TPMS fail
Discussion in 'Wheels & Tires' started by DaveInTexas, Sep 2, 2024.
  1. Sep 2, 2024 at 4:19 PM
    DaveInTexas
    DaveInTexas [OP] New Member
    Dave
    West Texas
    2020 Tundra SR5 + 2003 Tundra SR5
    The 2020 has a Ranch Hand front brushguard/bumper
    Worked great for 95,000mi
    Quit one day then worked next day.
    Now, persistent fail.
    Tire P’s all ~35psi
    Any easy (non-dealer) diagnostics or fixes?
  2. Sep 2, 2024 at 4:24 PM
    Retired...finally
    Seems early for a battery to die. A tire shop should be able to tell you which sensor(s) aren't transmitting.
  3. Sep 2, 2024 at 5:40 PM
    Nova1967
    Nova1967 New Member
    Maryland
    2021 tundra crew max, 1794, Smoked Mesquite
    Rear Sway bar, TRD dual exhaust, storage unit under rear seat, cargo mate, 10 spoke aftermarket 21" rims (Lexus), weather tech mates, Morimoto headlights, HR hood bar light, Chrome deleted: bulge, grille surround, valance, bumper end caps, mirrors. Replaced all parts with smoked mesquite, and L.E.D bright interior lights.
    Whenever you swap tires and rims with a different TMPS sensor, you need to reset sensor with new TMPS information. When you change back to the previous tire and rim system the computer my pick the old TMPS sensor.
  4. Sep 2, 2024 at 6:00 PM
    DaveInTexas
    Dave
    West Texas
    I’ve had individual sensors fail before; this indicates either all are failing at once (very unlikely) or the computer/its connections have a problem (note above that it failed one trip then came back to normal, then failed again).
  5. Sep 2, 2024 at 6:01 PM
    DaveInTexas
    Dave
    West Texas
    I’ll keep that in mind for next time I swap tires or rims.
    Any ideas about my problem?
  6. Sep 2, 2024 at 6:14 PM
    Nova1967
    Nova1967 New Member
    Maryland
    All my TMPS failed at the same time. I purchased new sensors with tires from Costco and they worked after driving several miles. Once I changed back to the original set of tires and rims, it took several miles again before the system recognized the TPMS sensors. Your vehicle should have the TMPS reset button located on the right , lower, side of steering wheel. Check manual for guidance.
  7. Sep 2, 2024 at 6:18 PM
    DaveInTexas
    Dave
    West Texas
    Did they quit, then come back, then quit again - like mine did?
    Weird.
    I did not change tires/wheels/sensors - just drivin’ around like normal.
    Good tip, I’ll try it.
    Thanks
  8. Dec 12, 2024 at 7:10 AM
    DaveInTexas
    Dave
    West Texas
    Dealer says it was only one sensor (left rear).
    Seems odd; all sensors were blanked out and the screen said it just needed calibrating. (The reset button did nothing) Anyway, it’s fixed.
    cost was $220
    Price check on that?
  9. Dec 12, 2024 at 1:05 PM
    DaveInTexas
    Dave
    West Texas
  10. Dec 24, 2024 at 7:07 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    Anybody know weather the spare tire has a TPMS sensor in it? I asked a few tecks @ my local stealership and could not get a straight answer from any of them.
  11. Dec 24, 2024 at 7:12 AM
    The OEM sensor runs about $90 MSRP so that sounds about right for the sensor and labor.
  12. Dec 24, 2024 at 7:12 AM
    It usually does not.
  13. Dec 24, 2024 at 7:37 PM
    DaveInTexas
    Dave
    West Texas
    I do not see a location on the instrument panel to display the spare pressure. Maybe it would have to be programmed?
    Mine (2020) did not appear to come with a 5th sensor.
    My wife's 2021 4Runner SR5 does have a 5th sensor and indication next to all the other sensors.
