subwoofer enclosures for 2.5 gen
Discussion in 'Audio & Video' started by 2010bigdog, Dec 24, 2024.
  1. Dec 24, 2024 at 5:33 AM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    can you post pictures of the subwoofer enclosures you have in your trucks (crewcab)? The JL stealth box is almost $2000 so want other options.
    Thanks in advance!
  2. Dec 24, 2024 at 7:39 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Cruchfield has some , TACO tunes, Custom Concepts, Skar Audio and more. Did a quick search and most I saw were around mid 300s.
  3. Dec 24, 2024 at 7:39 AM
    frichco228
    Frank
    Virginia
  4. Dec 24, 2024 at 7:43 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    if you go through my audio build (link in my signature), there's pictures in there of the Stealthbox and a ported box from Tech12Volt.
    AZBoatHauler, Snert and 1lowlife like this.
  5. Dec 24, 2024 at 2:26 PM
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    There is basically the same box places with either 10s or 12s shallow mount.
    on the other hand you can get a seat bracket from Gately and go up to a 15.
    there is a thread on the Gately seat brackets with a picture of a audiomobile encore 15.
    but if you want to stay stock the best deal on the planet is tech12volts box.
    His boxes have resin inside to completely seal the box up.
    most ported boxes for these trucks have to be small and the port tune is high as the port has to be small.
    just depends on what you want.
    I have 2 si sm12mk5 but the newer version is the si bm11.
    Snert likes this.
  6. Dec 25, 2024 at 4:37 PM
    Snert
    Snert New Member
    2021 SR5
    I’ve anecdotally read some people say the MK5’s are a lil better than the BM11’s, in any case, how do you like the Stereo Integritys? They’re on my list of potential new subs
  7. Dec 25, 2024 at 4:51 PM
    AZBoatHauler
    So.Arizona
    Tech 12 box.
