Tires worn out by segments
Discussion in 'New Member Introductions' started by Angelmontilla, Dec 24, 2024.
  1. Dec 24, 2024 at 7:39 AM
    Angelmontilla
    Angelmontilla [OP] New Member
    Angel
    I have Goodrich all Terrain tires about 10000 miles on it and Injust notice they are some noisy and are front tires are worn out by segments
  2. Dec 24, 2024 at 7:49 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
  3. Dec 24, 2024 at 7:50 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Sounds like the truck front end alignment is off, or incorrect tire pressure, or potentially bad suspension components up front...or a mix of all 3. Any of them can lead to incorrect/accelerated tire wear.
    Maybe contact the dealer/seller where you got the tires and see if they can do anything under the tire warranty. Worth a shot, but if the bad wear was caused by any of the issues I listed above, they will not replace them under the tire warranty.
    ZappBrannigan and JLS in WA like this.
  4. Dec 24, 2024 at 9:56 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Dec 25, 2024 at 1:15 PM
    Angelmontilla
    Angel
    Thank you so much , so far I found very low air pressure , I’ll be checking balance at a tire place next
