How do you turn TRAC back on on a 2017 tundra
Discussion in 'General Tundra Discussion' started by Mikeypop, Dec 22, 2024.
  1. Dec 22, 2024 at 11:58 AM
    Mikeypop
    Mikeypop [OP] New Member
    2017 Tundra SR5
    Traction control off message will not go off on my 2017 tundra regardless of what I try. I don't need a class in all the buttons. Just a simple this is how to turn it back on. Thanks
  2. Dec 22, 2024 at 12:00 PM
    When in doubt, reboot?
    HulkSmurf14 likes this.
  3. Dec 22, 2024 at 2:16 PM
    Tundra family
    Tundra family New Member
    It should be off when you restart the truck. Maybe start with a fuse check
  4. Dec 23, 2024 at 4:32 AM
    2mchfun
    Not because you need it now, but might later...
  5. Dec 27, 2024 at 5:20 AM
    Haroldwest5050
    Haroldwest5050 New Member
    Harold
    To turn traction control back on in your 2017 Tundra:
    Find the Traction Control button - It’s usually on the dashboard or near the gear shifter. It may say "TRAC" or show a car with skid marks.
    Press the button once. This should turn traction control back on.
    If the message doesn’t go away:
    Turn the truck off and back on.
    Check if the "Check Engine" light is on, as some issues can disable traction control.
    If it still won’t reset, you may need to have a mechanic look at it.
