Milwaukee Tools
Discussion in 'Off-Topic Discussion' started by T-Rex266, Nov 9, 2024.
  1. Dec 24, 2024 at 8:38 AM
    #901
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    DEI
    (also, Empire is owned by Milwaukee)
  2. Dec 24, 2024 at 8:40 AM
    #902
    Pex would have been way more cost effective though
    Prostar 190, Leo's first and Mater like this.
  3. Dec 24, 2024 at 8:43 AM
    #903
    RainMan_PNW
    Casey
    Clark County, WA
    Very true. I forget about direct burying PEX. But we’re usually direct burying much bigger lines than 1”, so HDPE ends up being the most common
  4. Dec 24, 2024 at 9:11 AM
    #904
    French Avocado
    Utah / Wyo
    Gorgeous!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    T-Rex266[QUOTED][OP] likes this.
  5. Dec 24, 2024 at 9:57 AM
    #905
    blenton
    blenton New Member
    Like many Milwaukee hand tools, they put the HEAVY in heavy duty. Haha.
    Empire are fine but I’ve had one or two that weren’t level right off the shelf. If you level something with it, then rotate the level 180*, its no longer level. I don’t use them anymore.
    I have a red stick 6’ milwaukee set that is great (but heavy) and another 48” red stick that rode in the truck for a bit. They are accurate. But I use Stabila 99% of the time - currently their Shadow level. My last Stabila lasted 5 or 6 years in the back of the truck but it went for a ride and nicked an edge. I replaced it but I bet it’s still better than a cheap level. I just need to get rid of the nick.
    Prostar 190 and Mater[QUOTED] like this.
  6. Dec 24, 2024 at 10:20 AM
    #906
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - all my levels are Stabila.
  7. Dec 24, 2024 at 12:06 PM
    #907
    I have both Milwaukee and Stabila. Both have been great.
  8. Dec 24, 2024 at 12:16 PM
    #908
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    So my lil old 83yr, 4'11", 75 lb mother in law did a number on her toilet my wife tells me last night.
    She lives with us in a mother-n-law unit attached to our house.
    No biggie I say and get the plunger. Welp, that didn't work. I'm kinda stunned to say the least, but the sink and tub drains are still working so I know it's isolated to the toilet.
    This auger from Milwaukee is worth the $60. Comes with attachment for your driver.
    https://www.homedepot.com/p/Milwauk...ger-Plumbing-Drain-Snake-49-16-3576/325130881
    Made quick work of a literal shit job.:rofl:
    Merry Christmas y'all :santa2:
  9. Dec 24, 2024 at 1:51 PM
    #909
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    This was on sale earlier so I snatched it up
  10. Dec 24, 2024 at 1:53 PM
    #910
    blenton
    blenton New Member
    Those are great. I usually have one or two of them in the truck. Battery lasts decently long, they are fairly bright, and they are much more compact than the m18 Rockets. The m18 certainly has longer battery life and puts out more light, but I set up the m12 version 4 out of 5 times (mostly because I have to remember to put the m18 Rocket in the truck if I plan on using it).
  11. Dec 24, 2024 at 2:44 PM
    #911
    I almost went with the M18, but it’s rare will I really use and this will get the job done when needed.
    Prostar 190 and Mater like this.
  12. Dec 24, 2024 at 2:50 PM
    #912
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    You all feel the 3” cutoff tool is worth $57.37?
    @RainMan_PNW so the bandfile worked well removing the spare tire guards?
    edit: yes, I need to charge my phone
  13. Dec 24, 2024 at 3:07 PM
    #913
    Outbound
    Aaron
    Northern Alberta
    Stabila are the only levels worth buying. Well, them and Flange Wizard for pipe work.
  14. Dec 24, 2024 at 6:33 PM
    #914
    RainMan_PNW
    Casey
    Clark County, WA
    You want to go slow and steady with it, but yes. I started with the grinder and it was raining sparks everywhere and hard to get up in there comfortably. Then I remembered I had the bandfile with me (was at my MIL’s because she has a shop) so I put it to work. Almost no sparks and really wasn’t much slower than I felt the grinder was once I got it into a position I could comfortably use it.
    Leo's first and Mater[QUOTED] like this.
  15. Dec 24, 2024 at 7:45 PM
    #915
    blenton
    blenton New Member
    For $57, the 3” cutoff wheel is worth it. It’s no grinder, but works great for tile and a few other things with the correct wheel.
    SYNCRO, Leo's first and Mater[QUOTED] like this.
  16. Dec 25, 2024 at 3:51 AM
    #916
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :eek:
  17. Dec 25, 2024 at 4:10 PM
    #917
    Wife got me this for Xmas
  18. Dec 25, 2024 at 7:01 PM
    #918
    SYNCRO
    SYNCRO New Member
    Stoked I got the insider from old St. Nick! Now I’m debating the 1/2” anvil and the SAE socket set….
    Mater, TomC843, Leo's first and 3 others like this.
  19. Dec 26, 2024 at 5:18 AM
    #919
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Got the 3/8" impact socket set as a gift
  20. Dec 26, 2024 at 4:18 PM
    #920
    Outbound
    Aaron
    Northern Alberta
  21. Dec 26, 2024 at 4:45 PM
    #921
    French Avocado
    Utah / Wyo
    Clearly a group of over-achievers!!!
  22. Dec 26, 2024 at 5:22 PM
    #922
    Hi my name is French Toasty;
    It’s been 102 days since I last bought Milwaukee and 4 days since I last used Milwaukee……
  23. Dec 26, 2024 at 5:31 PM
    #923
    Better make it 0 days
  24. Dec 26, 2024 at 8:37 PM
    #924
    RainMan_PNW
    Casey
    Clark County, WA
    it's been about 4 days since I last bought, and less than 4 hours since I last used...
  25. Dec 26, 2024 at 8:52 PM
    #925
    Be strong
  26. Dec 26, 2024 at 9:00 PM
    #926
    Tripleconpanna
    Yesterday, I received a HD gift card from BIL...
    Today, I spent said gift card on....
    Also today, I used my Hatchet on a downed tree from last night's winds...
    It's hopeless; attempting to escape the clutches of Red Tool Nation is futile... :pout:
    I blame this forum :bananadead:
  27. Dec 27, 2024 at 7:11 AM
    #927
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Does anyone know if insider ever goes on sale? Currently sitting at $299 forever....
    Insider
    Leo's first likes this.
  28. Dec 27, 2024 at 7:42 AM
    #928
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Fairly new M12 would not charge, stuck on 2 bars. Soooooo, yeah, tried the voodoo pixy swap for 2-3 minutes I guess?
    And I'll be dammed :rofl:
    Humor me if this is just common knowledge haha or make fun of me :rofl::bananadead:
  29. Dec 27, 2024 at 7:51 AM
    #929
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    I don't recall ever seeing it on sale. Just checked and I bought mine at $299 in February.
  30. Dec 27, 2024 at 7:53 AM
    #930
    Ghost Rider
    Ian
    Cypress, Texas
    Yea, I figured that....
