2/2.5 Gen ECGS Bushing Tool
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mater, Feb 17, 2024.
  1. Feb 17, 2024 at 6:59 PM
    Mater
    Mater [OP] New Member
    SD
    2016 MGM Platinum
    If you plan on doing the East Coast bushing upgrade; I’m will to send my removal tool out to you to use. I received this tool as a freebie so special thanks to @Editmars
    All I ask is that it is taken care of and used the way it was designed to be used. When you return the tool, you must include something local to you; a cool sticker, beer, or beer(unless you’re from Milwaukee, I don’t want any milky beast!) or anything you feel like sharing.
    Only request the tool when you’re actually going to use it, not for an upcoming project in the months to come (incase someone else needs it sooner). Have your parts ready to go for when the tool arrives.
    PM me with your address and contact info. Happy clamming!
    (FrenchToasty, 2020)
    * 95% of post content (ie plagiarized) comes from @FrenchToasty post found here https://www.tundras.com/threads/best-gen-ecgs-bushing-tool.59664/#post-1562978
    but the principle remains the same
    bmf4069, TRDFerguson, 2mchfun and 3 others like this.
  2. Feb 17, 2024 at 7:01 PM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    Super cool of you! :cheers:
    2mchfun, Mater[OP] and FrenchToasty like this.
  3. Feb 17, 2024 at 7:01 PM
    At some point will you measure the width of the part that slips into the diff and behind the needle bearing?
    Mater[QUOTED][OP] likes this.
  4. Feb 17, 2024 at 7:09 PM
    Mater
    SD
    2016 MGM Platinum
    Call it 42.2mm
    2mchfun and FrenchToasty[QUOTED] like this.
  5. Feb 17, 2024 at 7:29 PM
    Cool, I was wondering what the differences were between the two, I found this in my archives 86541610-7390-4CBC-92B3-14BB8423682B.jpg
  6. Feb 17, 2024 at 7:34 PM
    Mater
    SD
    2016 MGM Platinum
    Every millimeter counts!
  7. Feb 19, 2024 at 4:24 PM
    2mchfun
    Good stuff men!
    FrenchToasty and Mater[OP] like this.
  8. Feb 20, 2024 at 7:19 AM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Don’t you need the bushing install driver too?
  9. Feb 20, 2024 at 8:06 AM
    Mater
    SD
    2016 MGM Platinum
    That would probably help but don’t think it’s absolutely necessary. I’ve heard of people using a nicely shaped piece of pvc. I have a cheap race and seal install kit I’m happy to send along with the package that’ll most likely do the job
  10. Feb 20, 2024 at 8:09 AM
    Yeah you’d need the race/seal tool for the bushing itself
  11. Feb 20, 2024 at 8:50 AM
    Mater
    SD
    2016 MGM Platinum
    Sounds good bud! Let me know
    I haven’t seen much about ppl from 2/2.5 gen doing it, but you can head over to the 1st gen thread and ask some questions. I’m sure the procedure is similar
  12. Feb 20, 2024 at 10:14 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    There have been a few recently in the 2nd gen thread. I just did mine as well. Actually, I just loaned out my install tools as well so when I get those back I will put it up in here as a second set if you don't mind, I have the bushing and seal kit along with the puller.
    The process is not really that hard, and I would put my shade tree mechanic skill in the mid-low tier. The most difficult was getting the CV to pop out of the knuckle with only two hands. I used a video from a taco as a guide and it was very close, tundra just has bigger parts.
  13. Feb 20, 2024 at 11:36 AM
    Mater
    SD
    2016 MGM Platinum
    That’s awesome you were able to tackle it! Your skill level sounds about on par with mine. Good to know I’ll be able to do it when the time comes :thumbsup:
    Would be great to get another tool set going on here. I’m sure there will be quite a few of these bushings needing replacement.
    If you don’t mind, when you get your install tool back, if you could send me over some measurements that’d be awesome. I have a springtime goal of getting my lathe back together and dialed in. Turning another install tool would be a great project to get back in the swing of things
  14. Mar 1, 2024 at 10:04 PM
    APalmTree
    Brandon
    SW Washington
    Alright @dittothat and I suppose anyone else who wants to make their own install tools.
    Bushing installer:
    Seal installer: The depth as near as I can measure it at the moment is .375in
  15. Mar 1, 2024 at 10:06 PM
    Mater
    SD
    2016 MGM Platinum
    Thanks Brandon! Much appreciated :hattip:
  16. Mar 1, 2024 at 10:09 PM
    APalmTree
    Brandon
    SW Washington
    Let me know if you get into it and need anything else :thumbsup:
  17. Dec 23, 2024 at 10:29 AM
