General Supercharger Thread
  1. Dec 22, 2024 at 5:10 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Not a good month for me. Looks like that smoke from the catch can is severe blow-by looking into rebuild/junk yard replacement options. LKQ has a sub 70k 2020 for 5500. Guess that's why I have been getting such awful mileage. It's really odd, I detect no performance loss (outside MPGs)
    What is the consensus on drop in vs rebuild?
  2. Dec 22, 2024 at 5:13 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Maybe I missed it buried in this thread somewhere, but did you do a compression or leak down test? It was smoking from a sealed catch can?
    Mdl likes this.
  3. Dec 22, 2024 at 5:21 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I blew my 4.0 in the 2010 Tacoma last year. Tore it down and found the thrust bearing gave which killed #3 and 4 rod bearings, which killed the cylinder walls. Picked up a junk yard motor local, which had issues, and combined the two motors together to make one good one. I’d say if you have the time, tear it down and rebuild. If you don’t, then just swap it. It took me from Nov 23’ to June 24’, but I also had room for it to sit and another vehicle. When I finally sorted through all the scam motor websites and found the cheapest possible motor, which happened to be local, I finally made the swap. In reality, if I wanted to, I coulda probably had the swap done in maybe two weeks.
    IMG_3265.jpg IMG_3263.jpg IMG_3301.jpg IMG_3304.jpg IMG_3305.jpg IMG_3306.jpg IMG_3307.jpg IMG_6770.jpg IMG_3727.jpg IMG_3809.jpg
  4. Dec 22, 2024 at 5:33 AM
    e30cabrio
    It's a vented catch can, about 3 months ago, it started mildly smoking from the filter on the can. Last month it got a bit worse, yesterday it became like it was steaming coolant.
    It's coming from both valve breathers & the oil cap.
    I have not done any testing yet, need to do compression & leakdown but whichever way it goes I'll need a shop to do the actual work.
    I suppose if it is the valves, then I just need to rebuild the heads but that's a decision for after the diagnosis.
    I'd think seeing as no apparent oil loss is happening it might be valves.
    Ouch, that is a mess.
    I already have an engineless car in my garage, I don't have the bandwidth for another motor project.
    Whichever way it goes, it'll be at a shop somewhere.
    ARES35, Mdl and helidave[QUOTED] like this.
  5. Dec 22, 2024 at 6:58 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    In 2015 I blew my engine. Put a low mileage one from a 2012 in, stll going. Definitely do a leak down test. If it's really excessive then you got something going on. Hopefully its not serious...good luck.
    ARES35 and e30cabrio[QUOTED] like this.
  6. Dec 22, 2024 at 7:27 AM
    e30cabrio
    Am I mistaken that if I'm not losing oil it should be the valves so hopefully would only need work on the heads? (I'm doing an oil change, bumping from 5-20 to 5-40 after running a cleaner through it yesterday)
  7. Dec 22, 2024 at 7:48 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    If it's burning oil, the smoke would have a blue tint to it. You mentioned that the steam was like coolant? Can you smell coolant in the steam? It could be a headgasket compromised where a water jacket is, so the coolant is getting drawn into the combustion chamber and steaming off. You should be able to find one of these local, and it's a quick/cheap test to check if any combustion gases are getting into the coolant passages.
    https://www.amazon.com/Block-Tester-BT-500-Combustion-Leak/dp/B06VVBSFTF?smid=A1810GNA3P38E9&gQT=1
    ARES35 and Mdl like this.
  8. Dec 22, 2024 at 8:08 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Damn
  9. Dec 22, 2024 at 8:10 AM
    e30cabrio
    No coolant, the smoke is only coming from the valve cover/PVC. No loss of coolant, no visible lost oil, runs hard like always.
    Only performance loss has been mpg for over 6 months. It's been down to 5mpg last several tanks.
    I'm doing compression and leakdown this afternoon. (Before I cange the oil)
    Mdl, ARES35 and armyoffoo like this.
  10. Dec 22, 2024 at 8:18 AM
    e30cabrio
    Here's what it's doing, it got this bad 30 miles from home & I had people staring at me like it was shooting sparks, I cobbled it to route to the intake so I could get home.
    https://vimeo.com/1041533031?share=copy
    No crap on the oil cap.
  11. Dec 22, 2024 at 8:25 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That's a lot of escaping combustion, most likely pushing past your rings or piston ring lands on one or more holes. I had the same thing on my tacoma piston #4, I got lucky and only needed a light hone and a rebuild, fingers crossed.
    ARES35, Mdl, reywcms and 1 other person like this.
  12. Dec 22, 2024 at 8:33 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    That happened on my LS and 2JZ when they blew the ring lands. Would still run fine, but tons of blowby and the PCV looked like a tea kettle blowing shit out
    Black@Blue19, ARES35 and Mdl like this.
  13. Dec 22, 2024 at 8:33 AM
    e30cabrio
    ow
  14. Dec 22, 2024 at 8:34 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Did it get worse after you ran the cleaner in the oil?
    Mdl likes this.
  15. Dec 22, 2024 at 8:35 AM
    e30cabrio
    It is a bit better since the cleaner went in.
    It was just the 30 miles. I'm getting a few things done around the house, will start about 1.
    Mdl likes this.
  16. Dec 22, 2024 at 9:13 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Definitely seems like a ring issue
  17. Dec 22, 2024 at 10:08 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    When you say stock pump, do you mean Toyota OEM pump or the upgraded pump that comes with the Magnusson kit? Pump with Mag kit is designed to run with Mag 2650 in original configuration.
    NatesNightMare and Mdl like this.
  18. Dec 22, 2024 at 10:15 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Sorry to see the blowby @e30cabrio how many miles on that engine?
    As far as fuel pumps go I would not install the magnuson pump and I’d just spend the extra $190 on the deatschwerks 300c pump to future proof your fuel needs to 600whp and only do the fuel pump install one time.
  19. Dec 22, 2024 at 11:01 AM
    e30cabrio
    It's got 1435xx.
    Im almost ready to get into the tests
    Winks4x4Toy, ARES35 and Mdl like this.
  20. Dec 22, 2024 at 11:44 AM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    One that comes in the kit. Honestly I skimmed over it since I don't even have a truck right now and didn't realize the kit came with a larger pump.
    How bad of an idea is it to put a supercharger on a higher mileage Tundra with about 150k miles, 2015+? I could afford the S/C right away if I spent less on a truck but generally that means 130-150k miles on what I'm looking for. I'm only going to buy with carfaxes showing routine maintenance such as proper OCI's even though that's not a sure fire way to guarantee anything but it's better then nothing.
    I know the 5.7's are pretty decent if taken care of but is it that much better to spend 5-7k more and get a lower mileage truck and then put the S/C on in a bit?
    Mdl likes this.
  21. Dec 22, 2024 at 11:47 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Lots of tundras with higher mileage and blowers
  22. Dec 22, 2024 at 11:47 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    As long as the general maintenance(oil/atf)has been kept up should be good. @snivilous has 300k on his and others with low mileage, 150k.
  23. Dec 22, 2024 at 12:01 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Anyone ever use an external magnetic atf filter? Pros/cons? Supposed to not obstruct flow.
  24. Dec 22, 2024 at 12:08 PM
    ARES35
    ARES35 New member for life
    Mile high
    This does not look good for the rings, sorry to see this @e30cabrio :(.
    Mdl likes this.
  25. Dec 22, 2024 at 12:14 PM
    ARES35
    Mile high
    Last piece to the puzzle arrived! Lsd is stout as shit. Now the easy part, installing all this crap
  26. Dec 22, 2024 at 12:18 PM
    e30cabrio
    It's a valve on cylinder 1, good compression from the bottom end, leak down loses 100% on cylinder 1. I'll be dropping it off tomorrow to have both heads done
  27. Dec 22, 2024 at 12:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice find. At least it avoids pulling the engine and a tear down.
  28. Dec 22, 2024 at 12:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Awesome. Compared to my Auburn this thing blows it away. I haven't done anything on dry pavement but it rips on the wet stuff and can get away from you. :D
    ARES35[QUOTED] likes this.
  29. Dec 22, 2024 at 1:06 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I had the original Mag pump and injectors. With a custom tune, I pretty much hit the limit of both. I upgraded to the DW pump and injectors. Not a bad job to redo but if I had known, I would have done it from the beginning.
    j_supra, Silver17 and Mdl like this.
  30. Dec 22, 2024 at 1:20 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    I would say go for it. I wouldn’t be concerned about the mileage. I think the consensus would be to upgrade your valve body regardless if you want the trans to last.
    I installed my 2650 at 165 and the motor runs like a champ. 178 now and healthy as can be
