Sway bar bolts are stripped, how do I cut them off?
Discussion in '2nd Gen Tundras (2007-2013)' started by aidan_pierce, Oct 27, 2024.
  1. Oct 27, 2024 at 7:11 AM
    aidan_pierce
    aidan_pierce [OP] New Member
    Aidan
    2012 Tundra 5.7 crewmax
    Alright so i’m replacing my alternator, and to get the alternator out from under the engine, you have to remove the sway bar. However while doing so, I stripped the bolts that hold on the sway bar bracket. My only way of removing them that I can think of is cutting them. But a grinder and reciprocating saw won’t fit. Any ideas on how to remove these bolts?
  2. Oct 27, 2024 at 7:13 AM
    You rounded off the heads?
  3. Oct 27, 2024 at 7:21 AM
    aidan_pierce
    Aidan
    Nope, but the way the bolt is, no matter how hard I give it pressure, It doesn’t catch threads to loosen or tighten. If i could’ve fit a grinder in the gap i would’ve but it’s too tight. I’m currently trying to find a dremel bit that might work but i doubt it’ll cut through.
  4. Oct 27, 2024 at 8:27 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Can you take a picture of what you’re working on? My sway bar has been off and on a couple of times and I’ve never had any problems with it. It might give some smart people on this sight better info to help you.
    I think I understand, the welded nut inside has broken free and is just spinning. Is that right?
  5. Oct 27, 2024 at 8:34 AM
    aidan_pierce
    Aidan
    These are the bolts, on both sides they’re messed up. I debated just deleting the sway bar completely after this job. So i’m honestly not too worried about the threads being damaged.
  6. Oct 27, 2024 at 8:37 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Ok. So again, they’re just spinning at that point? Nut on inside of frame has come loose?
    You can probably get the blade of an oscillating tool in there.
    If you don’t have one, it’s a great tool to have around.
  7. Oct 27, 2024 at 8:51 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    On my '21 that's an access cover, you might be able to get a tool in there to hold the nuts
    Mater and Bprose like this.
  8. Oct 27, 2024 at 8:57 AM
    aidan_pierce
    Aidan
    I’ll try the oscillating tool, i didn’t even think about that! Thank you, i’ll let you know if it works
  9. Oct 27, 2024 at 8:58 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    If you want to cut those bolts, it might work to tape half a hacksaw blade and hold it against the bolt while you spin it with a drill or impact driver. Move the blade back and forth a bit as you go to avoid stripping the teeth against the spinning bolt.
    aidan_pierce[OP] likes this.
  10. Oct 27, 2024 at 9:04 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Check that access hole 1st.
  11. Oct 27, 2024 at 9:06 AM
    aidan_pierce
    Aidan
    I will, i can see that the nuts on the inside broke loose and that’s why it’s spinning. I don’t know how i’m gonna fit something in there but i’ll try. I might just try and weld it back on.
  12. Oct 27, 2024 at 8:08 PM
    Bassfishinfool
    Bassfishinfool New Member
    Michael
    2007 silver tundra trd offroad
    Sawzall with metal cutting blade go through that like butter
    aidan_pierce[OP] and COTundie like this.
  13. Oct 27, 2024 at 8:16 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Saws-all or try to pry down on the bolt as you loosen it????
  14. Oct 27, 2024 at 8:20 PM
    aidan_pierce
    Aidan
    Well i got them off! Used an oscillator and went right through them. drilled about half an inch more out of the access holes to fit a MIG gun inside. Gonna weld new nuts inside and see how well it does. You guys rock
    thomez likes this.
  15. Oct 27, 2024 at 8:47 PM
    lr172
    lr172 New Member
    07 DC
    I’m f that doesn’t work, just take a 1/4” steel plate big enough to support the bushing and strap. Tap holes for the bolts and weld that to the frame. Doubt that will interfere with anything. Will be much stronger than two tack welds on a nut.
  16. Oct 27, 2024 at 8:48 PM
    aidan_pierce
    Aidan
    Great idea, i’ll try that! I appreciate your guys’ help
  17. Dec 25, 2024 at 3:08 PM
    Warf
    Warf New Member
    2014 Limited
    2.4 in. level
    Where did you order the replacement bolt from?
