Found a connector on the floor…
Discussion in '3rd Gen Tundras (2022+)' started by 24pro, Dec 25, 2024.
  1. Dec 25, 2024 at 8:33 AM
    24pro
    24pro [OP] New Member
    ‘24 TRD Pro
    ‘24 pro, pulled out of the garage and saw a connector that a mouse chewed off, looking underneath I can’t see the other end of the wire to figure out what he got. It’s an 8 pin connector, wire colors: White, Green, Brown, Yellow, Orange, Red, Black, Blue. Can anyone ID? It could have come off passenger side area about where the cab and bed meet, but that’s just where I found it on the floor
  2. Dec 25, 2024 at 9:24 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Power passenger seat still operational?
  3. Dec 25, 2024 at 9:28 AM
    SDT-Online
    SDT-Online New Member
    2024 Tundra Platinum (Red)
    Time for some mouse bait.
    What does not work now that worked before?
    Were both sides of the connector on the floor?
  4. Dec 25, 2024 at 9:40 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Pics??? Find it on garage floor? Did you look up under there yet?
  5. Dec 25, 2024 at 9:49 AM
    24pro
    ‘24 TRD Pro
    Seat still works
    Just 1 side of the connector, everything seems to still be working, at least I haven’t noticed anything yet
    Looked around a bit, but I’m not seeing anything
    Raven67[QUOTED] likes this.
  6. Dec 25, 2024 at 9:53 AM
    lapoolboy
    lapoolboy New Member
    That doesn't appear to be from your truck. More likely road debris flung up under your truck somewhere that fell out in your garage.
    Ausfahrt, 1lowlife and Raven67 like this.
  7. Dec 25, 2024 at 9:59 AM
    24pro
    ‘24 TRD Pro
    Maybe, but it looks too new for me to think it’s not from my truck, I did run it over pulling out of the garage, and every part is there if not attached anymore
  8. Dec 25, 2024 at 10:04 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    Google the part number
  9. Dec 25, 2024 at 10:12 AM
    24pro
    ‘24 TRD Pro
    141 number comes up with just the connector, 152 number doesn’t return anything. On Toyotas part lookup both numbers return nothing
  10. Dec 25, 2024 at 10:26 AM
    Raven67
    Kentucky
    That number style doesn't look like a Toyota part. I agree with lapoolboy & think it's road debris.
    If it came from your truck, something wouldn't be working, or a warning light would be on with that many wires.
  11. Dec 25, 2024 at 10:44 AM
    bailey bulldog
    bailey bulldog New Member
    Have any other vehicles around?
  12. Dec 25, 2024 at 10:50 AM
    24pro
    ‘24 TRD Pro
    2 Jeeps in the garage, but there’s not a connector on either of them that would be this clean, 0 corrosion, the tape holding the plastic flex tubing on the wires was still fresh, if this didn’t come off my truck and was road debris it came off of something just as new as the truck
  13. Dec 25, 2024 at 10:55 AM
    bailey bulldog
  14. Dec 25, 2024 at 11:05 AM
    bailey bulldog
    Parking Sensor ACC Module Plug Socket for Ford, Land Rover, Carnival Sharpe Max.
  15. Dec 25, 2024 at 11:11 AM
    bailey bulldog
  16. Dec 25, 2024 at 11:25 AM
    bailey bulldog
  17. Dec 25, 2024 at 2:09 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    In my opinion it looks like it has too many solid colors. I'd think if it was a Toyota plug there would be stripes on the wires. Don't think it from your truck.
    1lowlife likes this.
  18. Dec 25, 2024 at 2:34 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That was my first thought as well..
    At least a white with black stripe ground wire..:cool:
    FrenchToasty and Rockpig[QUOTED] like this.
  19. Dec 25, 2024 at 5:03 PM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    To me, it doesn't look like any ratchet marks. Hard to say and for the rat to chew in the same spot at each wire.
  20. Dec 25, 2024 at 5:30 PM
    24pro
    ‘24 TRD Pro
    I’m thinking yall are right, no faults with the truck, all the lighting works, all the sensors are good. Looked at the connector/wires a bit more and found a company name on it, kyungshin, they make parts for Hyundai and my wife’s Tucson was totaled and sat in the driveway for a week or so, I’m guessing it fell off of there, and I brought it in on a tire. Thanks for all the responses, time to double down on mouse bait and traps out there
  21. Dec 25, 2024 at 5:31 PM
    lapoolboy
    Case closed.
    HLR_NM likes this.
  22. Dec 26, 2024 at 7:17 PM
    firehawk003
    firehawk003 New Member
    Dang, if mice did that in short order I would be scared to go in my garage.
  23. Dec 27, 2024 at 10:40 AM
    HLR_NM
    HLR_NM New Member
    Harry
    Wires are too thick for a 3rd gen Tundra but I see the mystery was already solved.
    Hyundais have some particularly delicious soy-based wiring.
  24. Dec 27, 2024 at 12:20 PM
    Glosta MikeV
    Glosta MikeV New Member
    Gloucester MA
    2024 Tundra Limited OR
    Using some Vulcan logic
    If the connector was for something required it would have been plugged into another connector and not fall off.
    If it was for a unused option it may have a plug to keep the pins from corroding , but more importantly it is not for an optional function you don't have so it shouldn't matter?
