Squeaking a$$ brakes
Discussion in '3rd Gen Tundras (2022+)' started by wysongdog, Nov 26, 2024.
  1. Nov 26, 2024 at 5:00 PM
    wysongdog
    wysongdog [OP] New Member
    Evening, brakes on my wife’s tundra squeak like a sob. Dumb af, we run in the dirt and mud. Any suggestions? New pads? What kind etc?
  2. Nov 26, 2024 at 5:05 PM
    Tundra family
    Tundra family New Member
    1st thing I'd do is check between the rotor and backing plate, pretty common for crud to build up in there if your muddin it.
  3. Nov 26, 2024 at 5:20 PM
    Breathing Borla
    AZ
    known issue, Toyota has a TSB to put on new brakes and shims etc , search for the tsb and ask dealer about it
  4. Nov 27, 2024 at 8:17 PM
    wysongdog
    Talked to my dealer today. Don’t feel like it was important to him to fix it. Are there good aftermarket pads I should just get and do it myself?
  5. Nov 29, 2024 at 5:34 AM
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    No you should get his lazy ass to order you new brakes per tsb and have Toyota fix them
    RickyBobbysTundra likes this.
  6. Nov 30, 2024 at 6:57 PM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    Got this TSB done yesterday. While mine was never excruciating, it was getting more frequent. I didn’t even have to prove it, my SA just ordered it all and got it done with the fuel tube fix. Unfortunately not all service departments are equal.
    RickyBobbysTundra and Timmy23 like this.
  7. Dec 1, 2024 at 10:06 AM
    Rockpig
    Rockpig You did what?
    08 Limited
    So you're just going to take that as the answer? You're going to spend your own money to fix a known problem that other dealers are fixing for nothing? Do you eat the plain pizza when you ordered and paid for a pepperoni?
  8. Dec 6, 2024 at 6:47 PM
    boblc123
    boblc123 New Member
    2024 Tundra Limited 4x4
    Can someone post the TSB here?
  9. Dec 6, 2024 at 7:03 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
  10. Dec 7, 2024 at 5:08 AM
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    How are they doing brake jobs for regular customers if the parts are on back order.
  11. Dec 22, 2024 at 7:09 AM
    wysongdog
    They said there was dirt in the groove of mine and soaked the pads in anti squeak lasted one day now squeaking again. Our dealer is a joke. We live on dirt roads. If this is truly the way it’s going to be. I guess us and Toyota won’t be friends anymore.
  12. Dec 22, 2024 at 7:14 AM
    pursuit2550
    pursuit2550 New Member
    Like it has been said, it's a TSB. The clips Toyota use are supposedly what causes the issue. The fix is the old style clips from the previous Gen.
  13. Dec 22, 2024 at 8:17 AM
    Timmy23
    Timmy23 New Member
    OR
    None
    Print the TSB linked to earlier in the thread. Take it to the service advisor, tell him their “fix” didn’t work, and ask them to do it right.
    If you need to, run it up the management chain.
    I can’t believe how there is such a difference in dealership service departments for known issues. I have had nothing but great service at both my local and original purchase dealerships that is 45 minutes away.
    I took my truck in for its 4th oil change and tire rotation in 2 years the other day as they had a $49.99 special on. I mentioned the lift kit they installed needed upper ball joint greasing as it was not a permanent sealed type.
    (Readylift SST)
    They had the senior tech that had installed the kit, grease it and go over the entire lift kit. He checked and re-torqued everything.
    Final bill was $49.99!
  14. Dec 22, 2024 at 10:00 AM
    wysongdog
    That’s a good service department. Rock springs service department is a touch lacking. I will print the tsb and see what happens next.
  15. Dec 22, 2024 at 4:39 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Company truck is down. I have been driving my Tundra for two weeks now daily. The brakes haven't squeaked any. When I let it sit a week before driving they squeak little ways then quit. So, I am thinking mine is because little rust an it sitting all week long.
  16. Dec 22, 2024 at 5:56 PM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    Farmers Branch , Texas
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    My 23 Pro is my company truck and use it a bit to drive on the project. I only get squeals after it sits for a few hour at times and more so in the mornings.
  17. Dec 22, 2024 at 6:03 PM
    Timmy23
    Timmy23 New Member
    OR
    None
    Brakes on my 23 haven’t made a peep since the TSB was performed on my truck a month ago. Used to squeak in the morning when backing up out of driveway and the first forward stop.
    Not always, but most of the time.
