yesir
  23. Dec 26, 2024 at 7:14 AM
    IMG_7440.jpgIt’s been a while, thanks
  24. Dec 26, 2024 at 7:43 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Pics or it didn’t happen, right? :rofl:
    The shop is slammed this morning but hopefully I will have enough time this afternoon to get this thing buttoned up and driving.
    I also decided to mock up some puddle lights underneath just to see how I’ll like them. Trans first, then wiring.
  25. Dec 26, 2024 at 9:46 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Soooo close…. The lift was on its way down and the storms knocked the power out :mad:
  26. Dec 26, 2024 at 9:48 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Whoa I like this truck.
    Got a build thread?!
  27. Dec 26, 2024 at 10:03 AM
    The Black Mamba
    DFW
    Imma keep it stock
    This is my build thread
  28. Dec 26, 2024 at 11:01 AM
    Big Man maybe trying to tell you something, Hoss.
    The world is his oyster :rofl:
  29. Dec 26, 2024 at 11:32 AM
    The Black Mamba
    DFW
    Imma keep it stock
    bmf4069, Voss, BroHon and 2 others like this.
  30. Dec 26, 2024 at 11:38 AM
    Did you screen shot a quote?
    bmf4069, Voss and BroHon like this.
