  1. Dec 23, 2024 at 8:27 AM
    Slow boat from Japan arrived to deliver my skid plate. :woot:
    Now I just need to get a frame to match it.
  2. Dec 23, 2024 at 8:39 AM
    notlikejohnny
    notlikejohnny New Member
    Shenandoah Valley, VA
    2005 4WD DC Limited, Phantom Grey
    Spoke to the parts department at Serra just now. The order had shipped from their distribution center, but they hadn't received it to then ship out to me, so I was able to cancel. Ordered the Moog Inners from RA. They should be here thursday. Slap them in friday or saturday.
  3. Dec 23, 2024 at 9:39 AM
    A little window chip repair with the Rain-X DIY kit. Pretty simple, stick the suction cup guide on, add the resin, insert the plunger and apply pressure to get the resin to infiltrate the chip. After removing the suction cup plunger apparatus, apply some topical and cover with the film provided. Then remove the film after 10min and scrape the excess off with the included razor blade. A little too cold to do it today, but did it anyway. Decent result, may repeat on a sunnier day.
    before:
    during:
    after:
    Kit used:
  4. Dec 23, 2024 at 9:44 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Looks good to me!
  5. Dec 23, 2024 at 10:21 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Well I sent the Cobra CB back, couldn't get it to transmit, and replaced it with an Anytone AT-6666-PRO 10 meter/Export model (CB capable). Not finished testing it but so far so good. Ignore the rat's nest of wires, not going to tidy the wires until I'm finished testing the unit.
    G_unit3000, Desert Dog, Voss and 6 others like this.
  6. Dec 23, 2024 at 11:54 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'll trade you mine for an aluminum one :thumbsup:
  7. Dec 23, 2024 at 12:43 PM
    shifty` Goons of Hazzard
    I did the Permatex one. It did a slightly better job. How much you pick out the hole, if applicable, and how much suction and pressure you use seems to help the result. I had to re-deposit some liquid on the hole and lay the patch down and cure with UV again, because I made the classic mistake of cutting the excess off. It takes it smoother to the glass if you hold the flat razor blade perpendicular to the glass and push back/forth with pressure. When I cut it out, it pulled epoxy out of the pit, I had to dig deep and reapply.
    G_unit3000 likes this.
  8. Dec 23, 2024 at 12:46 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Finally found a dimmer switch cap at a local junkyard. Not much but sometimes it’s the little wins lol.
  9. Dec 23, 2024 at 12:47 PM
    kentuckyMarksman
    kentuckyMarksman New Member
    I've got a double cab anyway, and I know you have an access cab. I haven't prices the metal out yet either.
  10. Dec 24, 2024 at 4:41 AM
    bmf4069 Captain wtf
    Those are nice! Have you tested the lateral hold in them yet? I need new seats for the Vic, but want something that'll hold my fat ass in place.
    The Black Mamba likes this.
  11. Dec 24, 2024 at 5:48 AM
    Velcro pants with matching seat covers….. problem solved
  12. Dec 24, 2024 at 6:06 AM
    bmf4069 Captain wtf
  13. Dec 24, 2024 at 6:41 AM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    LMAO! You're not wrong, though...
  14. Dec 24, 2024 at 6:41 AM
    Modern problems……
    Jack McCarthy and shifty` like this.
  15. Dec 24, 2024 at 7:25 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Hutcheson, Voss, bmf4069 and 8 others like this.
  16. Dec 24, 2024 at 7:30 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Good luck! Take no prisoners!
    Change that cut disc haha. SHRAPNEL !
  17. Dec 24, 2024 at 7:40 AM
    bmf4069, BroHon[QUOTED] and FishNinja like this.
  18. Dec 24, 2024 at 8:07 AM
    FishNinja
    Lee
    06DC2wd
    that's melted plastic from the flare lol
  19. Dec 24, 2024 at 8:09 AM
    B888s
    B888s New Member
    Brandon
    Bakersfield, CA
    2000 TRD Off-Road SR5 4x4 Access Cab
    Original owner!
    This is my son’s truck. He wanted full on hot boi seats and I talked him into these instead. They hold you in nicely. The thigh bolsters are not tall, so entering and exiting is easy. I have only driven/rode in it a few miles, but they are nice.
  20. Dec 24, 2024 at 9:34 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Were you rubbing before?
  21. Dec 24, 2024 at 9:35 AM
    Soaked the new skid plate in WD-40 and mounted it back on the truck. Not easy when you need to bend the hangers a little when it’s coated in lubricant.
    oscardog86 and BroHon like this.
  22. Dec 24, 2024 at 10:47 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    My hand is feeling so much better. I didn’t do anything to the tundra today because the shop is closed. However, last night the kids car started overheating. T-stat was stuck. So today I replaced the upper rad hose that blew off, replaced both t-stats, replaced the coolant temp sensor and obviously performed a coolant flush. The electric fan operates like it should (comes on at 215 and cuts off at 195). They should be good to go.
    jerryallday, bmf4069, des2mtn and 4 others like this.
  23. Dec 24, 2024 at 12:20 PM
    Good papa! Hope you get time to enjoy Christmas Eve later. Proud of your success this year, bro! Keep kicking ass....
  24. Dec 24, 2024 at 1:13 PM
    FishNinja
    Lee
    06DC2wd
    A little but nothing severe enough to warrant this. I did this cause I don't like how the stock flares look. That lip that comes down always bothered me.
  25. Dec 24, 2024 at 1:47 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Well you should be able to articulate better once you're done.
  26. Dec 24, 2024 at 2:17 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    UCAs and 6112s courtesy of 1st Gen Off-Road and Wheelers. Both of these items are easier on these trucks than 2nd or 3rd Gen Tacomas.
    Btw, the O'Reilly BJ press just barely fits inside the wheel well. Castle nut on, and having three hands, and don't forget to remove the lock ring!
    It's nice to see so much shiny on the front end of this truck since I did LBJs last week.
    Pity I couldn't splurge for spindles while I was in there... With new tires, I still hear a mild howl at certain speeds, which I'm convinced is a hub and not tires nor needle bearing.
    G_unit3000, Methodical, Voss and 6 others like this.
  27. Dec 24, 2024 at 3:14 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    I took mine off because one of the bolts was stripped but does the stock skid plate have provisions for an oil change? I think I remember having to take it off every time which is kind of a pita that thing is heavy and I really don’t like cycling bolts over and over due to fatigue. Yes… I have ocd
  28. Dec 24, 2024 at 3:22 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    need a ride report on the 6612s if you can. Need new suspension and seriously considering. Which notch did you go on those? Any pics of the whole truck? Nice work!
  29. Dec 24, 2024 at 3:39 PM
    The most it has is a hole to drain the oil through the skid plate. For the filter, you need to remove it to change the filter.
  30. Dec 24, 2024 at 3:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I ditched mine on my 03. Weight reduction and easier oil changes.
    Might've lost a little aerodynamics, but I think the bed cover and lowering the truck makes up for it.
    G_unit3000 and KTM_AJ421[QUOTED] like this.
